Banjo
Everything posted by Banjo
  1. I think the Chaser SX80 was like a Japanese version of our Cressida ? Think they had a 1.8 liter engine, so maybe the throttle body would be a mite big for a 4K engine. The Mazda 121 appealed, as it, like the 4K, is 1.3 liters, so could work well, despite the 121 having crossflow head & 16 valves (we wish). All that could possibly be needed, may be a simple adaptor plate to mate it, to the 4K inlet manifold ? I might chase up my mate with the Mazda 121, next weekend, & have a very close look at the setup. Maybe the little ECU, that I assume drives the injector on the 121, would work, just as it is. Once I finish this distributorless 5K, I might get a 121 throttle body/carby thingo, & have a play. It might ultimately keep a lot more 4Ks rollin along a lot more efficiently, & smoothly, for a few more years. Cheers Banjo
  2. Thanks Kevin, Good pics ! So what car make & model car did the compressor you used originate from ? Seems to fit well, & just what I'm looking for. Cheers Banjo
  3. Found this on www.drive.com.au website review. "Right from the word go, the Mazda 121 of 1990 captured the attention of Australian small-car buyers. It immediately attracted nicknames (not all of which were complimentary, on the surface at least) and it's bulbous little body was not only the hot topic of discussion for a while, but also encouraged plenty of imitators. It was probably that unconventional shape that was mostly responsible, but the biggest thing in the 121's favour was that it was seen as different. And when you think about it, it was different. Even at its most basic level, the 121's design strayed from the well-trodden path by being a four-door sedan with a distinct boot, when just about everything else was either a three or five-door hatchback. According to Mazda at the time, the all-new 121 was the world's smallest four-door sedan, and compared with the stodgy old 121 it replaced, the new car was also one of the grooviest around. And despite being externally tiny, the bulbous roofline and upright accommodation meant the car was actually reasonably roomy inside. Certainly, it was better than it appeared from outside and the boot space shamed many a bigger car. Despite the small opening, the boot could hold enough gear for a small family and the large, wide-opening doors made getting in and out less of a drama than it often is in small cars. "Like the car it replaced, the 121 sedan used a 1.3-litre, four-cylinder engine, but that's where the similarities stopped in their tracks. The later car's engine was a completely new design and used four valves per cylinder operated by a single overhead camshaft. Electronic fuel injection was still far from universal in 1990, and the littlest Mazda used single-point injection (basically an electronic carburettor) to put out 54kW of power at 6,000rpm and 106Nm or torque at 3,700rpm." At around-town speeds, the car felt pretty lively, but stretch the cruising speed and there wasn't always a lot left in reserve for overtaking or battling headwinds. Mechanical thrashing and noise was another downside of the 121's engine, and while it was no worse than most small cars when really wrung out, it still managed to make lots of racket when really pushed. At least Mazda stacked most of the performance reasonably low down in the rev range, so the engine didn't need to be worked too hard to deliver. The five-speed manual gearbox made the most of what was available under the 121's bonnet, although a lot of buyers gravitated towards the optional four-speed auto, which is never as satisfying to drive and makes the driver work the engine harder. One area where the 121 led the field was in its handling. Relatively low-profile tyres and reasonably firm suspension meant it was pretty tidy dynamically, at the expense of some ride comfort over bigger bumps and train tracks. The first shipment of cars missed out on power steering, but later batches had this feature as standard and it will be appreciated by any driver without Charles Atlas forearms. In fact, non-power-assisted cars can feel a bit brutish to drive, which is at odds with the car's intended role in life, so power steering is worth the extra money and will be easier to resell. Braking was taken care of by a standard-for-the-time front disc/rear drum set-up that performed more than adequately. The quoted kerb mass of less than 900kg obviously helped in that department. Equipment levels weren't terrific and a radio-cassette is about all you can hope for. All in all, the 121 sedan broke some important new ground for really small cars and showed that they could be both innovative and classy." Cheers Banjo
  4. Banjo replied to B-Lugg's topic in KE70 Projects
    Hi Ben, Yes, rewiring is a slow & painful job, but is very rewarding, as no other operation, provides more reliability to your overall car's electric systems. Consider, revamping the wiring all together, as described in my thread from some time ago. https://www.rollaclub.com/board/topic/65882-after-market-ke-light-column-switch/?tab=comments#comment-681303 You will finish up with a very clean neat engine bay, & a much more reliable & voltage drop free system. Unfortunately, I'm in Brissy, & you are in Vic., or I'd offer to give you a hand. It looks complicated, first up, but if you attack it, & treat one circuit at a time, it is quite simple to follow. Only additional outlay, is multi-fuse blocks & 12V auto relays, which are cheap on ebay. Any questions, please give us a yell. Cheers Banjo
  5. Yep ! Just like the rudimentary one, I guess, came on the Starlets. I believe it has a TPS incorporated, & a MAP sensor. Will do a bit more research today.
