Evski's Re55 22R Goodness
post-8435-1273135312_thumb.jpgpost-8435-1273135412_thumb.jpgpost-8435-1273135459_thumb.jpgpost-8435-1273135497_thumb.jpg
red makes it go faster :jamie:
Granny spec much?
my longgggg overrated rear bar
  • Replies 398
  • Views 244.2k
  • ill think of one soon :(     probs from the Taiwan seller on ebay
  • $170 for all weatherstrips (incl windscreens)   i got one month rego left on repaired 55, strip it, transfer all the parts to new 55, cut rear gaurds out and most usual spots for rust and keep them
  • Hahahaha but Hendo was Dfunkt's apprentice.lol.   Stu.
hello how f@$k are yah?
abit of a update. got every back from my machinist besides the head. hope fully head will be done by tomorrow arvo.
machinist was giving it a bit of a headjob and he was surprised how much casting was protruding inside of the ports.
crank is in, rear main is on. hopefully by tomorrow pistons/timing chain on
anyways if i get my head back before friday, fingers cross will be back together and in the car by late monday night...
check how much they had to shave off my rods to get them balanced :)
forgot to add.
Ive swapped the dash over and a/c evaporator, swapped those gay ass tail lights. started making gauge pods to fill the gap were the previous butcher cut a massive hole and put a stereo there that doesn't work....
a little update...... nah joking ;) HUGE UPDATE
engine in
gearbox in
tailshaft in
to do list
  • fill gearbox oil
  • install radiator/engine fan
  • put the wiring back in
  • replace front windscreen
  • replace front and rear window seals
  • change shocks over
  • put door trim on
  • install my tachometer & custom made gauge holder in dash
  • fit new relay for tacho meter/ water temp/ oil pressure
  • run in engine
  • check vale clearances/re torque head bolts
  • change oil
  • RWC!
casting removed from intake ports (apparently alot of casting my machinist said)
the head bolts i was gonna reuse untill i remembered another member who snapped one before, i had to steal 5 from my other engine
sexy
the only way i can under the car.. :dance: alot safer than jack stands
peace out A town
Edited by Evan G
good work evan.... should be a good daily, once you rwc it u going to modify it more u keep it stockish??
Looking good Evan. :jamie:
.....however did you heat-wrap the stock cast ex manifold? :jamie:
And why!? :jamie:
Bloody hell I wish I was up to this stage on my car, though. Marvelous job mate!
thanks people for the kind works.
rod - my plans are granny spec.
Altezzaclub - I'm in $1500 debt and sick of spending cash i don't have :jamie:
taz_rx - why not :jamie:
Because it can crystalise and crack the metal.
Never personally seen it but been told it deffinetly can happen. Hit up the googles. :jamie:
i think its in the engines best interest that he destroys that standard manifold.
so he can throw it out!!!! and put some extractors on!
car is looking real good evan g, good to see a nice clean build.
ahahahhaah ke70dave got me in some tears :jamie:
if it cracks meh
the 25+yr old ex manifold should hold up with the heat wrap it is toyota after all lol.... when it cracks is anyones guess.....
you should of seen the old exhaust manifold. had a thick crack all the way along the hotbox. as soon i took those 3 bolts off a big chunk just fell out LOL
