Rollaclub 1/4 Mile And Track Times Discussion
Thats a very good rule to address BUT (Here we go :) ) what if the time recorded was done at somewhere like the main straight at qld raceway or another track and they havnt been bothered to go to the drags to test it.
Its a blanket rule. If you're using a G-Tech chances are you're doing it on the street. Its also about effort. If they can't be bothered to go to the track when everyone else has why should Des bother adding them? And why would you take so much effort to get on a race track that you're not usually allowed to stop on just to G-Tech your car? :y:
  • Replies 155
  • Views 128k
I did a 14.38 @ 95Mph (1.00 reaction, 2.16 60ft) in my ZE KE70 panelvan, running 16psi, but with a damaged big port head that was limited to 6000rpm. I was getting like 30 or 40km/h out of first.
Persons with post amount under 100 will go into the non members section, If you hit 100 post and i havent moved it yet PM me.
ke30 ca18det, i ran 14.127 at 100 mph with a 2.3 sec 60 foot(only raced on 185 14's and 9 psi boost). might be racing again this weekend hoping for about a 13.6 on 14psi. might even run my slicks instead of cheese cutters.
new times
ca18 ke30 std turbo and computer, 10psi boost, 185/14 white walls, 13.87 at 101 31/01/07 (have slip)
te cortina std motor + turbo 13.34 at 103 27/01/07 (have slip) plenty more to come from this one yet.
Well, Finally hit the strip in my Twinky last night!
Ran a best of [email protected]! I'm pretty bloody happy with that! Should get into the 15s as my reaction time was a crap 1.040... bugger!
Still, not bad for a NA wrong wheel drive rolla!
Jarrad
Reaction don't matter, What was your 60ft like.
Pretty slow, 2.552secs. But on the other hand its not going to get much better than that! I was running against RTHY who ran a [email protected] with a badly slipping clutch, he rad a 2.515 60ft time.
Still, I should be able to dip into the 15's, my next fastest run was a 16.48 but heat soak killed the rest of my runs, they were all around the 16.6 mark.
Just uploaded the run to youtube... not the best vid but good enough!
Edited by TheNOBBLER
:D :) lost the top spot !!!! spewn!
oh well 0.2 of a second to take off and I haven't done a quarter pass with the new turbo yet, probably won't be until tassie nats in march!!
reckon its pretty safe to say i'll be nudging mid 15's though!! :P
My Ke70 will be taking number 1 when i cut her loose, Just a matter of time ladies :cool:
Still corolla powered though so it doesnt come under the crossbreed section, Maybe a revision of the catergories is needed ?
Edited by AE70
Revised.
