Everything posted by LINDSAY
My New Beast, Ke25
Hell yeah , go the KE25 weapon , and that monaro colour will look the goods , don't see many light blue KE2# series , keep up the good work man
Photos
I reckon they all pretty farken nice , just ask my pants !!!
Red Mango
OOOOHH hell yeah !!! this looks good , can't wait to see her when shes done , gidee up
Rolla20s Orange
FARKEN ELL this is one the best rolla's i ever seen , good job mate you can be very proud of yourself for building this thing
Ke70 Cutting Out Everytime It Hts A Hill
Have you checked you fuel filter ? take it out and see if you can blow through it , if not or if its hard to blow through replace it and should be sweet.
Ke25 - 4age
hey there all rollaheads , good idea cuzzo i think one of my mates has an AE71 rad. in his garage , i'll check it out . ca18rolla thats the golden word "reliable" , i really like your car by the way must go pretty good . i just received this fuel pump from ebay today EBAY- fuel pump Is this going to pump enough for a lift pump , i'm thinking that the main high pressure pump (255 lph) might be taking more fuel than what this lift pump(75-100 lph) is able to supply to the surge tank , anyone able to set me straight?
Raven's Ke25 Corolla Memorial Rebuild - Now Parting Out
Hi Raven , loving your 25 man , looks good. hows the brake upgrage coming along ? i've been following this with some interest cause i'm not far off starting a brake upgrade on my 25 , are you going to change the control arms ( i've heard something about issues with camber with the standard ke25 ones) Just intrested to see which way you go with yours , keep up the good work mate GO THE 25'S Lindsay
Ke25 - 4age
Cat convertor is coming soon when i get the exhaust done , but the charcoal canister i hadn't thought of , do you run the fuel return line through that ? where abouts are you getting engineered at ?
Ke25 - 4age
Thanks for the comments guys , yeah can't wait to get the beast going . I got busy on the weekend on putting an unleaded filler neck in ( engineering req.) seems a bit silly when you can't even buy leaded fuel anymore . I took the filler neck of a 87-90 Mazda 929 at pick & payless a couple of weeks ago (cost me bout $15) and had to cut it down a bit to join it up to original fuel tank inlet pipe
My First Car! Ke30!
Good work with the boot retrim Dean , looks really good man .
Ke25 - 4age
Nah , i wasn't planning on it .Where it sits right now is sort of reinforced and it is very stiff there too (busted a couple of drill bits getting through)plus i'm trying to stay away from welding as much as possible , my old man has got the welder at his place and we're both pretty average welders anyways . is it an engineering requirement or something?
Ke25 - 4age
i had to then finish the cooling system , basically just find some hoses that fit and are the right shape . It got a little bit hard when the bottom hose outlet on the radiator is the oppisite side of where it is on the engine , but a trip down to pick and payless found me a cooling pipe from a mitsubishi colt that i cut down a bit and looks like it'll do the job . Heater hoses needed to be re-routed with a couple of elbow barb fittings put the plenum/manifold on the other day to check if i had clearence from the master cylinder , looks fine for the moment but i think that i might have to go a dual circut m/cyl but i might leave that untill i get to the stage of brake upgrade. so this is what its lookin like at the moment
Ke25 - 4age
next thing to get done was the clutch master cylinder needed to be installed , to do that i took some MDF board and made it the shape of the clutch m/cyl flange , then traced around that onto the firewall where i thought it should go and started drilling small holes around where the whole in the middle should be then chiselled between the wholes and enlarged it for the m/cyl to go through . i used an AE71 clutch m/cyl just had to shorten the push rod a bit .
Ke25 - 4age
Hello all i have finally got some pics of my work in progress , about february the 3K in my KE25 had just about had enough So i got myself a 16V 4AGE with T50 , it was all setup for RWD (plenum , thermostat , etc) and ripped out the 3K and got to work . First up me and my Dad put the engine in its place with the AE71 mounts that it came with , no go , the mounts were too wide for the brackets on the x-member so we had to get started on making up some custom ones these are the mounts the me & Dad came up with , made from 6mm steel plate . we used MDF board to get the shape of the mount pieces and used them as a template on the 6mm steel , cut the steel shapes out , then while the engine was suspended in place by the engine crane tack welded the various shapes together as these assemblies , then took them to a steel fab place and they welded them properly for me . Got the engine mounted nicely now with just enough room at the back then i noticed the mount was right inline with where the oil filter should be so i had to install a remote mount oil filter setup like this
Ke20 Project. 3k To 4age To 4agte
hey man , it's looking good mate , i just read through the whole thread and sounds like your a bit ahead of mine , i'll have to get my own thread going for my beast soon , got plenty of pic's now . How did the S6 RX7 master cylinder go ? was there enough clearence with the manifold/plenum ? i'm very interested to know , i've still got the stock single circut M/Cyl and i think your right , a single circut ain't gonna do the job . Cheers , Lindsay
4age Afm Loom , Map Engine
thanks mate but i think i have it sorted for now , but i may get back to you on it . hows your beast coming along ? ( i'll go have a look at the thread )
the on on the right , goes to the MAP sensor ? i think
Hey thanks Medicine_Man , no not confused . so did you need to change the ecu or will they do both MAP and AFM applications? , any benefit of having one or the other ?
Hi all , Does anybody know if i can use a AFM loom on a engine that i think is a MAP sensed one ? Basically i bought the engine and the loom from two different sources , the engine i think is a MAP sensed because it has the fitting in the plenum with 3 x vacuum nipples coming out of it but it didn't come with the MAP sensor and the guy i bought the loom off says he beleives its a AFM sensed loom . any help appriciated thanks , Lindsay
Recent Photos Of Me And My Bros Corollas!
Looks good man , where abouts did ya take tha photos ?, looks alot like Jindabyne edit : ahh Tamworth , just saw your profile
Diff Pinion Seal Ke25/20
howdy all , i need to replace the pinoin seal on my diif , is it as easy as just un bolting the tailshaft flange and the nut on the pinouin shaft and pluck the seal out ? my dad was saying i might have to take out the pinion shaft , but then again he like to do things the longest and hardest ways possible sometimes any help appreciated , Lindsay
Is Your Pc Dusty?
Sweet , gotta get me sum of that
Is Your Pc Dusty?
What's the best way to de-dust a pc?
State Of Origin
you could start with your newest rookie star !
State Of Origin
OOOOHHHHHHH , Poor wittle Qweensland wost the game :lmao: It's ok you still got a couple of weeks to recover , stock up on tissues and cuddle each other before we beat ya again , HAHA :D
