Everything posted by Banjo
4K EFI Test Rig - IAC Valve
I purchased a knock sensor off ebay, suitable for a Subaru WRX. I chose it for two reasons . . . . 1. It wasn't that expensive. 2. It didn't have a threaded stud on it, but just a hole, so I could hopefully bolt it into the K series engine, using an existing unused thread in the block The knock sensor arrived today, so I quickly headed for the garage & engine, to find a good spot to mount it. The hole through the centre of the Subaru knock sensor takes an 8mm dia. bolt. The two bolts I highlighted in my previous post above, are 10mm in diameter, & I didn't really want to drill out the hole 2mm, in my new sensor. However, the holes directly below, that secure the mechanical fuel pump to the block, are 8mm in diameter, so that is where it is presently. I still might grab a 10mm bolt, & turn it down to 8mm, partly; & thread it, so I effectively have a 8mm stud onto which I can slip in the knock sensor, & "clamp" to the block, with a nut & thick washer. Where it is currently depicted above, has a gasket on the back of the cover plate, covering mechanical fuel pump hole, so the knock sensor has an "absorbing material" between it & the block proper. Next time, I'm running the engine, I'll put the CRO, across the knock sensors output, & see what the waveform of engine noise looks like. Cheers Banjo
KE30 big brake kit
Hi Dave, That looks amazing, & very professional, & simply bolt off; bolt on, from what I can see. It just raises two questions. 1. How much does that conversion kit cost, as displayed in your pic. ? 2. What size wheels did you fit, to wrap around that enlarged setup ? Would love a picture to see the wheels & front guard, to gain an insight into the resulting "stance" of the car. Did you match this front brake upgrade, with anything done to the rear brakes. Were your original rear brakes 9 inch, or smaller. Cheers Banjo
Ke26 restomod project
Hi Geoff, Fabulous start to your project thread. I take my hat off to You. That is such a daunting project, when what you have to start with; requires so much love/care, & work. Enjoy, & keep this thread updated. Cheers Banjo
Ke20 idler arm questions
- Ke20 idler arm questions
Hi Geoff, Did you make those lower front guard panels yourself, or buy them from Rare Spares, who I know used to make them for early Corollas, as they were such a rust catch point ? P.S. Start a Build Post on here. Always good to inspires others to have a go, when they see others attempting the same jobs. Cheers Banjo- Ke20 idler arm questions
Hi Geoff ! That is a labour of love, when there is that much corrosion accumulated over the years. Did you get the new ball joins pressed in, with a press, or create a ring anvill & hammer them home yourself ? I've always found 555 branded aftermarket bits & pieces OK, previously. Cheers Banjo- Ke20 idler arm questions
Hi Geoff, Are you saying you only changed one of the ball joints (not two) & the one you replaced; withs a new one, is the loose one ? i've never changed ball joints on the end on the lower suspenion arms. I am well aware that the grease nipples underneath the ball jopints are in a vunerable position to get wiped out, & not replaced; & if the rubber boot on the top side deteriorates, & allows road grime in, they will wear away. I'm wondering why I missed out on the delightful maintenance need. i just popped out to the shed, & I have three (3) off identical sets, I've pulled of Rollas, at some stage. They are all nice & tight, without any slop or wear movement in them at all. If the ball joint is new, & has slop in it, I'd be returning it for a new one. I've never ever, had the need to cut an olde one up, & look inside, but I assume there maybe a spring in the base, to allow grease to be pumped in. Maybe if there is a spring, then your new bush has it omitted, or it has broken in assembly at the factory ? Strangw ! Got me tossed how a brand new ball joint can be that loose, Usually, they are as tight as hell, when brand new. It looks like the Made in Japan ones are about $ 150 on ebay, whereas the Trupro versions are almost 1/3 of that amount. Cheers Banjo- Steering Components
I found another one in my garage, & had a quick look. I stand corrected. It does not have a phosphor bronze pivot sleeve bearing in it. It has two (2) tapered nylon bushes, one at each end. New bushes are about $ 30 a pair on ebay. I did however confirm, that the idler arm bracket, fits all models from KE-30, through to KE-55. Unfortunately, the idler arm ball joint is not replaceable, & if the ball joint has failed, you need to replace the complete pitman arm, which incorporates the ball joint. Both items; complete idler arm assembly, & the pitman arm, are available on ebay. Cheapest I saw the complete idler arm assembly was about $ 60.00. The pitman arm, including ball joint, was about $ 40 - $ 52, so on that basis, it would be wise just to pay the extra dollars, & obtain the full new assembly, & get everything. Cheers Banjo- So Who is Going to do the First KE Rolla EV Conversion ?
