Trev
Donor
    6398
    29
Everything posted by Trev
  1. LOL, you pay for something that won't munch itself with the torque output of the engine but in saying that, the 33 ate the old dog box that was in it.
  2. Want another? http://www.gumtree.com.au/s-ad/morayfield/cars/1964-cadillac-coupe-deville/1006266206
  3. 2009 I think but I still keep in contact with them.
  4. If you do happen to need something from road and track, tell them that Trev that used to work there sent you and they will probably look after you a bit better.
  5. I believe it was a vertex off of an ae86.
  6. Looks like it is running normal.
  7. Nah it's an SX11.
  8. Thanks Matt, yeah I thought it might have. Yeah the turbo setup I got for my old 71 took 3 month to arrive. Hoping that it will still be around my original quote since I am going with sea: Dear Trevor, This email is to notify you of an update to your order. The change to your order is: Order update for item HKS BLOWER (18430) Japanese Domestic Freight confirmed at 3,150¥ This results in a saving of $-11.69 --> Order total changed from $1,154.53 to $1,142.84 Balance changed from $-154.53 to -142.84
  9. So did I, read post 46.
  10. Got an email today saying that shipment from Japan to Oz will be another $276 (air) so I have asked them to send it via sea which will take approx 6 weeks and then how ever long it takes from Victoria to me.
  11. Do you have the emissions label under the bonnet? I can look at my 4ac 82 tomorrow arv and let you know where it goes.
  12. That's a nice unit you got there.
  13. When does it knock? Cornering, bumps etc.
  14. Yes, so you wanna use the smallport CAS and coil setup?
  15. Trev
    Maxi
    Hey I only wanted to come sit in your rain forest and watch you :P
  16. Such an aggressive look front on.
  17. Cheers Stu
  18. Yeah I want to be able to have a nice comfy car for the whole family for cruises etc but I want it to be mine. I put up the wanted ad as I had tried yahoo Japan etc (search items can be hard though) and carbonboy said about importmonster so I typed it into there and one came up, it ended up costing me $1148 once postage and fees were added which I think is quite good. I just hope it gets here soon and I can sort out a top water outlet to suit the blower since you end up with this much room:
  19. Stick it PPQ and TMR and they will give you what you want :)
  20. I haven't actually changed an E7 ball joint but every other was press out and in in the hydraulic press. All I remember from doing my struts was undoing the 2 lower strut bolts, removing the ball joint nut and then the tie rod end nut and changing the arms over and then the struts.
  21. Oh sorry man, I didn't realise you were actually changing the ball joints aswell, they will be a press in.
  22. Buy a good hammer, only time I have ever had to use a pitman arm puller was to, well, remove a pitman arm. Give the steering arm a whack on the edge around the joint (with the nut loosened off) and it should pop out.
  23. Trev
    Maxi
    Remember that you can ask me over any time :)
