towe001
Senior Member
    2563
    10
Everything posted by towe001
  1. Can't really help you all that much with the rims. http://www.outerlimits4x4.com/ might have a better idea But thats pretty nuts what you've done with the struts.
  2. Action shots are good. Whats your thoughts on the fender mirrors ? Any good or bit of a pain in the arse to use ?
  3. Axle Code Translator Pretty basic really - just plug in your diff code letter and three numbers and it spits back the crown wheel diameter, final drive (gear ratio) and what the centre is Can also click on the link at the bottom of the calculation "Calculate gearing for this axle", there's not really much choice in gearboxes but the ratios can be fiddled with so that the Speedo drive gear can be worked out and also the rpm to road speed can be worked out. Home page for the site - http://akb.norbie.net/Default.aspx
  4. Yeah i'm fairly sure its been done a few times but i just can't be bother searching for it
  5. Not a complaint or anything. But i'd sooner use an analog display (read as a needle display like the speedo) over a digital read out display cause in the heat of the moment remembering what the "safe" numbers are on the digital can be forgotten whereas if the analog is set with the needle pointing up at its "safe" position and a glance at the gauge will quickly and easily show any problems. The same can be said for the oil pressure sender - run a T-piece so that both pressure senders can be used. One for the gauge and the other for the light. The oil pressure light can catch the eye a lot quicker then the glance at the gauge when remembered. And one of the reasons for choosing electric over mechanical is that the sensor for the temp gauge is connected to the gauge and the pressure gauges (eg - oil, fuel) needs tubing running from what ever to the gauge and needs care to be taken for kinks, splits. Whereas electric its a simple matter of running a couple of wires. Dimmable lighting for the gauges - find out which side of the rheostat, thing for dimming the dash lights are on and splice in both wires for your gauge. More then likely will need the wiring diagram for the dash cause the ground (or negative) wires go through the rheostat. If its not done correctly the lights will either stay on , not come on or will not dim down and/or turn off when the dimmer knob is turned right down. Cheap gauge cover - depending on the size of the gauge but a tow ball cover is nice and cheap. Just make up the bracket from a couple of pieces of alloy, if needed. Good write up Evan :thumbsup:
  6. My new toy. 3 channels of indoor fun
  7. Really nice work from them. At least everything's back up and running like normal which is a good thing
  8. Hey Ben, did you put the forum down last night for maintenance ? Would it be possible to set up something that sends an email warning about it. I started getting withdrawals :thumbsup: and thinking the laptop had issues with me.....
  9. Not really any up dates apart from that i miss my little turtle :lol:
  10. Have another look my man, water temp, volts and oil pressure :P Id keep the car silver and maybe give it some black highlights
  11. TR-1B two seat trainer At the height it was flying it would of been traveling close to its top speed to stay afloat. And as 7shades said the pace car is there to tell the pilot the distance from the runway and at the correct height the pilot hits the stall speed and hits the tarmac. It was the only way for the pilots to land otherwise the "air cushion" will keep the plane up. Very awesome footage, thank Toy-Yoda :lol:
  12. I get the feeling the outside of this unit was made with midgets in mind I stand at 5'8" about 5'5" for this thing And yet the neighbors (holiday units as well, different complex) have a full height cloths line. Walked out of the unit turned right and almost face planted into the ac unit
  13. Bloody hell, and here i was thinking a service on the lancer from mitsubishi was a rip off
  14. Nice I like the fender mirrors Where'd you get them ?
  15. Everybody that got the '09 calender said just how good it was and not sending pictures, placing orders thats a real let down in the interest for the '10 edition people considering Jon had upped the ante for the '10 calender and we all knew it. And in a way if thats the response to the hard work that Jon put into the calendar..... I'd just keep it to the forum - not saying that the idea of a mag is a bad idea, i do like the idea more so on the tech articles etc that, say, i could print out or at least have a paper copy i could have next to me while stuffing around on the rolla I'll put my hand up for the ke30 one :lol:
  16. Yeah tell me about it. Hope she gets charged for it. But really i can't see why child welfare has to come into it cause there are worse "parents" out there and yet child welfare does nothing to help the kids nor the "parents"
  17. Almost feels like it. Didn't get the kids off to bed till about 9:30 - 10 and they'll be rampaging the unit again around 5:30. The heats annoying but at least the bunnies aren't bad :P
  18. From what i'm aware of is that the trimatic has a different output shaft whereas the A20 (? - two speed auto) shares the same output shaft pattern as the manual. Length of the tailshaft - i can't really quote on the length between the 2 speed auto and the manual, i'm yet to find out but i'd say it would be. But the shafts between the trimatic and the manual are the same
  19. Same as what everybody else said. And many thanks Mods to the top year
  20. Taken at 8:50pm I'm loving this daylight savings NOT
  21. But where as if your a half a carton pissed and shove your hand into a fire your thrown past the doors and into the ward... Completely different to the family with the 6 month old throwing up anything and everything and too weak to be able to even cry properly
  22. Don't know whats its like down south but up here its automatically covered in the power bill. Know how you feel with your mum, i'm the same with my dad. "Wacked out sports" or what ever its called pisses me off
  23. Urm, depends on which area your talking about with the curve. Before i did the speaker mounts i was test fitting the shelf into a ke55 that i had Its what i'm figuring on i'm also thinking that the ground wire has also been connected to a wire for the dash lights, they don't dim down at all.
  24. Turtle sitting in the driveway....." do me do me" So i did I did start the shelf when i got my old '55 but wound up cracking into other parts of the wreck along with what can be seen in the background. Anywhat, making up a bit of a list on things i want done after our trip south. Like the stereo - i've a feeling its been hooked up wrong, there's no memory (which i'd say there's no constant 12v) and every time the key gets flipped on the dash lights come on.... Also want to see if its got a thermostat. Takes a good while for it to heat up some days. Electronic ignition - be gone the points gap system Been scooting to work and back driving the turtle like a two speed manual at the moment. The shifter needs to be re-aligned but i'm not too worried at the moment. Thanks JiP, you've given me a sigh of relieve with the x-member. Went out and measured the lengths of the x-member to the end of bellhousing on both the fve speed and the auto and their both about the same - given i was looking at the measurement for the auto at an angle
  25. Most times if you get a written quote, its what they have to stick to. But yeah its happened to me, namely on the "unexpected things" I've learnt - ask for the old replaced parts And question why the heck did the 4age head gasket cost $350 for ??? Oh yes i'm pretty sure i still have the repair invoice floating around somewhere.
