Everything posted by cuzzo
Wsid 14/3/12
I hope to come down to watch you leave the ground!
Matts Ke30......sr20det
You could swap to a ke30 booster and try a Camry or Pajero master.
Ae101 Proper Jack Points (Photos Inside)
You want to jack it up from the strongest point on the chassis or bolted to the chassis. Front the engine crossmember, rear the rear subframe. (sorry never looked under an ae101 before) don't use a hydraulic jack on the scissor jack jacking point, all you will do is fold over the sill. Hell most of the time i wont use a scissor jack on the sills ever. Hope that helps.
What Grinds My Gears.
/don't know if serious... If the box is low on fluid it will not drive anywhere. the fluid must be checked with car running and up to temp.
7Agte Ke20
The only pedal box that will bolt in is the standard one. Everything else will require welding skills and grinding skills
7Agte Ke20
Also interested in pedal box pictures. Any reason why you decided to go aftermarket? Whered you get yours from? I'm looking at putting one in my ke aswell. Cheers, Adam
7Agte Ke20
Details on the wheels and tyres? (sizes?)
- Spotted Sydney.
Love the bog dust absolutely everywhere in the garage! Done some work on the old girl.....shaving the rear vents....hmmmm Howd you clean out the numbers? Metal pick?
[Ke20Xx]...Mark'S Ke20
I heard summernats has been cancelled....better start it this weekend. ;)
Matts dentistry ke30 back seat. You don't like those front teeth? Here jump in.
7Agte 20V Blacktop
6 point / 4 point cage? Ill be needing a cage to and want to go more than the regular 2 point. Will be watching to see how you go with it. Ive seen a capri with a full cage engineered as the head to bar clearance was a particular size needed. Unsure of specs though, but it can be done in NSW apparently.
1974 Ke30 2Door Street Racer
With the seat belts, Get some ke55 ones. The clip bolts to the floor and there is a captive nut already in the chassis. Or get some brand new ones and tell me where you got them from ;)
Sr20 Powered Ke20
f@$k me thats a big turbo. What radiator is that and where can it be sourced from?
Daisy The Ke30, Vtec F20C !
Haha love it mick!
7Agte 20V Blacktop
Yeah i do have it closer but either way i still had to cut the shifter position. It seems like your motor is further further forward cause of the dizzy?
7Agte 20V Blacktop
Did you want a shifter housing a bit further forward towards the firewall?
Cuzzo'S 4Agte Ke30 Rip -Reincarnated!
So some progress..... Engine bay in primer....need to finish off the cooler mounting and radiator setup. Ill have to put the motor back in for the time being and mock everything up. Any holes to be drilled...then i can lay some colour.
Yeah i need some doors badly though. Any connections? ;)
Nice pick up Andrew. Soo bloody jealous...I have to make mine half as good condition. Any conversion plans?
Ke Paint Choice
Nice colour! don't do this to me I'm about to paint mine :S
Ke26 1Jz Turbo (No Longer 13B Turbo)
Awesome. can't wait to see its first outing! Let me know when you head out.
Its definetly come a long way from the stocka! Any body work need doing first before its first outing?
Well no really progress pics but: Its business time......
It might just be worth doing the internal pump. Thats heaps of fuel it could hold. e85 ftw?