Lovely story about the very early (60-70 years ago) EV conversions, on the ABC website, yesterday. Good read ! https://www.abc.net.au/news/science/2023-02-04/worlds-first-electric-porsche-forgotten-history-evs-melbourne/101891670 However, it was a side story about a guy in Chinchilla, in Qld., that caught my eye. He converted a Dato 1200 ute. I worked for a company that had one of those once, & the ute cabin was hard to squeeze into. We can't let the Dato communitity, be the first ! Sure there must be someone out there, considering, doing an "EV", on their Rolla. https://www.abc.net.au/news/science/2021-10-18/converting-classic-cars-to-electric-vehicles/100533104 Cheers Banjo- Steering Components
I had a look in my heap of spares, & I do have an idler arm pivot assembly, out of a KE55. I can't imagine, Toyota changed that much throughout the KE30-35-55 series. I was going to compare it, with my KE30 2 door coupe one today, but it was raining, so couldn't put my KE30 up on the ramps, to take a look. If it's fine tomorrow, I'll take a look. This one is missing the phosphor bronze bush in the middle. I'll take a look through my heap of bits tomorrow, & see if it is there somewhere; or maybe I've used it previously, but can't recall.- Ke20 idler arm questions
I have never come across a "crushed" bush on an idler, on any of my Rollas. All the ones I've seen have two tapered half bushes. The only reason I could imagine, they placed a crushed idler bush, would be, that it assisted "self centering" of the steering. That would require, I presume; that the nut be tightened up, on the crush tube, with the steering in the straight ahead alignment. It might be easier to just get a whole new idler arm assembly, with the two tapered, removable & replaceable bushes, & dice the crush tubed version altogether. Cheers Banjo- Ke20 idler arm questions
Hi Geoff, If your KE26 idler arm pivot, is the same as those in the KE30 series, I have never come across them "locking up". The bushes in these take a beating, & I replaced them every 4-5 years. I guess, that if the nut on the top of the pivot, was too tight, it might not turn easily & could appear "locked". By all means, back the nut off, until it turns, but don't leave it loose. Cheers Banjo- 4K EFI Test Rig - IAC Valve
So the trigger wheel/disc, with magnets, & it’s decoder, is now running the engine, by firing four (4) off COPs sequentially; albeit, at a fixed advance of 10-12 degrees BTDC. (as per pics in the previous post) Next step to build an advance / retard controller. I built my ignition controller, with a “mapped” advance retard curve, by revisiting a tried & proven programmable ignition system, designed by Silicon Chip magazine, way back in March 2007. I say proven; as I have been using it in my KE30 2 door coupe, on a 4K-U engine, for years; with an Accuspark 3K dizzy Hall Sensor setup; & never had to touch it since, after I initially getting the advance mapping correct. I looked on the Silicon Chip website on-line store, & they still had the programmed PIC micro-processor for this project. I have built it up, in recent days, & tested it on the bench, & it appears to work well. The programmable ignition controller, can accommodate 2 off 11 x 11 advance/retard maps, (for duel fuel applications) or a single 15 x 15 map, which is what I’ve used There is no software, that communicates with this system, so a little hand controller, with an LCD display & some push buttons, is used to create the map. It’s a bit laborious, but works well. I used Excel to create the map. The MAP is a "little flat", to start with, but can be changed, during load testing, to optimise the advance setting, for various RPM & load ranges. I also limited the maximum RPM range, as my test trigger disc, & speed controlled electric motor on my bench, is not balanced; & the motor is only capable of 3500 RPM maximum. Once I get it on the engine & do some fine tuning, of the advance/retard map, I will be setting the advance as high as practically possible, without introducing “knock”, which could “spoil the party”. Not wanting to do that, I’ve yesterday built a Knock sensor kit; again put out by Silicon Chip in June 2007. (Silicon Chip still had the PCB in stock) Knock is caused by detonation, or too much advance; or high engine temps; or lower fuel octane rating, than normally being used; & results in mechanical piston rattle within the cylinder, around TDC. Modern cars all have a knock sensor, on the engine, that detects this piston rattle, & tells the ECU to back off the advance a bit. Apparently, all “knocking” in engines, creates “noise/knocks” in a frequency