  6. Lots of people seem to have troubles with the aging Aisin carbies, we were provided with on our early Rollas. I know there are other carbies been taken up over the years, both upright & side draught, but many are expensive. Query came to me over the weekend, that I thought someone may have already tried. A mate, which I haven't seen for 12 months called by, & drove his daughters Mazda 121, which he had been working on. I had not seen it previously, & when he lifted the bonnet, I commented that it was naturally aspirated, as a carby was what I would have expected to find under an air filter housing looking like that depicted below. However, the answer was no, & when the filter was removed, what was in view looked like a carby, but was in fact a single injector EFI throttle body, that looked like a carby. The injector is in the throttle body proper, under that dome in the venturi. The Mazda 121 engine it was fitted to is a 1.3 litre, like our 4Ks. Now this looked a lot simpler than the single injector EFI setup on the Starlets, & I wondered whether anyone on here had ever investigated trying the Mazda one out, on a 4K Rolla engine ? Cheers Banjo
  7. Banjo replied to Taz_Rx's topic in Rollaclub Rides
    OMG ! You did cook them ! Them head studs loook like they might be ARPs ? ? ? Hope it's soon back on the road. Cheers Banjo
  8. Banjo replied to Taz_Rx's topic in Rollaclub Rides
    Lovely Simon ! Love those dishies. Looks all sooo clean, you could almost put your bake beans in those dishes & have breakfast, whilst working on it ! https://www.wikihow.com/Cook-Food-on-Your-Car's-Engine https://www.youtube.com/watch?v=IFQCrDOq-oY Love your work. Cheers Banjo
  9. Hi James, Very common problem, with the cheaper type of ring compressors, most of us have. This video explains the issue perfectly, if everything else you have done so far, is as per the book. https://www.youtube.com/watch?v=v1bKOQWVOaE https://www.ebay.com.au/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=tapered+bore+ring+compressor&_sacat=0 There is also an adjustable tapered ring compressor, which are a lot cheaper, but I've never used one, so can't vouch for it. https://www.ebay.com.au/itm/4-000-4-060-Aluminum-Adjustable-Piston-Ring-Compressor/311749924622?hash=item4895be570e:g:hosAAOSwK~RaBQLn:rk:3:pf:1&frcectupt=true Maybe someone else on here that has used one, might like to comment. Cheers Banjo
  10. Hi Tim, Personally I would not try to prise the seal out, with it in situ in the engine. Too much risk of scoring the seal journal on the crankshaft. By removing the seal holder, without lowering the sump, again, you will probably damage something. Just clean the whole sump pan gasket mating area, & get all that accumulated rubbish off, then lower the sump itself, at the back, & take the aluminium seal housing out. Cheers Banjo
  11. Well, finally got a couple of hours over the Christmas break, to complete the 12mm dia. return coolant line from the back of the engine, to the thermostat housing, from the little "Tee" adaptor I fitted to the head rear access plate. Normally the heater return coolant line runs down the distributor side of the K series engine.. With the COP conversion, I am doing on this 5K, I wanted to keep the distributor side of the engine as clean looking as possible. I decided to run the return line down the manifold side of the engine, as there are a couple of unused mounting points, provided on the aluminium inlet manifold casting. It turned out perfectly, so am very pleased with the end result. I was originally considering fitting two (2) off return coolant lines; one for the head only, & the other for the heater, when in operation. That's how I did it on my 4K-U in my daily drive. However, as the heater is used so infrequently, here in "sunny" Queensland, I have decided to let the one return line carry both return coolant circuits. This results in a lot less complication, & a cleaner uncluttered look. Parts Required: 1 meter length of 12mm copper pipe from Bunnings. 2 off the shelf metal brackets, which I cut down to suit, from Bunnings. 2 off 1/2" pipe saddle mounts. 4 off 5mm bolts, nuts & washers. 2 off 6mm x 25mm bolts, for brackets to manifold. 6 - 8 off 11-22mm screw type hose clamps. 1/2" hoses off a Commodore or Hi-Lux. 1 off SpeedFlow 16 x 1.5M 1/2" hose adaptor, to plumb line into thermostat housing. Bit of hi temp silver paint This is surely one of the easiest & best mods you can do to your K Series engine, to overcome the inherent issue of the rear cylinder no: 4 running hotter than the forward cylinders. P.S. Although I advised it is an easy job, it is best carried out, when you happen to have the engine out of the car, or the head off. Undoing the four (4) off bolts that hold the little access plate can be fraught with difficulties, if they are corrosion welded to the aluminium head, as it is virtually impossible to drill & tap new threads with the engine in the car & the head on, as the distance between the rear of the head & the firewall, is so limited. Cheers Banjo
  12. Most definitely leaking; & probably for some time. Remove the aluminium seal housing & replace. A very good idea to replace the gearbox spigot bearing in the crankshaft, while you are at it, if it feels in any way a bit "dry". or you can sense any movement, with your little finger. Good luck ! Cheers Banjo
