August 24, 201214 yr comment_622960 Ok, before you guy's start flaming me I'd like to explain myself. I'd like to take my car to a few track days and learn how really drive a car sideways in a safe environment. I'm from the northern suburbs of melbourne and the car ( RT142 corona) will be pulled off rego in a few weeks. I know welded diff's are dodgy and break easily but I'm not about to go and spend big bucks on 2 ways etc at this stage on a first year apprentice wage. I've researched the internet and asked around for people who can actually weld a diff and no luck so would any of you guys know of somebody that can weld my diff in melbourne? Report
August 24, 201214 yr comment_622962 Repost i know, but good for a laugh...DON'T DO THIS!!! Edited August 24, 201214 yr by Bowler Report
August 24, 201214 yr comment_622970 Just find a welding engineer, they should be able to weld anything. Plenty of guys specialise in welding steel more than 5mm thick, although I suppose that might be easier here in the country than the big smoke.. Report
August 24, 201214 yr comment_623008 actually, that wouldn't likely be the case. Welding material with such high carbon content isn't that common. Find an engine builder who does vintage engine work, they will have a preheat/postheat setup and the right rods because they will weld a lot of cast iron heads and blocks. where in melbourne are you, theres a guy in ringwood that i know has done a few Flathead fords and might be able to sort you out/ Ask around for someone who's done Cast Iron and you'll be fine. Report
August 24, 201214 yr comment_623013 An older guy down here, does them himself using tire weights. Melts them down and pours it in. They seem to hold up alright! Report
August 24, 201214 yr Author comment_623014 Philbey: I'm in coburg but I'd be happy to drive out to ringwood if he can do it. If possible can you PM me his number or would you be able to ask him if it's not too much trouble. In the meantime I'll be looking for welding engineers I may already know of one fingers crossed! Jono.C: I don't have the equipment to do something like that and I'm a fair distance from tasmania haha Edited August 24, 201214 yr by jordan101 Report
August 24, 201214 yr comment_623015 Repost i know, but good for a laugh...DON'T DO THIS!!! Hahah, Yeah nice Report
August 30, 201214 yr comment_624034 Mate welding diffs is piss easy if you know how to weld. Drop the crownwheel & carrier assembly out and give it to a boilermaker. Any engineering shop should be able to do it. Just give it to them complete and tell them it has to go back the same way it came apart, with no slag/splatter in the axle splines or the mating faces. once its done pull it apart again and religiulously clean everything and double check for splatter. If thats all good reassemble and fill with oil. then robert will be your mums sibling. Report
August 30, 201214 yr comment_624039 the only diff i have been involved with was welded in the back yard of some guys house for a 6 pack with a stick welder and a few random bolts thrown in for good measure. was in my mates ca18det 86. dropped it off in the morning, picked it up 3hrs later, and one hell of a mess was present inside. being the inteligent mechanically minded people, we just threw the centre back in and hoped for the best. but damn it never gave up the ghost, took some abuse that diff. Report
August 30, 201214 yr comment_624043 Buy a spool? Drop the centre out, take it and the spool somewhere and ask them to chuck it in for you. Report
August 30, 201214 yr comment_624088 Yeh these guys make good points; no need to apply a bunch of science to a dodgy bit of work anyway.... I suppose the better it's done, with pre and post heating, the less likely it will explode. But jam enough junk in there it won't matter anyway, it'll be your axles that snap. For interest sake, the joint was Speed Works on Molan St Ringwood. Report
August 30, 201214 yr comment_624117 Any one with even the smallest clue could weld a diff, its pretty much a plug weld, take it to any fab shop and they should have it done it 10mins provided you cleaned it beforehand Report
August 30, 201214 yr comment_624156 Your worry should be the fact the diff gears are carbon steel so it's not as easy as getting your mate Bazza and his $300 piece of shit inverter and just packing the ʇ~~ɔ up with filler rod, but the blokes on here make a good point, no need to put so much science into a dodgy job anyways,my advice is find an engineer shop with welders that have experience in welding cast like the dude above me mentioned...if the dudes in the shop look real old you should be right hahahah or just don't stress and throw ur mate Bazza half a slab hahahah it'll hold up for long enough that's my $0.02 anyways.. Report