band width of between 4.5kHz & 6.5 kHz. The knock sensor itself, is basically a tiny microphone, listening to your engine. They typically use a piezo-electric sensor, which is attached to the engine block or head. The “knock or detonation” sensor controller, is basically a “notch” filter that only looks at frequencies between 4.8 – 6.4 kHz. When detonation, or knock is detected; a signal is sent to the ignition controller. As knock only occurs around TDC, the controller only looks at the knock sensor output, around TDC & for several milliseconds after firing has taken place. That avoids any other engine noise, that gets picked up by the “knock sensor”. The controller then automatically reduces the advance, between 0.5 to 6.0 degrees of advance, depending on the severity of the knock. I could nip down to a wreckers, & pick up a knock sensor, but I notice they are not that expensive on ebay, ranging from around $ 20 upto about $ 80.00. I prefer the screw-in type, rather than a bracket on the engine; as the sensor, then becomes part & parcel of the engine, & integral, to the block or head. Next question is where to mount it. My research indicates, that the preferred position is on the head some where. Has anyone out there ever fitted a knock sensor to their K Series engine, & if so, where did you attach it ? My personal preference, would be to fit it, high on the engine block, on the opposite side of the engine, to the exhaust header. I found a couple of threaded holes, behind the mechanical fuel pump, that appear to be roughly between cylinders 1 & 2. A bit tight in there, as the mechanical fuel pump obstructs; but I’m using an electric pump, & that area, has a blanking plate. Would welcome any suggestions. Cheers Banjo- Ke70 wag
Hi Mate ! What model 4K engine have you got. Is it a 4K-C or a 4K-U ? As you have advised that the 4K is "fully worked", I'm presuming the camshaft has been reprofiled ? Is this the same camshaft that was in the engine, before you had the crankshaft ground & new bearing presumanbly; or did you have the camshaft profiled or a new one fitted fitted at the same time ? We had someone else on here recently, with camshaft tiiming issues. I'll dig out the thread & link it here, & you can have a read, & see if the info therein, is relevant to your situation. Here is some it below . . . . . . I've been trying to find You a pdf version, on the web; of the "Yellow Bible", which the Toyota factory manual produced for the K Series engine. I have a hard copy which I purchased years ago. I covers every K series engine from the 2K to the 5K-C. I have just scanned the picture that is most relevant to your issue. When a manual refers to things like assembling & dissembling a car engine, they assume the engine is out of the car on a bench. There is a difference between the word "vertically", & "perpendicular." The K series engine block has the top of the block (where the head bolts on), & the bottom of the block (where the sump bolts on) being perfectly parallel to each other So when the block is on a bench being assembled etc. the keyway on the crankshaft is both vertical & perpendicular, assuming the bench top is level. However, when the K series is installed in the engine bay, it tilts over to the LHS, when you are standing in front of the grill, looking into the engine bay. I've never measured it, but it looks roughly about 15 degrees. You are looking at the keyway, & saying it is 20 degs out; or off the perpendicular, but your engine is in the car & already tilted, to the LHS. Your reference plane should be the bottom edge of the timing chain cover, which as the diagram above indicates, is exactly 90 degrees to a line drawn vertically through the crankshaft keyway. I don't know how else to describe it to you. Probably the best I can do, is show you a picture on Rollaclub, I took about 4 odd years ago, where someone else, had a similar issue to that which you have. Notice the engine is sitting on wooden blocks, supporting the engine on the block flanges where the sump is attached. Note the crankshaft keyway, is both vertical & perpendicular. If you want to read that post, then go to this link. https://www.rollaclub.com/board/topic/74223-worked-5k-problems-on-1st-start/ In conclusion, I don't believe that your engine needs to get pulled out. I believe the "timing error" you are seeing with the timing light, is caused by something else; probably vacuum problems. To stop any vacuum issues, causing timing errors, simply pull off the vaccum hose from the dizzy, so it cannot affect the advance at all. However, you must block the hose off, & any other offrices into the inlet manifold, so that the engine has a chance of getting the right air / fuel ratio. I hope this assists. Cheers Banjo- 4K EFI Test Rig - IAC Valve
