Everything posted by Mick E
Ke-25 Sprinter Specifications
i have a ke-25 would like too build it to sprinter specs. ie twin carbs tacho dash what are other specs please
White Ke-25
sorry i ment to say pics would come later , when i get the car back
White Ke-25
hey fella:s just picked a ke-25 , 5k 4spd 13 inch mazda rims ke-70 front brakes. no pics yet getting road worthy, check at the moment in great condition for 74 model corolla
Rust In Ke-25
is there a rust repair section for ke-20-25, spare wheel wells. thanks
Settings Tappets... Rule Of 9
if its a ke series motor check a manual , you can withone valve downyou adjust four tappets, one full turn you adjust the other four .
Have You Weighed Your Rolla?
74-ke20 khana cross car alum radiator 5k t-40 gearbox std banjo diff hornet foam filled fuel tank. perspex back and side windows, sparco race seat gutted interior chome-moly cage hyd-handbrake steel bumpers,all other panels std corolla. weight on tested public digital weight bridge was 780 kgs front 420 kgs back 360kgs
Genuine Toyota 3k Duel Carby Setup
great job great price will clean up well
Ke20-ae86 Suspension Parts
will be up for lcas for ke-20 rack and pinoun for ke-20 you beauty
toyota sprinter carbys and manifold how much did you pay
Ke25 Steering Box
there,s an adjusting grub screw and locknut on top steering box. adjust in straight ahead position not too much as steering will lock up
Wonder If This Actually Works
evan g they do work, a 16 year old girl ran jb camira. with an elec super charger on it in vcas events went very well
- Trds Rally Car
- Trds Rally Car
- Trds Rally Car
Gasket Identification
1 exhaust flange 2exhaust to inlet manifold
Wheel Idenfication Help
these are rebel wheels still avalaible in sydney i think
Xt130 Struts
13 x6 superlites 13x5.5 superlites with a 3 mm spacer 13x7 rebels will fit
Front Bearing?? Please Help!
there is a little bit of mucking about removing the drive shaft cost just a guess about 250 bucks
Ke20 Rare Suspension Changeover
can only fit adjust camber tops if you have coil overs struts . to get any good camber
as coln72 can only
Snapped Axle
most axles snap at spline end should be able to remove diff centre
Snapped Axle
redwarf is right most axles snap at spline should be able to remove diff centre
if its fwd its most likely a constant velocity joint in the drive shafts
Removing Tie Rod Arms
cam the 2 nuts are locknuts 1lh thread 1 rh thread heat adjuster and drop in bucket of water should loosen them