  13. Hi Tim, Is the 5 speed G/B you've got, originally from a KE55, or a later KE70 ? Cheers Banjo
  14. Only "scary", if you have an "aversion", to K Series engines falling on your head. phobia an extreme or irrational fear of or aversion to something. "she suffered from a phobia about birds" synonyms: abnormal fear, irrational fear, obsessive fear, fear, dread, horror, terror, dislike, hatred, loathing, detestation, distaste, aversion, antipathy, revulsion, repulsion; More aversion a strong dislike or disinclination. "they made plain their aversion to the use of force" synonyms: dislike of, distaste for, disinclination, abhorrence, hatred, hate, loathing, detestation, odium, antipathy, hostility; someone or something that arouses a strong dislike or disinclination. "my dog's pet aversion is visitors, particularly males" synonyms: abnormal fear, irrational fear, obsessive fear, fear, dread, horror, terror, dislike, hatred, loathing, detestation, distaste, aversion, antipathy, revulsion, repulsion;
  15. I just remembered, I once changed an oil pump, & a set of big-end bearings, in my KE55 coupe, without removing, or lifting the engine, but just supporting it, & removing the front cross member altogether. As Altezzaclub, suggests. It is not such a big job, & you have very clear access to the bottom of the engine, as the following pics display.
  16. Hi Tim, Is the oil pan gasket leaking in just one place, or in several places ? I've come across leaking oil pan gaskets, that can be fixed, by just going around & tightening each & every sump bolt & nut, without the pain of replacing the oil pan/sump gasket in situ. If the gasket appears to be leaking at the rear, there is always the possibility that it is really a leaking rear oil seal, which can appear to the untrained eye to be a leaking oil pan gasket. If the sump area is a big oily mess, I'd run the front of your car up on the ramps; tighten every sump flange nut & bolt; give the whole area a good dousing of "aerosol degreaser"; hose it all down with a bit of pressure; let it dry; start up the car & take it for a 20 minute run; run it up on the ramps again, & see if it really needs the gasket being replaced, or is just isolated at one point. If the oil leak is right at the front, (quite common) then the leaking oil gets "blown" back over the entire sump, & looks a lot worse than it really is. Let us know how you go. I can assure you "Altezzaclub", above is quite correct, that replacing the sump gasket, with the engine in the car is a "dog of a job", & you'll finish up swearing a lot ! Cheers Banjo
  17. Very sorry to hear of your wife's brain bleed. Really trust you get a "Good Christmas News" that She is showing great improvement. Being Christmas, which is really for kids, & lots of fun, I can imagine, how you & your kids feel. As Dave says . . . It sucks ! I really, hope that in a couple of months, She is making a full recovery, & that you can look back at this period, as a very bad dream, in the past. I'm sure the thoughts of all of us here on Rollaclub, are with you & yours, at this time. Please yell out, if we can be of any practical assistance. "We are family",. . . . . although many of us, have never physically met. Cheers Banjo
  18. Another steamy Summer already in Queensland, and a boy's thoughts turn to . . . . . Air Conditioning. I know, some KEs had A/C factory fitted as standard. However, my KE30 2 door sedan, was not one of them, as originally with a 2 speed auto, & a 3K engine, it would never have got up hills, whilst the A/C was on. (It probably even had trouble getting up hills without the A/C on) My better half always complains, when it is hot & sticky, . . . . "can you put A/C in this car ?" My standard answer, is . . . "It already has A/C, just wind the windows down, to start it up." Unfortunately, that retort, is starting to "run thin", so as I have a 5K going into it soon, I thought maybe it might not be that hard to retro-fit A/C. Now I don't want to go find an olde KE Rolla, that had A/C, & pull everything off, & swap it over, as a compressor that olde, would be pretty cactus, & not worth reconditioning. Modern auto compressors, I would hope, would be a lot more efficient, & more plentiful. So my question is this . . . Has anyone on here, successfully retro fitted an A/C system into their KE Rolla, that originates from a "modern car" (<10years old around 1.5 - 2.0 litre) ? There is plenty of room down on the front of the installed 5K Rolla engine, to fit the compressor, with good access. A compressor mounting bracket could easily be fashioned, I would think, & there are two (2) mounting points on the block, similar to the alternator mounting on the opposite side of the engine. So if anyone has done this, please post & provide some details, as I'm not interested in "reinventing the wheel", if someone has been through the exercise previously. P.S. Now the 5K engine I have, probably came out of a Toyota forklift or similar, as it had three (3) pulley grooves, on the crankshaft pulley. One for the alternator, & two for power steering pump & some sort of hydraulic pump; so an A/C should not be too hard on it. Cheers Banjo
