Taz_Rx
    6796
    54
Everything posted by Taz_Rx
  1. Don't want spool?
  2. http://m.ebay.com.au/itm/Intercooler-front-mount-mx6-corolla-/262853181985?hash=item3d33454221%3Ag%3A63oAAOSwHMJYGYHO&_trkparms=pageci%253A587699b4-f582-11e6-a882-74dbd18008c2%257Cparentrq%253A4f0f481e15a0a622861069aefff4324d%257Ciid%253A3
  3. Maybe seek untubbed_20's input on that. Without adequate bracing and maybe still with, its a lot of weight and leverage hanging off the exhaust manifold. You could try and find an mx6 cooler like mine rather than some wanky cross flow aftermarket thing.
  4. Didn't know 10's had the battery on the drivers side. Leaves a nice void behind the passenger side headlight.....
  5. I've got a coffee jar lid over the top of my custom cas as well.
  6. What happened to the infection setup?
  7. GM maybe? Got pics?
  8. Did you look on the tyres themselves for a recommended inflation?
  9. Fair enough, thats lighter than I would have guessed. I only mentioned as I once helped a mate dynamat his car audio demo vito. We were rather surprised how much a sheet about the size of a4 would deaden a while roof panel. It's great stuff. Have you ever seen the demo display some shops have with 2 metal garbage bins with subs in them. 1 with and 1 without dynamat?
  10. ....or wind the window down.
  11. You don't need to go too crazy with dynamat. Probably half as much on the roof there would have had the same effect, which also helps with not adding as much weight. Interested to see your hydrographics too!
  12. Re the cas, you could always try retro fitting the guts from say an rb cas into a bmw dizzy as I did with sr20 into k!
  13. From memory my start add on is only about 10ms. 70 is huge!
  14. Carter's are self priming
  15. Water outlet in the manifold mounting face for water cooled inlet manifold.
  16. Reversing the leaves is just stupid. You would be better off just solid mounting the diff as the leaves won't work upside down.
  17. Fyi shifters aren't interchangeable
  18. No pretty well interchangeable apart from solid vs hydro
  19. Have you still got the r31 calipers? I was looking at them to do a disc upgrade on my t series.
  20. You don't need brand new ones, just get your old ones refaced
  21. Hmmm, do you think this might have something to do with the noise in the back end!?....
  22. I'm 99% sure you can, but can't confirm now cause I sold off all my w bits. Stu (tommys dad) could probably confirm as they're going to put a w50 in his 20.... using my old bell housing pictured.
  23. Totally wrong. .... vacuum advance is pretty much only for idle and light throttle driving. As you rev the motor and open the butterflies you lose vacuum, at what you essentially shouldn't have any!
  24. Start a projects thread and show us! Did you use a 7ke manifold?
