Trev's Ae71 Sedan Turbo Project
  • Replies 233
  • Views 91.9k
Went to court today, I get my license back in January so I'm not in a hurry to finish it, 6 months to go....
Edited by Trev
HKS adjustable cam gears and belt will be here around the 9th of August.
Today I went and got the waterpump and rear housing, Not much RWD stuff needed now.
It doesnt matter where it sits, but is the offset different? I was under the impression they were the same.
I thought i'd get a pic just to show the difference between the FWD and RWD pumps:
This is because the RWD setup runs the cooling fan.
Edited by Trev
Forgot to get a pic with the pulley on the pump:
Cheers trev, they are quite different arent they.
Yeah they are,
I spoke to Terry from road and track when he came around yesterday and i have decided that i am just going to buy a brand new AE86 harmonic balancer instead of going lightweight for the crank.
Yeah but its still a 4wd!! lower it already trev
( thanks for all the help today too )
I know, Suspension aint a big thing right now...
No worries, With all the 4AGE parts i have i wasn't worried :n:
I have been looking at HKS cams with a low profile as i cbf usin a set of bigport cams in it but now I'm thinking about going all the way and getting a set of the HKS 272 degree 8.1mm lift cams and valve springs, Anyone used these in a GE before?
I have all ways been told that big lift and duration cams are bad for forced induction ?
And blown V8's run stock cams.....
No worries, With all the 4AGE parts i have i wasn't worried :D
So... if you get the HKS cams will you have a set of unused, unrequired bigport cams? :o
Nah i will have a set of GZE cams spare, I just didnt wanna use a set of bigport cams as i will be usin them both.
