Rollaclub 1/4 Mile And Track Times Discussion
1:10 at Baskerville, using 3rd and 4th only. (not 2nd). On 185/60 firehawk tires, and only 2 degrees castor.
Edit: Oh yeah, Ke25 corolla, 3sge.
Edited by robj
  • Replies 155
  • Views 128k
KE35 4AGZE Time: 14.780sec R/T: 0.320 2/12/09
Is there a leader board somewhere? or do we have to go through all the pages to work it out?
The first (leading?) time, the speed looks incorrect? I don't think if you go 104mph you can trap an 11 :yes:
Also can i add 1:12:00 for my ke30 4agte at wakefield park NSW
BTW are these natsport / official timing results or gps based times ok?
Thanks.
Edited by cuzzo
The first (leading?) time, the speed looks incorrect? I don't think if you go 104mph you can trap an 11 >|
Thanks.
Pretty sure Curly has a time slip for that pass. I also remember reading he was on the limiter crossing the line, so that may explain why the trap speed isn't as high as it maybe should be for that ET.
I frankly don't care weather the track timing are done with a stop watch or hour glass!! :yes:
I took the placing off the track times, so this more of a reference of how your car compares to others. If we had a lot more times for certain tracks then I would then think about adding some placing back on it.
Your time has now been added. :hmm:
Thanks.
it has run 12.4@84mph and 12,3@121 just depends how it takes of, the 104 run was on a dial in time of 12.00 so i had the foot on the brake
Fook me,
whats ur 60footer?
edit: i still don't understand how????? isnt there some maths against that? 114mph i would believe but WTF?
double edit: i have used a few online calculators (not sure if accurate) and the all say they mph would have to alteast be around 118mph. Thats going on weight = 1Tonne and 300horses.
I'm not doubting the time just the speeds.
Edited by cuzzo
You ever had the '20 down the 1/4?
I WISH!
no drag strip in SA means ive never had the chance :yes:
Would love to tho, an interstate trip seems to be only hope at this stage tho
Fook me,
whats ur 60footer?
easy answer 450hp the wheelspin is the problem, .3sec reaction time, 1.61 60ft 98mph half track, 2 year old yokohama c drives on 15psi and it weighs 1060kgs
the 12.4 @ 84 was same setup but in a ke30 crossing the line wearing the door handles away
Added. Got a trap speed and 60' time original?
92.82mph 60' 2.240
