Did you run around it three times clutching a dead chicken and reciting Macbeth?
Bwahahaha, funniest thing I've read all night.
Coils packs wired properly?
Updates have been at a low lately, i am sorry.
To be honest, that is because there are no updates.
Work on the car over the last month has been virtual nil, Both Justin and myself have had other calls of life to extend to.
The car now has 20.1 Kms on the clock. Justin put a few more on it.. the fault did not play up for him, but even though the motor was driven up to temp around the yard; i still feel as if there was insufficient load against the motor to properly re-invent the fault as per the previous test drives conditions.
I have a fuel pressure gauge set to go on the motor, and a few tricks up my sleeve after talking to many mechanics and techies.
Either next weekend, or the weekend after - the blue car leaves the shed, and comes home to my place where the end of its journey will be completed.
That car has spent a 1/5 of its life inside.. i need to build some sort of structure to ensure that that figure stays & improves :D No way on my mothers dead body will that car be left a) outside b) on the street.
Pictures will be posted when the car is cleaned again, before its goodbye from the big green shed.
Matt
