Figjam14
Everything posted by Figjam14
  1. probaly worth a shot, trying a different coil, i got a msd one( was around 200) and it free revs fine but as soon as its on the dyno breaks down and shit after 5000, a mate of ours had the same problem with a datto
  2. undo the engine mounts and gearbox crossmember and jack them both up as high at you can? my need to undo your exahust to
  3. reminds of me xa couope alot
  4. did u get your flywheel shaved down alot? because what can happen is when that happens you will need to space the trust bearing out abit.
  5. good on ya trev.
  6. bore out to 60th, shave head until 12:1 compression, bigger cam, extractors, weber if your allowed, port and polish head, bigger valves and springs, fully balance motor, deck block and yeaaah
  7. inside is soo miint man
  8. Figjam14 replied to herbie44's topic in Rollaclub Rides
    yeah still got 4k
  9. you can make anything fit;)
  10. did u check the timing? if advanced to much it can blow them. i don't one last week like that. also make sure when u tension you don't use any extensions.
  11. get a decent 4k for 100ish and gbox around another 100-150
  12. tbh i have never heard of anyone running them in a ke road car.. i run them in my speedway car but we move the radiators into the rear.. i just tried a spare one into a corlla we have and fits fine? just need to remove the fan at a guess and put in electric
  13. whats the plans for the radiator?... you can buy new vn ones for around 200?
  14. i use some sort of commadore spring? think its maybe vn.. not sure
  15. About the jets on the 4k carbie, it would be best to go and buy some jet drill bits.. only up your secondary jet because if you up your primary it can flood the car easy.. just drill it out a tiny bit each time, take it for a drive then check the plugs (you wont your plugs to be a tiny bit darker then a a creamy colour), and just keep doing that until they look good.
  16. deffantly worth it :)
  17. gimmie haha, gone over budget yet?
  18. you sir have just changed my mind about ke70s ;) ;) ;)
  19. i would guess so, i can put ke70 struts in my 55?
  20. in my speedway car when we were starting( we start 1st then snap 2nd) i missed the gear and went upto 12000rpm and thats as high as the tacho goes....