These have arrived now, & I've tested them all for dwell time required to reach full coil load amps. I'm not sure whether these Denso COPs, I've purchased are genuine or copies. However, whatever they are; their dwell times are all identical, as they must/should be. The trigger wheel, dscribed in this thread, & it's associated decoding electronics, was fitted to the 5K test engine stand over the weekend, & it is all working perfectly, albeit, with a static 10-12 degrees of advance. I had the use my little CPS (camshaft position sensor), instead of the one I had incorporated into the camshaft spocket/chain cover. It was in the wrong position, so it was easier to use the other CPS sensor, built into an old cut down 3K dissy, as it can accomodate & place the camshaft position pulse, anywhere in the 720 deg cranshaft 2 revoloution cycle. Just now building a proven circuit, for providing a load & advance map for RPM & Load compensation. I also intend to add a knock sensor to it, so that I can take advance to it's limits without any chance of serious engine damage. One of the disadvantages of using a COP; is that there are no longer any spark plug leads, to put the strobe timing light pickup onto. Note my "workaround", by mounting no: 1 cylinder COP, upside down, & running a spark plug lead between the spark plug & the bottom tip of the COP. I have seen a tester on the internet, & I belive you can buy them commercially, that senses whether a COP is firing, by just placing a "wand" on the top of the COP itself. I should be able to build a "wand" that could then be used to trigger the timing light, so that the above work-a-round, is not required/needed. Cheers Banjo- So Who is Going to do the First KE Rolla EV Conversion ?
Oh I love it ! The love affair continues. You lift the bonnet, of your EV powered car, but still has all the appearances of a worked V8. I think it is call "holding on"; to what we stiil love & are so used to. https://www.sparesbox.com.au/blog/electric-gt-ecrate-motor Cheers Banjo- 4K EFI Test Rig - IAC Valve
Every millisecond is important, when it comes to timing & charging a coil primary winding, whether it be a single coil system, or a COP system, with one coil per cylinder. Lets look at the maths of ignition timing. In a 4 cylinder engine, with a points/distributor based system, the dwell angle (period during which the points are closed & the coil primary winding is charging), is pretty common, at around 45 degrees; depending on the lobe profile on any given distributor. So if we relate that to crankshaft degrees, it would be 90 degrees, as the distributor only runs at half crankshaft speed. 90 degrees equals exactly 1/4 of a revolution of the crankshaft. If the engine is at idle at 1000 RPM, then one revolution of the crankshaft takes 60,000 milliseconds, (millisec in a minute) divided by 1000, & equals 60 milliseconds. As 90 crankshaft dwell angle is a quarter of one revolution, then the dwell period would be 15 milliseconds. Now repeat the calculation for when the RPM is mid range, at say 2500 RPM. 60,000 / 2500 = 24 milliseconds. 90 degree is 1/4 of that period & is 6 milliseconds. For 5000 RPM the figure is (60,000 / 5000) = 12 milliseconds. 90 degree is 1/4 of that period & is 3 milliseconds. Unfortunately coils don’t charge in angles. They charge in time. So in a 4 cylinder engine, at 5000 RPM; if the coil was not able to full charge enough in that given period, the ignition coil performance, would drop off, the higher the RPM progressed. So that was for a 4 cylinder engine. If we repeat that exercise with a maximum dwell, for 6 & 8 cylinder engines, where the cam & crankshaft dwell angles are even less;, you can see why early engineers on 6 & 8 cylinder engines, dreamt up things like twin points & even dual distributors, to try & extend that dwell period, for charging up the coil. The real problem with a single coil is it has to charge up, & fire, before it can start to charge up again, ready for the next cylinder. That limits time available at higher RPMs. One of the reasons for the COP design; was that each cylinder had it’s own coil. Their charging periods could effectively overlap, if necessary. One of the reasons CDI became so popular, was that it overcame the dwell restrictions, altogether. A capacitor was charged up, by a much higher voltage than 12 volts (typically 200-300 Vdc), in less time, than it took 12V dc to charge a coil primary winding. These are still very popular on high