Everything posted by Trev
4Agze Map Or Afm?
You got the engine home yet?
4Agze Map Or Afm?
No I am saying that I didn't realise that the bigport also came as a DLI ignition with an AFM, going by what you have, yours will be a bigport from a AE92 GTZ Levin so the ecu will be correct. Sorry for the head ʞ©$ɟ.
4Agze Map Or Afm?
You must have been typing before I edited.
4Agze Map Or Afm?
I just found some info that states that the bigport also came as an AFM dli in the GTZ levin, yours will be this.
4Agze Map Or Afm?
Considering that they said DLI bigport, I am fairly sure you know your answer, do a google.
- 4Agze Map Or Afm?
Trev's 1990 Fzr250rr (yamaha)
Yeah one day when I have this back together or I steal my mates.
- 4Age In To Ke70?.......
Freight Company In Brisbane?
NQX is fairly cheap.
- Trev's Hks Blown Ae71 Spirit
4Age Intermittent Starting Issues.
You got the timing light pickup going the right way? You working off the timing cover marks?
How much you reckon it is out?
Dizzy has a notch and dot on the shaft that you line up.
Take the dizzy out and rotate it one tooth clockwise, line up the crankshaft to oil pump dot, make a new mark on the pulley at zero to the timing marks and recheck it all.
- Ke70 Tyre Hits Caster-Rod At Full Lock, Help!!!!!
Random Photo Thread
Hard Brakes
You can use what you want but I will use what is on the cap and always will but I was taught that by proper workshops. Oh and look, another brake fluid spec that states the same. This has recently been proven which is why they didn't go through with the phase out of DOT 3 fluids and which is why it is more common to see it on shelves now than what it ever has.
Torana Xu1 Rear Boot Spoiler Will It Fit
Here is one I prepared earlier :P http://www.rollaclub.com/board/topic/14788-trevs-ae71-panelvan-na-bigport/page__st__45#entry198839
