towe001
Senior Member
    2563
    10
Everything posted by towe001
  1. I think it'd be easier to fit the engine x-member from the v8 powered vk commodore to the skyline in your pic.
  2. Wouldn't get your hopes up on the single cam and keep dreaming for the twincam version unless it was a private import or a tarted up 25
  3. Only the kids beds. My daughter has one of those old style mattresses with the buttons and the kirby just sucked up one of them. The lady was a little horrified about it but all i could do was wide eyed bewilderment and then start laughing about it. She even showed a vacuum powered sander and one of the attachments for it was a massage pad thing. Her comment to it was "there's more to it then just a foot massage." I'm positive she had a twinkle in her eyes when she said it.... What was with our bloody phones today.... nothing more then 30 minutes tops the damn thing would start ringing. And if the whoever couldn't get us that way it'd be the bloody mobiles. And i think the one reason why home break-ins are on the rise is that every man and its dog is about and on the town blocking up the roads... Had to do a bit of shopping and normally what would take us about 10 minutes to get to the shop took us, oh, only about 60 minutes.
  4. :wink: The chick that had us hooked on the thing was pretty good as well :wink:
  5. Take a notice of the scrap metal.... I've forgotten the name but from memory its putting a kink in the end of the sheet and punching a hole so that another piece can be spot welded to it
  6. Most times i'll just breeze through the write-ups and look at the pretty pictures. But, my man, the title, the lead up, the write-up, the pictures, just awesome :wink: But i had thought all of Europe were all right hook cars
  7. Not really a total gear grinder But i want my KIRBY, damn it
  8. The "X" is the motor - as in referral to the holden starfire. The "T" is the chassis code - for Corona and the "130" is the model version number
  9. Which leads to a..... http://www.youtube.com/watch?v=J5z4Vs26-TI
  10. If your going a multi coil setup (eg - commodore v6) then yes, but if your just running the plugs off the dizzy (be it either points, electronic or optical) and the one coil for the dizzy (eg - 4age) then no. Having a better look and i started thinking that they looked like Injection Perfection throttle bodies. But after having a google around http://www.injectionperfection.com.au/content/view/21/71/ I'm now thinking modified bike carbies - say, maybe, Harley ? And i kinda doubt the carbies being CNC machined. Looks like casting marks under the trumpets and why are the trumpets welded in ? Maybe CNC modified but not machined...
  11. KE30's and i think 55's came with two different diff's. The Jap style and Borg-Warner and the flanges are different. Which means you'll have two chooses either take it back and swap for the one you'll need or swap the ends over. Might be easier to take it back
  12. Nar not bidding, might keep an eye on it but not bidding. If i went EFI, i'd go quads or, there was someone on the forum that used one of those carby styled throttle body things that had the injectors mounted in it, so i was also thinking of something like that to start with. With a Megasquirt confuser. Phuck it looks good, but not as good as quads
  13. I'm not really sure what the carter pump looks like. But anywhat, when you go to mount it, bolt it down no rubber grommets or something rubber and thick to stop vibrations going through the car. Electrically, wire the switch side of the relay to the battery side of the coil - so that the pump doesn't run while the ignition is off. Fuel lines - pull the fuel line off the filter and find a bolt or something that can plug the hose so that when you go to cut the hose near the tank you'll have something that can plug the hose tank side of the pump. And connect the hose on the engine side of the pump first. And see about running a filter between the tank and the pump. Just use a clean ice cream container to catch the fuel spills
  14. Some people just don't get it :)
  15. Throw out bearing ?
  16. Eagle Boys
  17. Just had a look see at mine - Jul 20 2008, 10:59pm :y:
  18. Top idea :y: It'll help out the members that have little to no experience with freighting stuff Couriers Please - http://www.couriersplease.com.au/ Fastway - http://www.fastway.com.au/ Startrack Express - http://www.startrackexpress.com.au/ NQX - http://www.nqx.com.au/ Queensland based but does have interstate branches Toll Ipec - http://www.tollipec.com.au/ TNT - http://www.tnt.com/express/en_au/site/home.html Toll - http://www.toll.com.au/TollOnline/otherservices.html Toll Priority - https://priority.toll.com.au/ Followmont - http://www.followmont.com.au/ Queensland based Their the ones we deal with at work or at least the major players in transport and frieght Their are others we also deal with but their local based, like Garden City Couriers. And for us Followmont Transport is indirectly serviced - thats is we go though Garden City and they deliver to Followmont for us. But, yeah, it good to ring around and get quotes etc. Some, like, Fastway and Couriers Please have a maximum weight limit. Try the locals as well cause they might also have direct dealings with the major players which could drop the cost a little as well. Ask if they do a door to door service - some do some don't. And then there's some that'll drop off the goods off at another transport company for a "follow on". If they do a door to door find out how it'd done - not really all that good if your wanting to transport a motor or a diff if its going to be someone turning up in a little van... Some have a "I'm not really worried about doing it", whereas others...... Its the little things that are good to know. Like if your planning on freighting that windscreen then insurance or maybe, say, a fuel tank - some will want their arses covered and class it as a dangerous item and that'll mean the cost will sky rocket and if a spot check finds something undeclared....
  19. I like the idea of option 2 and then the poll By the way JiP your link in your siggie comes up as http://hhttp//www.rollaclub.com/board/?showtopic=32282=
  20. Don't worry as soon as i can thats what i'm doing. And with me on probation i don't really think i'll be there for too much longer but i'm not all that worried - money wise, yes... being there, no... being able to spend more time with my kids, plus... being able to hopefully get the house back up to shape, plus.
  21. Yeah tell me about it.... My other half is getting her resume up to date at the moment and start the hunt for work cause i'm up to my ears in this crap and wanting to get out of it so we're going to do a role swap. About a month back, one of the other guys there asked about taking time off cause his girlfriend was involved in an accident where she was t-boned to the drivers door - "What don't you care about your job?" And to think at one stage it was a really great place to work at. Sure the mornings for me were crap but i got over that and enjoyed the day but now....
  22. My work place is starting to turn into nothing more then a phucking joke - One of the girls is pregnant and this is her last week at work and her pay is getting cut cause she takes too long to do things AND she takes too many toilet breaks.
  23. Race horse
  24. And if the federal government is anything like what the Queensland government is like, they wont give a rats hairy brown ring hole to what their voters vote for unless its voting for what they want. Like, i'm all for the anti-net censorship we don't need it, don't want it but i'm not forking over my hard earned money for something the government will just push to the side cause its not in their interest not to have it. Just like the Queensland government - if they think its a good idea who cares what you have to say we're selling what ever to overseas, building a gigantic bog hole and putting a can on a grey water pipe line to the Lockyer Valley for the farmers
