dashills
Everything posted by dashills
  1. Hey mate , tidy ill rolla , as jay said brakes first , maybe wheels and ride height , half inch from the back , inch from the front ( PLEASE don't cut the springs ) if your looking for the 55 late front try old school wrecker or other blokes on this forum . For inside what condis is it in?. Could you show us pics?
  2. Dave , falcons are a pig for that ,you put in a yolk , it snags on the rack 4.5 ltrs of trannie oil every where . I hate fords .
  3. Hey mate, The yolk will stop oil as long as its not scored and the right one . Mistakes happen so we must learn from them we only human . Maybe next time pop a oil bucket under it so if you don't have a yolk , you might be able to catch it
  4. Yeah they did in the 2.0 ltr and theres 3 engine sizes 1.6 ,1.8 ,2.0 and the b6 and bp have 5 speed with short shifter Which make the great bang for your buck . I picked up full alloy rad for under $150 today . Sweeeeeeeeeeet
  5. Oh and more POWER .
  6. Hey all, I'm poppin a mx5 b6 1.6 Dohc motor and box into a t18 . Let me know what you guys and girls think . What i have found out is manifolds are on the right sides , elec ign , cable speedo drive , hydrualic clutch . All these things are great no need to custom it to fit ( I think)
  7. Hey dude A new pump is in order , it's a major f up , the whine is the pump fins scoring the housing , not good Cheers David
  8. hi mate try niping up all the inlet and exhaust nuts and bolts as my e7 use to run like crap for that reason and your cluster might have had it try getting a replacement
  9. Hey Dude , try xd-xe-xf ford front nearly same diamiter as e7's you will have to cut them , stiff as , nearly no body roll at the rear
  10. Hey Dude If your going to rip the head off , port it, polish it, double valve springs to suit your new cam , larger valves and harden seats ( then you can run ulp 95 no flash lube :D )and maybe bronze guides. :yes:
  11. hi mate , what gear box are running ?
  12. Hi Guys , I have a 2tgteu manifold and loom and need to know where all the plugs go, and what the part numbers are ? Also which electric fuel pump to run ? which ecu to run 2t , 3t or an after market unit ( i was thinking wolf V4X )the engine is a ohv 3tc , the engine mods high mount turbo , front mount cooler , bov , boost controler , turbo timer , upgraded injectors and maybe a coil pack . Thanks Dave
  13. Hi Mate, Try for some 205\ 60 r 13 you can still get them
  14. Hi Mate , Did you mean the spliter / spoiler on the stone tray under the bumper ? if so i think you might find it on ebay uk .
  15. what motor are you running ?
  16. i will cars in storage at the moment i will do as soon as i get in to the new place
  17. run the piping under the front lower rad support , i've done this already
  18. Hey t18drifts , are you going to do front mount cooler , i would customize the intake chamber and throttle body upgrade . I have seen one on the net put out 700+ hp
  19. nice mini dude , is disc front end or drum
  20. hi guys , havent in on for a while , but try a company called brd racing at www.brdracing.com they have all kinds of stuff for 2t and 3t rollas . i know they hav a front and rear coil overs they make them to your specs .
  21. hey there , how did you fit t18 struts into a e7 they have got diferent top plate ,and the t18 has got a small section of coil at the bottom of the strut so no you can't
  22. hey dude no they wont the pcd is wrong dashills
  23. hey josh, one quick question is it efi or carby ? i only ask because the topic title says " carby issues " but on your post it say "lack of petrol in the tank in an efi car" just wondering
  24. try jacking the 55 up slide the manual under with you and do a check of the trans and box mounts , whats the worst that could happen
  25. hey there , could be the drums are not adjusted properly ,front pads or rear sheos could be stuffed , or it could be some thing simple like one of the bleeders could be loose ,booster's shot
