MYSTIK
Region Leader[RL]
    1140
    2
Everything posted by MYSTIK
  1. MYSTIK
    Spotted
    this is not the place for wanted to buy ads :rolla: please use the wanted to buy section in the market place located in the below link http://www.rollaclub.com/board/?showforum=86 cheers Mystik
  2. heart attack in a box
  3. as a wise man once said "a 20v is worth the effort over a 16v" but I'm pretty sure he was referring to swapping the 16v for a 20v in an sx/gti 930LLO didnt you just freshen up the 4age you put in, if so i personally would stick with that engine as you done 99% of the work already. gearbox isnt really hard to do, and now you have the choice of gearboxes C52 - stock/early 20v st C56 - from both 20st/bt C160 - 20v bt only in the BZ-R(someone correct me here if I'm wrong)
  4. +1 i seem to remember a quote somewhere along the lines of "if it has oil pressure it can be turbocharged" and i can't remember where i heard it or who said it :P
  5. the guys just refreshed a 4age smallport and put it into he ae9x sedan, now it seems the head is dodgy(his words) and he was wondering if the 20 st head would bolt on to a smallport block. yes it will bolt on fine(albeit smallport has an external oil drain in the head which the 20v st doesnt or vice versa), there is the possibility of the pistons hitting a valve in the head, if you compare the 16v/20v piston you can see they are both fly cut differently, so there must be a reason why toyota redesigned the 20v pistons rather than reusing the 16v pistons
  6. i guess you missed the thread on the second page of the sa section? heres the link, http://www.rollaclub.com/board/?showtopic=27402 ill merge the 2 threads later :P
  7. thanks to thoses who have posted their recommendations so far :dance:, the list will most likely continue to change, while i arrange place into alphabetical order in the near furture, and adjust headings etc etc :hmm:
  8. sorry i missed your calls, but i was out at a family friends place until early hours of this morning, will hopefully be at the next cruise one when organised :D
  9. please post pictures of your ride(s) in a rides and project thread not in here :y: it is quite an annoying habit that a few members have or have picked up :) other than that good luck and lets hope it not as far gone as it looks to be
  10. looking at his profile it looks as if the OP has a series 1 seca. so i agree with the witzl's on the series 2 ae92 sx/gti brake upgrade, i did it on of my last corolla, and current s2 seca(standard larger front brakes) and i can't fault either setup, I'm looking at doing the ae101 rear brake upgrade(in the near future) same my seca is pretty much the same as the witzl's twinky, only minus the swarbar(s) so i still get the slight understeer when pushing the car, but still a fun daily that can still handle corners with some comfort :y:
  11. pedders, whiteline, kmac are a few for swaybars i do believe toda have a fairly light flywheel for the 4age brakes will depend on if you want a simple factory upgrade or a aftermarket/custom setup have a read of the link below and it will enlighten you to some of the brake upgrades that use factory parts from other corollas http://www.twincam.info/index.php?showtopic=1063
  12. doctors yes, nurses no they are underpaid :y:. underpaid
  13. now many corolla owners use a similar setup which consist of KYB struts and king/lovell/or choice of springs. by stabiliser? if you mean a rear swaybar you can't go past whiteline, as they have fixed and adjustable available for the ae9x series and while your at it, i will also suggest checking and/or changing you suspension bushes as they are more than likely stuffed if the car is all original
  14. this is the 4th or 5th friday this has been arranged for, so lack of time isnt the issue here, its more a case of inclement weather and cars needing or getting work done. :y:
  15. i agree on that, but then again i probably would have gone with a toyota varient with 2 more cylinders, 1uzfe FTW :y:
  16. hmm we now this seems to be the third thread made about these pm's :y: http://www.rollaclub.com/board/?showtopic=30384 http://www.rollaclub.com/board/?showtopic=30383
  17. MYSTIK
    Conversion
    this is the wrong section for asking technical questions. but i will help point you in the right direction. 4age will be a striaght bolt up, in the ae86, especially if you are using a 4age already setup in rwd configuration and the fuel and wiring setup to suit. if not then the biggest headaches will be the fuel system and wiring.
  18. Borgward Isabella estate hint: don't leave the website on the picture :D
  19. http://www.rollaclub.com/board/?showtopic=26634 < have a read here, and there some more links in the thread for you to read.
