Trev
Donor
    6398
    29
Everything posted by Trev
  1. Its more than likely coming from your PCV valve due to blowby, Stick a catch can on it if its too much.
  2. Ok, I played postal 2 years when it was released in the US and my mate got a torrent download before they shut it down and i have been wondering what the game was called until i found it the other day so i downloaded the postal 2 demo and then the postal 2 share the pain full game and i wanted to know what the other games in the series were like.
  3. My 4agte project has a A40 3 speed auto (standard AE71 auto) which will be getting kitted and a stally but I'm only aiming for around 200rwhp, I don't see how the auto wont be able to handle what your aiming for if you get it kitted as it should hold together. EDIT: You will also have to get a flexplate from a 20v or another 4age as we don't have the 6 bolt 4age.
  4. Hey, Just wanna know if anyone has or has played anything from the postal series at all?
  5. Ha Cam, Yours is far from original now :y: Nice collection there Gav, How many you got all up now?
  6. Trev
    Des' Twincam.
    Id use VHT cause thats the only brand i know that does decent hi temp paints and so on.
  7. Thats a nice tidy looking dash and will go a treat in the wagon.
  8. Found this on twincam.org:
  9. 4 = Four It's one of those WTF plates.
  10. Slim (4ages) came around yesterday and we were looking over a few things and on closer inspection i realised that the bonnet support just wont work due to the lack of space so I'm just gonna put up with it.
  11. Plates arrived today:
  12. Trev
    Des' Twincam.
    Hurry up and bring it around as i wanna see what a freshend up GE is like.
  13. Trev
    Des' Twincam.
    Other than that is it good to drive?
  14. Its definately fish eyes which is mostly caused by silicone, oil & water, It can also be caused from leaving wax and grease remover on too long, I don't know why its coming out a few hours later but i did a paint job where it came out when we finished the car (paint place was selling thinned paint and we werent aware so my mate mixed it up with thinners, It still had a good consistency), Do you have a water seperator on the compressor? Thats all i can say as its not my field, Good luck.
  15. Just gimme one of the HR31's and i will be happy.
  16. If you want. This is one of the other things i am working on and i decided how i should do it today and made a quick sketch is an adjustable rear bonnet support as no matter how many times you shim the bonnet it still hits the wipers, My 1st thought was to make it short/long adjustable like a panhard rod but realised that it would put too much stress on the hinges or start to bend them so i came up with this one: It will sit between the bolts and the hinge so the bonnet still sits flush, The adjuster will just be a bolt with a rubber cap on it that will push the bonnet up, The length of the support will just be matched to the spacing of the holes as they are now.
  17. Being 2pak you are baking it arent you?
  18. Sounds exactly like silicone, Give silicone drops a go, My brother is a qualified panel beater so i could ask him if you want.
  19. The ae71 starter i have looks nothing like the one on the right but the one in the ae82 seca looks similar, Both are 4ac autos.
  20. Started on the proper CAI setup today, It should perform very well and make a decent sound, I also no longer have the standard water trap but will modify the intake plate i am making to have an auto drain in it, PICS - Water seperator: Now a straight forward intake: Rough sketch of how it will sit on the guard, You have the opening, The outer part of the duct and then the part that will be cut out: My daughter took a pic while i was mucking around with it so i thought id post it: The duct/scoop I'm trying to get is similar to the XW GT SMALL - FBS44: The intake plate will look something like this: And it will be attached to the intake with a pipe clamp and will seal up against the guard with some window or door rubber.
  21. Ok, I thought you were asking what it was in general not what corolla it was off, Just looks alot like a a VB-K 6cyl starter but i also don't have one infront of me to look at.
  22. Looks like a holden starter.
  23. Can i just ask why the dellortos would breach the ADR rules? I know its a rides thread but id like info as i will be running twin 40mm dcoe's webbers on a 4age.
  24. Let us know when its fitted, How do you go about using the vented one as i looked at getting one a while back but understand they wouldnt be ADR approved?
  25. Do you know what the ring gear size is, I have a listing and for the TE7#'s listed it has T Banjo (including LSD) and 4 pinion S Banjo, If you can get that ring gear size i may be able to help out more without the ID tag code.
