Ke70 5K Build
  • Replies 361
  • Views 127.1k
the tech of 35 years at work said his seen truck blocks crack from oil in the headbolt threads (mind you this is torque of 650nm)
Yeh it's pretty easy to do, oil is incompressible and when your putting plenty of torque on (you won't need 650nm either) you are pressurising that oil to an extreme. That's the beauty of bolts, the insane amount of mechanical advantage you get. google Pascals Law.
Also, a lot of older blocks are Cast Iron which is isn't too good with Tensile forces.
  • 4 weeks later...
Ok i'm back, is there any way to get the pistons back into the block without having the proper tool?
^ ^ ^ Into the dodgy mods thread!! :D
Cheap, crude and effective!
Yeh that's a bloody good tip, but mind you if you shop around it's only 15 bucks for a ring compressor anyway.
The worst is when you're doing a motorbike or similar and you have to drop the cylinder sleeve over the piston, you need a compressor that can split.
Or lots of practice with your fingers....
ok i have a compressor, do i coat the rings and the sides of the pistons in engine oil?
Hi Anastasios.
I think that you would give them a light coat of oil.
Don't you have a workshop manual?
I would never even attempt a job like this without at least a Gregories.
W.
Why use a manual when you have a Rollaclub?
I think it's brilliant that you have the desire and patience to do this all yourself, I would have cracked it and bought another engine by now..... But I'm hopeless.... :dance:
Top work, keep it up...... And a +1 for condensing this thread into a tech article.....
Its probably better off being turned into ana's projects thread. If you want this to be the case (when your engine is 100% and running) just shoot me a PM and I'll move into the appropiate area and you can re-title it. :dance:
Haha yea I think that would be a good idea! Heres a pic of the machined pistons, atm I am waiting to get paid so I can go buy another headgasket etc and get this running. I went and bought a piston ring tool as well, so if anyone needs to borrow one in the Sydney area let me know.
Edited by anastasios
I payed something like 30 or so bucks for it from supercheap, its not the best quality and took a few times to get each one in, but hey they are in.
Hey guys what torque settings do you use for the oil pan nuts?
My original manual says:
Oil pan x Cylinder block Standard bolt 0.2-0.4 kg-m 18-34 in.lb
Step bolt 0.3-0.7 kg-m 27-60 in.lb
Cheers, W.
Edited by woteva