  20. Now after having a few people as of late asking where to buy parts or asking for recommendation for workshops to get work done, and a couple of suggestions from SA members. So i figured its time to have our own Recommendations List. Now i would like this to remain and open thread, but there's one catch with this though, first person who posts a disagreement or badmouths a business will equal an immediate thread closure, and thread cleaning/deletion. I know this sounds harsh but I'm trying to absolve Irokin and rollaclub from having an legal backlash. or the other way is to have closed thread and have people send a pm with their recommendations to either myself(MYSTIK) or aidaniel so we can update the list. Cheers Dale Body/Crash/Chassis Repairs Chassis Tech 81-83 Coglin St, Brompton 5007 (08) 8346 2988 www.chassistech.com.au Dean's Auto Repairs Lot 104 Adams Road, Williamstown (08) 8524 6123 Dyno Tuners Bells Auto Service 296 Main North Road, Prospect SA 5082 (08) 8344 9625 Blackwood Dyno Tune 2 Stirling Road, Blackwood SA 5051 (08) 8370 3450 www.blackwooddyno.com.au Engine Rebuilders/Machine Shops API engines 11 Somerset Curcuit, Lonsdale SA 5160 (08) 8326 2028 Mclaren Motor Engineering 6 Howards Rd, Beverley SA 5009 (08) 8243 2080‎ Exhausts Carline Mufflers - Marion Unit 11, 798 Marion Rd, Marion SA 5043 (08) 8298 7840‎ Carline (now complete exhausts) 22 Regency Rd, Kilkenny SA 5009 (08) 8445 2755 D&T Performance 12 Gilbert St, Adelaide SA 5000 Ph: 8212 4100 Everlast Mufflers 31 Golden Grove Rd, Ridgehaven SA 5097 (08) 8396 3255 Well Hung Exhausts 10 Christie Rd, Lonsdale SA 5160 (08) 8186 2880 Fabrication/Machining Lrd Engineering 3-5 Alfred Ave, Beverly SA 5009 (08) 8268 5420 General Servicing Bells Auto Service 296 Main North Road, Prospect SA 5082 (08) 8344 9625 Munno Para Brake & Suspension 11 Charlotte St, Smithfield SA 5114 (08) 8254 3000 Power Brakes (S.A.) Pty Ltd 613 North East Rd, Gilles Plains 5086 (08) 8261 0888 Salisbury South Mechanical Repairs 7a Pentland Rd, Salisbury South 5106 (08) 8285 5544 Smooth Garage 7/ 16 Glasgow St, Wingfield SA 5013 (08) 8244 4344 Strut Re-gas SA 131 Augusta St, Glenelg East SA 5045 Ph/Fax: 8295 5596 Parts New/Used Production Line Spares (GMH specialists) 10 Christie Rd, Lonsdale SA 5610 (08) 8326 3033 Autopro - Clovercrest 1/92 - 94 Kelly Rd, Modbury SA 5093 (08) 8395 3200‎ www.autoprogg.com.au Suspension Industrial Springs 341 - 359 Port Rd Hindmarsh (200m east of the Port Rd + South Rd intersection) (08) 8346 2276 www.industrialsprings.com.au Munno Para Brake & Suspension 11 Charlotte St, Smithfield SA 5114 (08) 8254 3000 Pedders - Morphett Vale 6 Bains Rd, Morphett Vale SA 5162 (08) 8326 4211 Wheels/Tyres Bridgestone Tyre Centre - Flinders Park 294 Grange Rd, Flinders Park SA 5025 (08) 8234 0090 Torque Tyres 1 Playford Crs, Salisbury SA 5108 (08) 8281 2044 Brakes All Clutch and Brake 3 Pinn St St Mary's Behind the MFS station on south road. (08) 8277 8122 LINK
  21. oh dear, i think you have bought yourself a world of trouble with that ke20. there is actually a thread and some post about it in the spotted section. http://www.rollaclub.com/board/?showtopic=29123 << thread about it
  22. might have been a better than saying that you want bigger than a 4age/4agze in the first place :) if you ask nicely I'm sure someone that has a 4age, and lives close "might" take you for a spin and show you that they arent small and weak :)
  23. ummm how about a no. bianca i clean it up a bit later on tonight, and i think it will be mostly the last few pages that need to be cleaned if not completely removed :) i look into it a bit more closely after i wake up a bit more nightshift FTL :y: Edit: did a bit of reading, and some cleaning. anymore that you think needs to be cleaned let me know :)
  24. no, but it will get you a pretty hefty fine though :P
  25. according to his msn status message he's seen the light and bought a dunnydore :P
