Trev
Donor
    6398
    29
Everything posted by Trev
  1. Funny you should say that as I have been saying that there should be automotive parties.
  2. :laff: You will see my dent from when my ute got ran over.
  3. Is that it????
  4. :hmm: Still have not found it, if you drive something with a dent in it it means you are a shit driver, if you own a drift car with a dent in it it means you ʞ©$ɟing rock cause you are a hard out bad ass, where the hell is the logic? :dance: It's been a while
  5. S series will also fit, we just had one made up for a customer at $400, SR into AE86 with T series diff.
  6. Stretched tyres are for dumbasses that want wide rims but don't have the power to spin anything wider then 10cm, stupid ʞ©$ɟing idiots.
  7. ok
  8. I will be a shit crunt like yogi bear and steal your picnic baskets.
  9. Thank god it ain't spring as with all this rain the leaf sap would make it slippery as hell, as fun as it sounds I would prefer my front tyres to maintain contact.
  10. Fairies, I has no fear :laff:
  11. You have the earth on the cd player hooked up to the wrong spot, you have it hooked up to a lighting source, need to hook it up to a proper earth.
  12. Ha, that is better then my old plate 169EXK, 1 69 extra kinky.
  13. If there was a problem with the gearbox fitting then I would have said so but instead I said only if it has a 220mm clutch. The 4afe flywheel will not work as it is only 6 bolt, I am assuming you are trying to bolt the gearbox upto the 20v which already has a clutch and flywheel on it. Yes, just go bolt the f*&king thing up, if the clutch hits then shit happens.
  14. Obviously he is asking if the 20v clutch and flywheel will fit, if he was using the 4afe (which he can't) then he would not have a problem.
  15. Trev
    Spotted Qld
    They only eat gearbox's, everything else is fairly good.
  16. Hunting is caused by a cooling system problem where the water doesn't always meet the wax pellet under the intake manifold, if it has an issue with the cooling system then it will run rich, also the temp sender for the dash is on the water outlet (top hose), have you checked to see if there is sufficient water in the system? Might also pay to check you TPS settings.
  17. Trev
    Spotted Qld
    Pajero, it has to be a wanker :lolcry:
  18. What does it run like while it is running, does it seem to be on cold start (idle high) or just really fuely?
  19. Keep me posted for this, take the ute or the rolla :hmm:
  20. The pressure plate only hits if you have the 220mm clutch, measure the flywheel and clutch assembly for the 4afe and then do the same for the 20v.
  21. Have never seen one do so yet and I have changed the coiling system on one with a 2 hump.
  22. Yes, was on trade me a while back too.
  23. What numbers are on the tag on the cartridge?
  24. Was awesome to ride, just sucks that my brother decided to take it apart one day and misplace all my shit.
  25. So I finally got the pics of my bike (well it used to be :P) but I didn't bother washing it. Lock on brakes, were great for parking as it never moved.
