22 -
2
Everything posted by KE70ph
Thanks man! Looks well here for now. Brought it on local shop for fenders and door alignment, minor body repairs and paint restoration. Rusted parts are removed and replaced by fabricated sheet metal.
Due to covid19 pandemic work are suspended here in the philippines, so i have to spend the whole day staying at home. This gives me a chance to work on my project ke70, instead of spending my whole day watching ke70 restoration process in youtube. I decided to strip it to bare metal using angle grinder with 36 grit 4" flap disc (no available paint stripper paint shops were close due to lockdown), removed all carpet, dashboard etc.
Do i need to change my fenders, apron, radiator support, hood etc. Anything else i need to convert it to quadlights. Thanks! Car model: 1983 corolla GL variant (philippines)
- ke70
- quadlights
(and 4 more)
Tagged with:
how to convert flat headlights to quadlights? KE70 '83
KE70ph replied to KE70ph's topic in KE70 Technical Articles
Hey man its been a year. I'm in process converting my flat front(rectangular headlights) to quadlights. Do i need to change my bonnet, apron and fenders, radiator support? -
xt130 struts, brakes and hub (do you mean complete strut?) and the t3 steering (super evolved knuckles??). does my factory castor rod(ke70), sway bar link fits in that kind of xt130 stuff(lcA and strut) can someone answer this question before i throw in some cash on that stuff. thanks!
Stock flathead ke70 83' headlight replacement
Wiring connections are all good, i checked it using a test light.. -
how to port and polish toyota 4k cylinder head? where should i start? intake manifold? any idea where to start?
can someone provide a wiring a diagram for toyota 4A-FE engine corolla 91-95
Thanks for that info nick!
Try compression test on 3 and 4, (wet test procedure) pour a small amount (enough to cover the cylinder wall) of oil into the cylinder through the spark plug hole. - if adding the oil increases the compression, the piston rings and/or your cylinder bore may be worn or damaged. - if the pressure stays low, a valve may be sticking or seating improperly, or there may be a leakage past the gasket, valve oil seal.
what are those wheels (the blue one)?
whats are those wheels?
Thanks for the help! It took me a whole day fixing my ignition timing just beacuse i forgot to install the pcv and the vacuum hoses that makes the car idling roughly.
This is my first car I'm new here. Need help on wiring connections from primary wiring (high tension cord from ignition coil to distributor cap) Can someone provide an illustration of ignition coil to distributor wiring connections. Thanks! From philippines.
thanks for the help! well appreciated! -
You should adjust your ignition timing properly and check if your vacuum hose are properly connected.
Hey, maybe you should check your ignition coil.
