Hiro Protagonist
  1. Well ended up waiting a little bit more than a year, but I've also been slack in updating my forum threads. So, in clear violation of 2020 norms, we decided to socially un-distance the body from the wheels - Blue springs for a blue car, of course. Ended up with 40mm drop on the front and 30mm on the rear (but the rears should settle a little more seeing as how they are new). Passed the shoe test (cheated and used a boot :p), does make getting in and out of the driveway a little trickier since we have rolled gutters (so there is no dip on the driveway portion). Not much changed in the year since (what with COVID and still being in warranty and all), but not long after said lowering was done the SX/ZR wheels that I had stashed away copped a load of Pilot Sport 4s and went on (was waiting for the lowering springs to go in and for a 25%-off tyre sale) Here's how she sat, waiting for the train of cars to arrive at Nepean Dam for CCAD 2021
  2. DoE means Duke of Edinburgh Award to me Damn monarchy has their fingers in everything
  3. Reserve lifted may mean that it has actually hit the reserve mark by that point, but the seller/agent has decided to remove the reserve (think of it as "lifting" a restriction) in a way of sparking further interest rather than waiting for the reserve to actually be met (sometimes bidding will peter out before meeting the reserve as people lose interest not knowing how high the reserve floor is). You'll see it a lot with house auctions, agents/auctioneers will notice that buyers are losing interest before the reserve is met and will pause/halt the auction to confer with the seller to see if they want to stick to their original reserve and possibly let the auction "pass in", ie not meet the reserve and there is no obligation to sell to the highest bidder (but there is the option for private negotiation afterwards) or if they want to lift the reserve and the auction then becomes "absolute" (ie it _will_ sell to the highest legitimate bid) Not sure of the legalities, but increasing the reserve price once an auction has started would be incredibly unethical.
  4. So, some kind of progress happened... There's now a big empty hole in my life....I mean my engine bay One 7AFE + C52 extracted as ordered And now the install begins... Step 1: Check Euro-spec ZZE112 timing-end mount fits. It does (no mods required) Step 2: Check C52 gearbox mounts fit Celica C60 They do (slight mod required to stiffener on top gearbox mount but could be left off) Step 3: Check fitment of C60 in to Corolla engine bay It fits (just), clears subframe (although will need sump/block attached to 100% confirm), however battery tray will require some surgery to allow the front-mounted Celica shifter to work (battery will be getting relocated anyway) Step 4: #getonthebeers Check
  5. I don't think the shifter end of the cable is really "serviceable", you can get solid brass bushings for the gearbox end from Speedsource etc (or do the classic skateboard bearing hack) but if the shifter ends are really flogged out it might be a case of a new shifter cable (or shift arm if it's the ball on the shifter that is worn rather than the cup on the cable). Normally the shifter end it is the cradle bushes that you replace to try and firm things up. Is it an all-round "looseness" or limited to front/back or side-to-side (which might indicate a particular linkage bush)?
  6. Which bushings? The ones on the linkages on the gearbox, or the ones on the end of the cables under the shifter?
  7. No, AZ6 is just the Aisin-Seiki name for the box (it is used in a bunch of other Japanese cars such as the MX5, 200SX, RX8 and even the 86/BRZ, but with different bellhousing patterns for all), has nothing to do with the Toyota AZ engines
