Trev
Donor
    6398
    29
Everything posted by Trev
  1. Yes you can.
  2. When you look at it, our bikes really do have bad economy.
  3. Yes indeed.
  4. I will burn your houses down if you pricks don't go. If you take your bike and it starts raining then you are more then welcome to jump in with me.
  5. As long as we aren't flying up to corners and slamming on the brakes then we should be ok, just have to keep the tails inline.
  6. Ok, you could also check that the speedo was working but not sure if you have one since it is a paddock basher. Did you put the plate in the right way, have the flywheel surface checked? change the pressure plate? check to see if the input shaft was still intact?
  7. Put it in gear and with the hand brake on let the clutch out and have someone look under the car to see if the tail shaft is turning, you may have smashed your diff.
  8. I like this pic.
  9. I have kept my shit ass tyres on the back for this reason :dance: I have nothing against cyclists but I am going to go install on of these to the back of the ute for the lols: http://www.youtube.com/watch?v=chw1ubYk9IE :lolcry:
  10. I will come ride your bike for you :P I actually got into the shed the other day and ran my bike for a while but realised it still has a charging issue, I dunno if the magneto is shagged or if the harness is playing up, it has a brand new regulator and when I fitted it all the tests on the magneto confirmed is was working, shit is getting annoying. 19914afc, if someone that has been riding bikes longer then you says to you 'your front brakes need attention' don't reply with 'nah tyou are just too fat as they stop me fine' my ignorance is what caused my accident.
  11. Sweet, will have to line something up when I get mine back on the road. http://www.rollaclub.com/board/topic/32666-trevs-1990-fzr250rr-yamaha/page__p__362763__fromsearch__1#entry362763
  12. All ready: http://www.rollaclub.com/board/topic/49680-trevs-84-nissan-720-king-cab-2wd/page__view__findpost__p__570640
  13. Air filter is back on, bolt + loctite. Diff oil has been changed, all points greased, front brakes serviced, rear brakes changed, new dot 3 brake fluid.
  14. No water in the washer bottle means it isn't working the way it did from factory, we still have the road worthy guidelines book at work and ʞ©$ɟ some of the things are pathetic. Had one custome bring in a EL falcon, the work I wrote down that it required to be road worthy came to $3500 (this included a blown HG), no one wants to pay to fix a car these days ad I am not saying my car is perfect, I have had a yellow sticker on it this year and there are a couple of things that it can be picked for.
  15. You do know that a cop can defect a car that you just drove out of the showroom right?
  16. This, all the things you posted are still a sign of a bad electrical issue. When the fuel filter in the mrs 82 blocked up the car would just die, no funny tacho readings and no different from hot to cold.
  17. S series are also found in ke70 vans. you just need a flange that is 55mm square bolt pattern and 38mm (IIRC) center bore. Forgot to mention, make sure it isn't a staked uni shaft as you have to pay a lot more to have the uni removed.
  18. Hard to explain, kinda like a nacho but more mexican. ʞ©$ɟ, just buy one :P Mine is only a 250, the only drama I had was getting it up the hills as it had a few dramas, through all the twisty's it was quite fun and responsive, if you have never been up there then BE ʞ©$ɟING CAREFUL, I had mine at a 45 degree steering sideways slide in one of the corners, they really creep up on you, what bike do you have?
  19. They don't hit the guard because the suspension is that hard and or it has so much camber that there is no way it will have the angle to touch the guard. This was also about stretch and not camber.
  20. This, I love the smell of Nulon carby and throttle body cleaner. Dunno about you but it smells like someone has been sitting in there wih a cigar, worst one was recently in an Estima that would get worse with the cabin fan on, we ended up looking at the cabin filter and changing it as it was green. Want me to put a little bit in a sniffer bottle for you? :laff:
  21. Dang it, wish my bike was still on the road, would love to take it up there again.
  22. Take your dizzy cap off and check to see that the windings in the dizzy are still intact.
  23. Ah mexicana pies an Munch pesto chicken wraps, yum yum yum yum.
  24. Oh ʞ©$ɟ, lucky you said that, it would have been a long wait at the BP for me.
  25. If you don't wanna drive from Warwick saturday morning then feel free to put your tent up at my house friday night.