reving single & twin cylinder engines on ATVs & quad bikes, outboard motors etc. https://en.wikipedia.org/wiki/Capacitor_discharge_ignition They are pretty cheap on ebay, so I might get hold of one, & have a play with it. There would be no need for dwell angle compensation, vs 12 volt battery voltage. Returning to the COP performance; it is more important that the COPs are matched, in terms of time to fully charge the primary winding of the COP’s coil. There is only one dwell time vs battery voltage compensation table, in the engine ecu. It would be totally unwieldly, to have one for each COP. I’ve ordered another 4 off Denso COPs today, from the same source. When I receive them, I’ll test each one separately, & see how close & matched their charging times are. It doesn't really matter whether they are 3 msec, or 4 msec; as long as they are all the same.- 4K EFI Test Rig - IAC Valve
Haven’t posted to this thread for a while on this project, as Christmas was in the midst, of that period. However, I’ve been doing a lot of design work on the bench, after I proved that the pulses generated by the aluminium multi-magnet trigger wheel, were reliably & worked well, on a working/running 5K engine. My next stage was to see if it was possible to decode the signals I had produced into actually running the engine, albeit, with a fixed advance of say 10-12 degrees. For this exercise, I needed to use the camshaft, CPS (camshaft position sensor), which was available on my 5K engine, but not on my bench; unless I built a little mechanical electric motor driven wheel, with another adjoining disc, running at half speed, to produce the CPS signal / pulse. Not wanting to go to all that “mechanical” trouble, I came up with an idea, that worked perfectly. I added a single additional magnet; mounted slightly inboard on crankshaft aluminium trigger wheel/disc. It produced a single pulse once per revolution, when, really; I needed one pulse every two (2) revolutions. I passed the single pulse through an IC that provided frequency division by two; & “voila”, it worked perfectly, with a single pulse for every two turns of the crankshaft mounted trigger wheel. It didn’t take long to produce a circuit, that provided four (4) individual sequential pulses; exactly 180 crankshaft degrees apart. I only needed 3-4 dedicated ICs, to perform this function. The little electric motor I had on bench has a speed controller on it, so I can run the motor for cranking speed to about 3500 RPM. The waveforms on the C.R.O. (Cathode Ray Oscilloscope), looked clean & precise. The last stage of this exercise/experiment, was to fire four (4) spark plugs, sequentially, before I head out to the garage to hook it up to a real running engine. For this I needed a precise pulse width to charge & fire the COPs (Coil On Plug) ignitors . The particular COP I’ve been using is a Denso model 90919-02240, commonly fitted to the Toyota Yaris, & by all accounts favoured by a lot of motor sport people who have converted early Toyota & Nissan engines over to COP coils. After I googled, I managed to find a number of people who have played with this particular COP, to determine, a range of trigger/charging pulse widths, to cater for a range of 12 volt battery voltages from 7 – 15 Volts DC. This is necessary, so an ECU, can produce a pulse width to charge & trigger the COP, with the ideal pulse width, based on the battery terminal voltage. The obvious need for this would be a cold winter start, where battery voltage, under cranking, could be too low, to produce a reliable & full strength spark to fire & start the engine. A wider pulse would be required, to “fully charge” the COP coil, before it is discharged, to induce a HV voltage in the secondary coil. The pulse width figure, for this model COP, for a 12 volts supply, appears to be about 3.2 – 3.3 milliseconds, from tables I’ve seen on the net, where others have carried out detailed testing of this COP model. My repeated tests here, seemed to agree. With a battery voltage of 12.59 Vdc, the ideal pulse width, where the coil charge just reached saturation was about 3.3 msec. So I build four (4) little circuits, to each produce a 3.2 msec pulse, using a 555 timer; & hook the little test system up to 4 off spark plugs, all gapped the same, on my bench. Again; “voila”, I then had four (4) spark plugs firing sequentially, on my bench, without a mechanical distributor or micro processor ECU in sight; or involved at all. I had the four (4) new spark plugs, fitted to a K series head upside down, on the bench. I turned off the lights in my workshop, & viewed the spark plug “arcs”, at close quarters