SLO-030
Senior Member
Everything posted by SLO-030
  1. There's no such thing as a non-expensive part on a Chaser :dance:
  2. +1 Need some Dodgem Footage.
  3. Bmxsexmonkey is selling the tailhousing and shifter from a KE55 5speed. The KE55 tailhousing is a bolt on affair to a KE70 5speed and means its a bolt in job for a KE30.
  4. a KE55 5spd will be a bolt in afair to a KE30. a KE70 5spd requires the shifter hole to be cut about 90mm further back. Also need to have the KE70 gearbox mount and crossmember. You said that you have to adjust the crossmember in the first car (previously auto) Auto chassis have a different bolting arrangement and the crossmember is further back than the manual chassis
  5. I don't see how "heavy duty" they could be, not much room for improvement on the Jap ones.
  6. Snapped 2 spigots off the cross again, tailshaft hit the ground. Lucky it was only doing like 10km/h in a carpark.
  7. Thanks for the offer mate. Big thanks to all that pulled over (Mick, Darren, Alan, Hendo, Hugh)
  8. I replaced them myself. Followed the directions of a qualified mechanic of 20+ years.
  9. SLO-030 replied to rian's topic in General Mechanical
    The ballast resistor is there to limit current draw thru the point. To stop them arcing and killing themselves. Non-electronic coils are just made to cope with the lower voltage they receive as a signal. The start circuit bypasses the resistor to give the coil a full 12v to aid start up. As soon as the key flicks back to the ignition circuit, voltage is dropped back thru the resistor. No point changing to an electronic dizzy, then leaving a coil that operates at 8v. Thats the whole point of going to electronic ignition systems. MORE power to the coil = MORE spark power.
  10. Went to pull over, slowed down, got on the grass and it locked up. Pretty much just along for the ride after that. Hugh88kw pulled me out with his XR6 ute, Me reversing and the front getting pushed by Mick and Alan.
  11. Took the wagon for a wash tonight. Returned home on a tow truck. 2nd Universal in 6days. :bash:
  12. Lookin good! Try putting a jack and a piece of wood under the fuel tank. Should pop right back into shape.
  13. I think i can say, once your sliding on grass, there's not much you can do to control it.
  14. Sounds like it might be running lean. Is it running hotter than usual?
  15. If you need a hand, let me know.
  16. SLO-030 replied to mungi mods's topic in Rollaclub Rides
    Interesting. I spy a 5 stud front end conversion...
  17. BIIGGGG massive thanks to Jarrad and Melanie for organising a wicked weekend. And to everyone who attented to make it what it was. Hope next year is just as good under new management. Also a massive thanks to EWT (Woz, Josh and family) For a place to stay for the couple of days i was in Vic. Deffinatly give you guys some more notice next time!! CHEERS Ryan
  18. Haha, yea, but lucky as there wasnt a scratch on the car or myself/passenger.
  19. Got lost in the grass, oh baby baby :dance:
  20. 308 requires no firewall mods. Maybe some tunnel massaging for the Auto?
  21. A shell with a heap of gear in the back.
  22. SLO-030 replied to NickZ's topic in Rides - non-Toyota
    Looking good man! Do i spy a KE30 shifter boot there :P
  23. SLO-030 replied to GJM85's topic in General Mechanical
    Pcv opens under vacuum. Which is why alot of older cars let off a puff of oil smoke after closing the throttle. If the valve hasnt already completly jammed up...