  19. The T piece is copper & brass combo type. The bottom of the "T", that is silver soldered to the plate, is very thick brass. It is very solid & strong. It is very tight down there between the back of the head & the firewall. No room for a 2 way valve. The pipes coming out sideways, is so that any movement, will be absorbed by the hoses. This way, the existing heater tap, on the rear of the firewall, will still be used to turn on the heater. The return to the front of the engine, of coolant from the back of the head, will flow all of the time. P.S. I did have a look at 2 way valves on the net, but they are all four port, & it would result in it being a plumbers nightmare down there, & very messy. I'm using the K.I.S.S. principal. (Keep It Super Simple) Cheers Banjo
  20. Earlier in this thread, I suggested improving/lowering the coolant temperature differential between the front & the rear of the head, by taking hot water from the back of the head, & feeding it back to the underside of the thermostat, in the thermostat housing. It worked perfectly ! I did this on my 4K-U, in the car, but was hesitant to remove the plate on the rear of the head, in case one of the bolts was frozen, & snapped. To "prove the effect", I simply removed the heater hose, from the spout on the rear of the head. What I really needed, was a dual outlet, on the rear of the head, one for the heater inlet, & the other for the return to the front of the engine. I've got a "distributorless" 5K, that will be going in the KE30 soon, for some road testing, so thought, now is the time to fabricate a dual coolant outlet on the back of the head, before the engine gets levered into the KE30. This is how it turned out. Just a simple Tee tap plumbing fitting , from Bunnings, silver soldered, to the rear head access plate. Thought I'd just post a couple of pics, in case someone else, wants to do the same, or something similar. A really worthwhile simple mod, that provides great results, & may even save you a blown piston, or broken rings on no: 4 cylinder. Cheers Banjo
  21. In theory, the fuel pressure, which is quite low, in the order of 4-10 PSI, has a slight effect, as higher pressure can allow the float cut-off needle, to only close when the fuel level in the bowl is a bit higher. As your fuel pump has a return or bypass outlet, it should be pretty constant. I wouldn't worry too much, as your engine's idling & driving performance, are to your satisfaction. Carbies as old as ours, suffer from a build up of "fuel gum" & lacquers, in the tiny passages internally. A good idea, is to dissemble the carby completely, & soak in a carby cleaning fluid, & then reassemble. Not really recommended, unless you really know what you are doing. A quick fix, is to remove the air cleaner, & give the carby a good dousing of carby & thottle cleaner, in a spray can. Sometimes running the engine at 2000 rpm with the air cleaner off, & spraying thottle & carby cleaner straight into the throats, can often, get rid of annoying stumbles in the carby's performance. Cheers Banjo
  22. Yes ! When the idle mixture adjustment screw is wound in as far as it can go, it completely blocks fuel coming out the "idle port hole" at the very bottom of the primary venturi. As you unwind it, it allows more fuel to be sucked out of the idle port, & renders the idling mixture less lean. A very good check is to make sure that the electric solenoid valve on the carby is working. It is powered by the ignition circuit. It prevents run-on, once the ignition has been turned off, as it allows fuel to flow to the "slow" & "idle" ports only. Once you have the idling good, & to your liking, simply disconnect the wire to the carby solenoid, & the engine should starve & stop, or at least get very fluffy. That proves the solenoid is working You can usually hear the solenoid clicking, if you turn the ignition switch on & off. Surprisingly, the idle circuit it still in play, & contributing to the overall A/F ratio, when you are driving. I learnt this once on a long trip. All of sudden, the engine was not "as strong", & I didn't know why. At the next small town I passed through, I had to pull up, at a pedestrian crossing, & the engine cut out. That gave me the clue. I pulled over, & found the green connector, for the single wire to the carby solenoid had gone o/c. Cleaned it up, & it then idled properly, & the engine was back to full power. Cheers Banjo
  23. That is the idling mixture adjustment screw, i've highlighted. If you screw it right out, you'll see it has a "pointed" tip. The idle speed adjustment is the big thumb screw to the right & up, in that picture. It usually has a large screwdriver slot in it. Cheers Banjo
  24. This is the idle adjustment screw. It has a spring behind it. Hope that assists. Cheers Banjo
  25. The two gaskets are supplied, as they are both needed. 1. One gasket fits between the engine block & the mounting spacer. 2. The second gasket fits between the mounting block & the fuel pump flange. You probably only fitted one, because you did no remove the mounting spacer, from the the engine block. The spacer is that dark bit in the picture below. It stops the fuel pump getting too hot, & vaporising the fuel. Cheers Banjo