with a magnifying glass. On one plug, the spark looked a slightly different colour to the remaining other three; & did not appear to be as “intense”. My CRO indicated all four COPS were receiving a pulse with width of exactly 3.2 milliseconds. I checked all the connections & battery voltage fed to pin 4 of each COP, which were OK. So I swapped two adjacent COPs around, one being the one, that was not as intense. Strangely, the spark plug at the position which had the weaker spark, moved to the relocated COP position. So spark plug & voltage & pulse width, all being all the same, it appeared the culprit was the COP, & I had a faulty one, albeit, that it was actually functioning & working, but not at full strength. When the trigger signal leading edge, is first applied to the COP, it doesn’t fire the spark plug. The leading edge of the pulse, turns on the special transistor, inside the COP, that charges up the primary coil of COP transformer. This can take several milliseconds. Once the coil is fully charged, that is the instance it is perfect to turn off the trigger signal. The collapsing magnetic field in the primary winding, induces a high voltage in the secondary coil, & that voltage jumps across the spark plug gap. This is why the duration of the pulse to the COP, is so “critical”. If the pulse is too narrow (shorter), the primary winding may not be fully charged, & the energy stored in the winding, will not be able to produce a spark strong enough. If the pulse is too wide, then once the primary winding is saturated, the current will still be flowing. However, as the primary winding is already fully charged, this additional energy, is just dissipated as heat, & the COP body will feel hot. Obviously, running excessively hot, will impact on the long term reliably & efficiency of the COP. I then remembered I had a small Hantek-CC AC/DC current clamp, in my possession, that plugs into the CRO, so I could actually see what the charging current was. I hooked it up & measured the current drawn by the two COPs, where I had observed one had a “brighter” spark, than the other. The one with the brighter spark, was indicating, that at the end on 3.2 millisecond trigger pulse, the current had risen to 11 amperes DC, at which point the spark was generated. The one with the not so bright spark, was indicating, that at the end on 3.2 millisecond trigger pulse, the current had only risen to 8.0 amperes DC, at which point the spark was generated. It just appeared that a 3.2 millisecond pulse was not long enough for this particular COP. To investigate what the issue was, I modified the pulse widths of both COP drivers, to 4.0 milliseconds, & repeated the exercise. Noticeably, both spark plugs now had arcs, that were of similar intensity. The COP that was previous firing, at 3.2 msec, was now firing at 4.0 msec, but had fully saturated by 3.2 msec; & was flat lining until 4.0 msec, when it fired. (see below) The COP that was previous firing, at 3.2 msec, but was only achieving 8.0 amperes current, was achieving 10.5 amperes, when it had been charging for 4.0 msec, when it fired. (see below) I left them both running like this for 15-20 minutes, & you could feel the increase in COP body temperature, of the COP that was fully charged by 3.2 msec., but did not fire until 4.0 msec. So there was no defect in these two COPs; it was just that they were different. I smelt a rat ! I had a total of six (6) model 90919-02240 COPs. I then tested them each individually, as above procedure. Four (4) off required a 3.2 msec pulse to reach 11 amps, & be fully saturated, before firing. Two (2) off required a 4.0 msec pulse to reach 10.5 amps, & be fully saturated, before firing. I know there are fake components out there, & it looks like I’ve been caught with 2 off, with these “Toyota Denso” COPs. I looked at all six of them in detail, & the moulded markings all clearly say Toyota Denso, & made in Japan, & to the naked eye, look identical. If these two (2) are counterfeits which I suspect, they are very good ones, externally. A few years ago, I got caught with counterfeit NGK Iridium spark plugs, where the only way to tell visually, is a slight difference in the printing on the box. I rang NGK, here in Australia, & they gave me the name of a guaranteed official retailer of NGK spark plugs here in Brisbane. https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/689127-spotting-fake-denso-ignition-coils-cops.html https://www.ngkntk.com/newsroom/blog/emea/fake-or-not/ Interesting that the guy in this article about the fake Denso COPs, measured the resistance of the coil & found it was “higher” than the genuine Denso product, which would correlate with it taking longer/slower to reach a full charge. So I might just go & buy four (4) new Denso 90919-02240 COPs, & hopefully I obtain some uniformity in their performance. So next update, will hopefully be with the system actually running on my 5K engine, as currently, it has a carby on it. Cheers Banjo- Squeal/Screech After Clutch Replacement
