I'm sorry but this has been shitting me.
There is no word in the English dictionary that is "Yous", only "Ewes". Stop it or I will roll up a newspaper and clip you with it.
If you're going to be pretentious and obnoxious to other Rollaclub members, at least use the correct grammar and English skills.
Edited by mhmills
  • Upvote 1
  • Downvote 1
Wouldn't "You's" be the shortening of You is.. Due the appostrophe placement, which isn't a grammatically correct term thus redundant?
Either way this thread makes me lol..
Thats a nasty looking turbo setup! but it matches the rest of the car
Yep, this vehicle makes ghetto look good.
So lets look at the facts:
Others HAVE had more power through the same clutch kit...... including more torque.....
No oil on it....
You say the FW was machined.....
And you say it was properly adjusted....
.....Oh, and I'd love a photo of the CAMS officials face when he sees that exhaust! :thumbsup:
Send me a copy of the photo too please? Unless he doesn't plan on competing in a CAMS sanctioned event, then I guess it doesn't matter as long as it passes scrutineering? If the scrutineering at Winton is like that at Heathcote, he'll cruise through. :lol:
The cover was hot pink but the heat ʞ©$ɟe the paint and I bought a whole kit there's a pic of it new in the thread somewhere it was like $450 and boxes and duffs break from shock loading,when you have heaps of power the clutch slips if you don't shock load. Slo, you have some custom clutch no? And I dunno or care how much power and torque ou have but if the clutch is the same then you must have less of something. I don't think any of yous understand how much more torque E85 makes also the engine takes 5degree of more spark compared to avgas also it's oxygenated and at the end of the day the shit works good enough to slip clutches!
Okay, I'm skeptical as to what pressure plate has been used, sure there may be a pic of a new one somewhere but the one pic of the PP straight off the flywheel as you've shown it does not appear to have any trace of the original coating left. I've seen quite a few chewed Exedy clutches from cars (including track-used cars) making over 3x the power of yours & none exhibited the colouring etc that yours does. I've also never seen a flywheel machining job that looked like yours.
Random question concerning 'oxygenated' fuels....if there really is 'extra' oxygen dissolved in the fuel, in a given volume of fuel, does this not displace hydrocarbons that are used for the big bang? Therefore reducing the power of said bang as less hydrocarbons are burning? Pretty sure a motor can get enough oxygen via the intake...
More the point that other stock parts will break before even a stock clutch begins to slip...
^^^ This.
Well clearly they don't, and it prob won't break a stock box on 175's and I have spare boxes so I can change a box in 40mins between sessions if I have too
As a former KE70 owner, I beg to differ.
The point is, why change broken things if you don't have to? There's 40 minutes you could've been on the track going for a new slide angle/arse-backwards-exit record. Forsee the problems & fix them before they become a problem seems a better way to to go about things.
iPhone makes its own weird words
No it doesn't, it makes selections from its pre-programmed database.
I'm with mhmills on this one, 'yous' makes me think bogan.
Haha everyone's jealous that my car slips clutches ;)
I highly doubt people are jealous of you seeming to be acting so arrogant about causing mechanical damage to a perfectly good clutch plate, when there really shouldn't be a problem. Maybe if you dropped the attitude a touch, we can all nut out what the real/specific cause is/was?
  • Upvote 1
You gotta be kidding me Mitch....
I'd rather be out machining flywheels and destroying tyres than making excuses ;)
  • Upvote 3
  • Downvote 1
When the fuck are you cunts going to shut the fuck up and leave the kid alone, he is 17, most 17 year olds say stupid shit including you Evan which is why there used to be a page dedicated to you from which a lot of members here were a part of which was called 'EVAN G IS A TOTAL KNOBHEAD'
It is quite annoying to see you idiots carry n the way you do towards Mitch here and on facebook, this place really is the new boost cruising thanks to you fucks.
And for all the skeptics in here, the clutch setup has not been changed since the supercharged setup, there was no problems with it then so why don't you look at the fact that it is worn and the extra power ruined it completely.
Now shut the fuck up.
  • Upvote 4
  • Downvote 3
I haven't visited here since about page eight, and I don't have a lot of interest in being here now, but you are all behaving like children.
Guys, collectively pull your heads in (on both sides) and play nicely.
Wait... How did you say ʞ©$ɟ without it correcting?
E85... Tell me why it takes 30% more fuel over the whole map???? Cause it's oxygenated it's like having 20psi instead of 15 in a way also it takes 5DEFREES more spark timing everywhere compared to avgas so like 7-8 compared to 98. And it makes mental torque down low which none of yous have. Clearly no one here has played with it and knows what its capable of....... It practically methanol! Ad the cover changed color from mega heap when I was driving it and it was slipping I didn't care so I just kept going and going and going...
  • Upvote 1
Pay for membership.
Mitch, just give up.