  8. None, because the 2ZZ is still attached to the engine-stand in the garage...
  9. There's a Hoonigan half-hour video on the same car, goes _very_ indepth
  10. So, time for another little catch-up. Finally got around to getting rid of the donor Celica shell, managed to sneak it in under 2 years by a single day, which is a pretty decent indication of how slowly I move with most projects Next was getting the SuperStrut brakes fitted Calipers and carriers vapour-blasted ready for overhaul (second set for a mate's Sportivo) Primed Top-coated (I went matte-black, Andrew went silver) New pistons, seals, dust boots and clip-rings And new slide pins, boots, bolts and banjos Interestingly when I got my wheel bearings replaced back in 2017 the new hubs came without the 55mm step in them.....so the AE111 rotors I sourced would no longer fit properly (also meant that the new rotors I got when trying to diagnose the wheel bearings have been flopping around with a mil diameter clearance for 2 and a half years, well that explains the brake shudder...). Good thing I still had the 54.1mm AE101 rotors as a backup Rotor now centred well in the pad carrier, if I wanted to use the more commonly available DBA759 Sportivo rotor I'd probably have to get another 2mm machined off the carrier and that would be a little too much for my liking Make sure to use the SuperStrut pad not the ST204 Celica pad (Celica pads are thicker and the caliper won't fit over them), I used DP3995C EBC Redstuffs but any pad for the later SW20 MR2s will fit (same pad as the SuperStrut Corolla) Caliper fitted And new braided lines just for bling And the end result
  11. AE101/102/111 coilovers will fit 100% (as long as they aren't for a SuperStrut model), I believe AE92 will as well but not 100% (some places say they do, others have different part numbers)
  12. Just bought a second-hand set of Yellowspeeds (no, not Godspeed or maXpeedingrods or any other eBay crap), was never really certain that I wanted to go to coilovers but they came up at an absolute bargain so couldn't resist. Interestingly they appear to be 7/4kg F/R which is a little different from the usual 6/4kg and 8/6kg sets out there Will pull them apart and give everything a clean and oil (the threads look like they could use it) and maybe a bit of paint if I can be arsed). by Ian Rigby, on Flickr
  13. Another piece of the puzzle (courtesy of bway) by Ian Rigby, on Flickr 1-1/2" primaries, 4-1 merge collector, v-band mid-joint, 2.5" down-pipe. Many revs. Much shiny
  14. I've been saying for a few years now that they should transition Supercars to a modified-GT3/4 category, probably the closest international-grade category out there to what the V8s currently are speed-wise, plus allows manufacturers an easy entrance back in to the Australian racing market (can still have Ford v GM v Toyota v Nissan et al, just won't be a Taxi Racing category any more). If they wanted to try and maintain more of a link to the "win on Sunday, sell on Monday" mantra then they'd probably need to go more towards an expanded TCR category, but you'd have better luck converting a dyed-in-the-wool Holden/Ford V8 supporter to a Camaro/Mustang GT4 than you would a Hyundai i30N or Golf GTi TCR.
  15. Been a little while since the last update - 12 weeks/60 days and 48 flights worth of travel for work on one hand, plus my old man passed away in September on the other has meant that this year has basically been a write-off as far as car updates is concerned, but that didn't hamper much the accrual of parts. Latest haul below: 20191224_160022 by Ian Rigby, on Flickr Fidanza lightweight flywheel (3.4kg vs 5.9kg factory) Xtreme HD clutch ARP flywheel and pressure plate bolts (the only Toyota bolts that ARP list for the pressure plate are to suit a Hilux and cost a fortune for no reason, however Skyline ones are dirt-cheap by comparison and same thread, just a little longer) New VVT and VVL solenoids and OCV filters Full VRS kit