Are You sure you put the bearing on the right way around ? From my quick research, the AU Falcon clutch thrust bearing only goes on one way. One side is flat, (fitted towards the carrier), & the other side is curved (fitted outwards toward the fingers). If it was fitted in reverse, the fingers might touch the centre tube, before the curved section of the bearing. This side above is the fitted side. This side with the curved face, faces the fingers. Just a thought ! Cheers Banjo- Squeal/Screech After Clutch Replacement
Unfortunately, gearbox has got to come out again. It will be obvious, whence you get it out, as there will marks to indicate somewhere. No point in theorising atm. just get it out, as it is not going to fix itself. Let us know what you find ! Cheers Banjo- 5K with no oil pressure!
As Luca has purchased this manifold new, by the appearance of it; it maybe, that the casting is formed, but you have to drill it out, if you need to use a particular vacuum port. Have often seen universal alloy manifolds new, with more vacuum ports that you can use; all blocked off, so you drill out the one most conveniently located to where the vacuum hoses are in the engine bay. Finding it hard to believe it would run, as well as the video indicated, if it was wide open, as it first appears. That size vacuum connection could only be utilised for a brake booster me thinks ? Cheers Banjo- 5K with no oil pressure!
Hi Luca, Thanks for your answers to my previous queries. Your Query: Looking down on the distributor from the top, without the dizzy cap thereupon, the distributor looks basically "round/circular" except for part of the dizzy body which houses the operating shaft, to rotate the movable plate in the dizzy, This shaft is driven, by the belows at the end to which the hose from manifold vacuum, is fed to the dizzy. That part of the dizzy protrudes from the dizzy case, & usually lies basically parallel to the engine block, if the dizzy is correctly inserted with the camshaft. It appears we might have more than one issue here, that is causing confusion as to how to fix your issues. 1. There is still the question whether the "engine mechaical" timing is correct. 2. There is the definite question, as to what effect, leakage of air into the manifold is affecting the mixture, & vacuum to the distributor advance/retard mechanism. 3. There is the question whether the ignition is irregular or intermittent (boucing around) It is possible to turn the engine over without it actually combusting; by turning the engine via the starter motor only. It's not hard, once you remove the spark plugs, so there is no compression. Sure it won't run at 1000rpm, but at a 100 or so RPM, on the starter motor, you can easily check the timing, without fuel. I've done this a couple of times, when I've encountered strange faults, or combinations thereof; & it does work. Actually I have a "locked up" 3K dizzy I sometimes insert, to remove any possibilty that automatic advance/retard has any effect, on a particular problem. So for this test we need you to do the following. 1. Remove all four spark plus. 2. remove vacuum line from dissy or manifold. 3. Prop open fully all carby throttle butterflys. 4. Remove the HT lead between the ignition coil & centre of dizzy cap. 5. Take one spark plug, & put it upside down, in the top of the ignition coil. 6. Get a bit of insulated copper wire, & strip insulation from one end & wrap around thread of the upside down spark plug, & connect the other end of this wire to ground/earth/negative. 7. Place your timing light pickup clamp, around this wire in 6, with the arrow on the clamp pointing towards the ground end. You are now ready to go. You might need to have a second person turn & hold the ignition key in the "start" position, so You can clearly direct the strobe at the timing marks on the front of the engine. The strobe will flash 4 times each two revolutions, instead of 1, but that does not matter. You should be able to clearly see what the base timing of your engine is. Tip: A "little whiteout" on the timing marks on the timing chain cover, & the crankshaft pulley timing mark, will help the clarity, of what you are trying to discover. Cheers Banjo- 5K with no oil pressure!
