Evski's Re55 22R Goodness
Evan G
i scored this one off ebay for $650, picked it up from albury (boarder of nsw/melb). since i couldnt find anyone to tow it back on a tralier i decided to drive it back sad.gif, it was a 3 hour drive each way.
i loaded the car with almost all my tools from work. spare dissy/fuel pump/carby/tyre Just incase.. what a waste of time that was. drove it back didnt break down! but then again it is s a corolla smile.gif
some pics
post-8435-1270887654_thumb.jpgpost-8435-1270887746_thumb.jpgpost-8435-1270887786_thumb.jpgpost-8435-1270887838_thumb.jpgpost-8435-1270887889_thumb.jpg post-8435-1270888032_thumb.jpg
as the story goes from the seller
he bought it off a 16 year old girl who was learning to drive in her back yard, so she painted the car in pink house paint!
so the seller bought it off of her. sanded it all back and painted it in 2pak. he painted it and bought a bombadoor and lost intrest
200 something on the clock.
5 speed manual
blows a bit of some on start up
noisy thrust & input bearings
stripped thread on the sump plug!
over spray everywere
and most of all square head lights
plans
convert to round headlights
Granny spec no stupid mods
engine rebuild
tigh 113 cam
carby rebuild
fit my electric dissy
respray the engine bay
fix up the over spray
replace input shaft bearing and new hd exedy clutch
swap the a/c over to this car
swap dashpad/cluster
door/boot rubber kit
throw the sedan rear lights as far as possible and swap to normall ke55 lights
swap windscreens
and hid kit
then rego and roll'n
Edited by Evan G
  • Upvote 1
  • Downvote 1
plans
engine rebuild
tigh 113 cam
carby rebuild
swap windscreens
and hid kit
i think thats it :(
Where are you sourcing your door and boot rubber kit?
Nice buy Evan, try (phils aus rotaries on ebay) for rubbers on the ke55. So whats the go with the repaired ke55? scraping it etc?
$170 for all weatherstrips (incl windscreens)
i got one month rego left on repaired 55, strip it, transfer all the parts to new 55, cut rear gaurds out and most usual spots for rust and keep them as patch panels
  • Upvote 1
  • Downvote 1
11.04.2010
ripped the engine & g/b out
previously a auto? looks like it!
headed down to bamboo's to pick up my 14's. had a good chat/look over his cars :bash:
thanks bamboo for the rims and letting me borrow your timing light :yes:
12.04.2010
got a carby kit from MBL carburettors in reservoir, told the owner i mite be putting a cam in it gave me a couple of extra jets and for $40 can't complain
stripped the engine in a hour :bash:, found alot of metal on the bottom of the sump, what does the carbon build up around the valves mean? (i found valve saver in the glow box?)
post-8435-1271066585_thumb.jpgpost-8435-1271066349_thumb.jpgpost-8435-1271066392_thumb.jpg
cracked manifold? all the bolts for the manifolds were loose!
gonna throw the gearbox in the hot wash at work tomorrow, order the input shaft bearing/input/output seal
Edited by Evan G