  16. So that's how things stood at the start of this year.....basically nothing has happened since. Still got to pull the shifter cables out of the Celica shell (which requires disassembling most of the dash) along with some of the body harness (for the engine bay fuse box) but in the meantime I've started hoarding parts for the eventual conversion. First things first - some tools, and something to put them in. Been wanting a decent roll-cab for ages but never really had enough to fill it, but eventually got sick of all my stuff being scattered between two separate toolboxes, a builders-bag, and the floor, so I snagged one of the limited edition Mighty Car Mods roll-cab set when they went on special. Knew we bought a hatch for a reason... Then decided it was time to make the swap from Ryobi One+ to Milwaukee, much better tools as well as being smaller (with inline batteries too, much better for engine-bay/undercar work). Got a 1/2" power ratchet, 1/2" stumpy impact wrench and a 13mm hammer drill (for house stuff). Also just picked up a 1/4" hex-chuck impact driver for the small stuff (not pictured) Then came the parts hoarding. First up was a plug-n-play Adaptronic E440d ECU modified by Kaizen Garage, which Jason Purcell had running in his AE82 2ZZ race car. This will allow be to do away with the factory immobiliser, run a bigger intake without the factory MAF (has onboard MAP sensor), as well as tweak lift and redline rpms to my liking (not to mention being able to support bigger cams). Next was a bunch of little bits and pieces to try and spark my motivation again - a 6-speed TRD ball shift knob (from the Tacoma/FJ Cruiser), height perfectly suits the MWR short shifter. Also got the MWR underside WP and ALT pulleys for some extra bling, a 77° TRD thermostat, Speed Source extended slave cylinder pushrod, and an MWR MR2 2ZZ engine mount adaptor. Along with that I also sourced the RH engine mount from a 4ZZ Euro ZZE111, so between that and the MR2 adaptor I should have something close to built-in. Next up will probably be clutch/flywheel, and maybe start looking at cams (but that opens Pandora's Box, because then I'll need valve springs, then might as well get new stem seals, then might as well get new valves, which means the head has to come off etc etc)On, and the Celica shell is a bit breezy now too... by Ian Rigby, on Flickr kr
  17. To get classic/historic registration in NSW you need to be a registered member of an affiliated club (and by club I mean an actual club, not an online forum). If you're in Sydney, and willing to be an active member of the club I'd recommend Toymods (their information can be found HERE), conversely I highly recommend staying away from Whitmore as they are known to be dodgy. Otherwise you'll need to look around your local area for an affiliated club (unless you're out in the boonies there are usually several around) and go through whatever procedure they require.
  18. Pretty handy reference for the codes but I know some of the dates are wrong, OKA Diamond White is listed as being 2000- when in Australia at least it was available from the early/mid 90s on the Corolla and Camry (have had both).
  19. Pretty sure the 4AFE never had 84kw in Aus (some of the imported AE95s might have had the high-comp version), if it's a locally-supplied 4AFE then it'll be ~75-78kw
  20. The 4AFC is 16-valve but it is the narrow-angle slave-cam arrangement which doesn't have anywhere near the aftermarket support of the GE.
  21. Any wheel/tyre shop will have tonnes of 4x100s, it's one of the most common small-car wheel sizes out there. If you're after used, just go to your local wreckers/parts-dismantler, they should have piles of wheel sets lying around.
  22. North American Toyotas have had Entune for a few years now (which I don't think ours did) and there is no end of hate for it.
  23. I started on Twincam.org, then moved to Toymods, then here shortly afterwards, followed by TOCAU, OzCelica, AE82ownersclub, ToyotaNation, AE101ownersclub, SoarerCentral, MightyCarMods (before someone flicked a switch and deleted everything after 2013....) Well I say "moved", but I've stayed on all of them (apart from Twincam which got bought by a douche-canoe and died a quick death, and AE82oc went defuct)
  24. Just made me realise I've been on here for almost 13 years now (which will mean 13 years since I bought the then-gf a KE55...)
  25. Day +next - engine is now on the stand. Had to take the flywheel off as the mounting arms were hitting the pressure plate dowels, and could probably use a washer or two on the top gearbox bolts as they just bottom out in the block. Currently pivoting around the crank which makes it super hard to turn (2ZZ is quite top-heavy too), need to try and lower it as much as I can so it doesn't turn in to the Leaning Tower of Pisa. Actually ended up re-fitting the exhaust manifold just to try and balance it in the short-term. by Ian Rigby, on Flickr Next step (after balancing the stand) will be to label and strip off all the hoses etc, get the manifolds off and then pull the cam cover to do the lift bolts (and get an idea on the general condition of the engine).