Hey Luca, I wouldn’t be ripping the engine out, at this stage. Did you assemble the timing chain & alignment with the crankshaft pulley; or did others ? If it was you, did you follow the maunual instructions, & pay attention to the alignment, as described in my link, in pictures, in my previous post. You can test the timing, as I suggestedy; by taking out the spark plugs & turning the enigine over by hand & watching the rocker arm & push rods, relative to where the cranksaft pulley & distributor rotor are, at any given point of rotation. Many engine builders, place a large degree wheel on the flywheel, before the gearbox, is remated; which allows to accuraltely noting of the opening & closing angles of the inlet & exhaust valves on each cylinder. Is the cam in the engine standard, or a modified or performance version ? The dizzy doesn't have a wire that grounds it. The dizzy's ground/earth, is the engine block itself. Is the block securely grounded to chassis & negative terminal of the battery ? It must be or the starter motor would not work properly. The only wire to the dizzy, is the wire going to the ignition coil -ve terminal. You indicated that you have "points", so the dissy is obviously not a 5K electronic type. Just move the heater hose offending part, if it is that close. If the dissy is inserted & orientated correctly, it's electrical terminal shouldn't be anywhere close to heater hose clamps or earthed parts. As to the boucing around of the timing light strobe, I can only suggest that vacuum line is pulsating, due to leakage at the manifold, Whilst it is boucing around, pinch the hose to the dizzy, closed; & see if that stops is fluctuating. If it does, then it is a fluctuating vaccuum that is causing the issue. Cheers Banjo- 5K with no oil pressure!
Hey Luca, As you've indicated that you thought maybe the distributor gear cog was out maybe, 1 or 2 teeth, I thought I'd look up our forum, & see if we had ever posted any advice or instructions, as to how to go about this. I'm sure we have; but can't seem to find anything. This is one action, a lot of K Series owners have a problem with. The oil pump is driven by the camshaft; but only when the distributor shaft is in place., as you well know, after placing your drill down the dizzy hole & spinning it, when chasing the oil pressure issue. The trick is, to place the slot in the oil pump, with a screw driver, in exactly the right position; so that when the distributor shaft engages & slews clockwise, that the dog flat on the end of the dizzy shaft drops straight into the slot on the top of the oil pump shaft. It usually takes 2 or 3 tries to get it right. However, it has to finish up with the rotor button, pointing in the right position. I'm sure the Japanese worker at Toyota, back in the 1960-70, could do this in his sleep, with his eyes closed, but as we do it ever so often, it takes a bit of effort & care. The very first thing, is to make sure the engine crankshaft is at no: 1 TDC. It's a good idea, to fit the rotor button to the dizzy, whist inserting it, & placing a mark where no: spark plug lead post is, on the outer alloy edge of the dizzy. If it does line up perfectly, when the dissy is fully inserted, & the advance / retard protusion on the dissy body is parallel to the block; then carefully remove; reposition the slot in the oil pump, with a screw driver, & then turn the dizzy shaft the same amount, in the same direction, & reinsert. Next time, I do this on my engine, I'll take a couple of pics, & add them to this description. Cheers Banjo - Ke20 idler arm questions
