Taz_Rx
    6796
    54
Everything posted by Taz_Rx
  1. :laff: Did you get the prices for those 2x around the wrong way!?
  2. Also not sure if its the same in other states, but I think we have a rule that if you tint the front windows dark you have to have a passenger side mirror. :laff:
  3. Try opening the points gap up a bit. Is the coil you're using a resistor type coil(like a GT40R)? If so you need to wire in a ballast resistor, OR run a non-resistor type coil. Either way it should cause your problem, but like Dave said its deffinately not good for your coil.
  4. MPH probably won't change much. I'm hoping that I will be able to knock some time off the ET though as I'd like to have an LSD in the T series. I think the peg-legging was the biggest draw back last time.
  5. Probably the timing. Give it a shimmy and get back to us if its still doing it. :)
  6. Remove the lower section of seat Undo 2x bolts at the bottom of the back rest Then push UP on the backrest - There's a couple of plastic clips that hold it in at the top Yes 30/55 4 door seats are interchangable. Not sure about KE35's
  7. None of those are diff bearings! They're all front hub (inner and outer) bearings or rear axle bearings. As you would know they diff bearings are conicle like the front ones.
  8. Theres another on ebay at the mo if you still want one wpn.... http://cgi.ebay.com.au/malpassi-fuel-regul...=item20b1fc72ac Although you'll probably just need an EFI one yeah?
  9. The last outing was the last round for the 09/10 season. 10/11 season start on the 22nd of August with a test and tune and then the first round is 18th of Sep. I really want to get my T series in before going out again so that'll be the deciding factor as to when I next get out.
  10. Taz_Rx
    Done
    Yeah pretty much all toyota speedo are the same until they started using electronic senders. The ratio of the speedo drive probably won't be correct though.
  11. You sure the different part number aren't for maybe main CW bearings, and then the pinion bearings as well?
  12. This is pretty cool......
  13. Yeah I already klnew, SLW was PM question about the fuel reg. So you're selling him the ebay turbo kit?
  14. For a first offence I would. Considering how many times this guy has had threads locked I thought it was time for some public humiliation.
  15. I'm not repeating myself for you. Re-read my first reply to you. So tell me, why did you want to know if you can put a 7k head on a 3k? http://www.rollaclub.com/board/index.php?showtopic=41645
  16. No you haven't...... you just asked ALL RC members when you start another pointless thread like "will a 7k head fit on a 3k".
  17. Fords suck! :P
  18. Evan - Open a google page, type in "where is chuck norris" and then click "i'm felling lucky". :P
  19. Couple of different ways: 3kbp's have an o-ring around the top of the valve stem as a stem seal. 4k's have a much nicer seal which clips onto the top of the valve stem guide. Also the top valve retainers are the easiest way to pick them. The 3kbp ones curl around the top of the spring a bit and down the sides slightly as seen in below pic (bottom head). You can't see the 4k ones all that well but the top retainer is flat and doesn't curl around the side of the spring.
  20. Did said KE70 also have an SR20 or CA18 in it? They probably put the dash in aswell to make all the guages work easily. Agree XE7X dashes are ugly. You've never pulled a whole dash out hey? Removing them isn't too bad, but trying to put a whole dash back in is a bitch. Now you want to try and modify one dash to fit in another car...... that just sounds like a nightmare to me!!! :P You can make the 30/55 dashes look pretty good with a bit of handy work. This is my dash in Tar.....
  21. Because you constantly start pointless, well covered questions, normally about heads and how you're trying to cheat your way to winning. Except it - You need to use a 3k for speedway...... that included the 3k head. So stop asking RC members to effectively help you cheat. I think I speak for all of the admin/mods (including the "f@$k stain" who locked your thread yesterday) when I say we're sick of your shit. Shape up or ship out. :P
  22. I'm pretty sure the whole dropping a piano on a marina thing is from and old movie. Hopefully one of the old(er) farts here can tell us what movie?
  23. Oh well you've got another $1000 to plow into now I suppose! :(
  24. 5k lifters have a bigger diametre so you can't use 3k ones for a 5k solid conversion.
  25. They'd probably just say "whats your problem? Jeremy has already stated that corollas don't have souls!" :(
