Evan G
    3817
    23
Everything posted by Evan G
  1. what about 22r? ;)
  2. sigma arms + xt130 struts = 1.5 neg camber. + camber tops = 3.5
  3. 7k and 5k hydro's are the same
  4. i don't have a efi manifold to start mucking around with. ive converted the original manifold to suit a 32/36 weber but bonnet clearance will be an issue
  5. the early type engines had round ports. so the previous owner made it round. I'm going tomorrow to sus out getting it aqua cut out of mild steel 8mm thick (i got acess to a mig so its easier)
  6. double check your timing chain tentioner bolt tightness/sealing surface
  7. ebay usa. have quiet a problem with the intake manifold. the nuff nuff i bought it off didnt think about the thermostat housing. redesign it is gonna be a karnt!
  8. plenum is tiny. was made for a blow thru set up. ill be making a bigger plenum or run trumpets. engine kit arvied today from the states in under 4 working days :o
  9. before vs after dissy alternator and others every bolt-on painted motorbike carbs NO F*CKING AROUND.JPEG
  10. its a secret ;) this build is going to get out of hand. head and rebuild kit orderd (should be here this week) got cbr900 motorbike carbs and mainfold off ebay for a great price. need tractor/starter motor/msd unit and cam sub 14sec 1/4 mile is my goal ;)
  11. could of went Valve Lift .527 .527 Advertised Duration 325° 325° Duration @ .050" 274° 274° 3000-8000 rpm range LOL!
  12. yea gday rollaclub. update 22r is at machinist ;) (250/260@ 50 thou cam. 12:1. 1mm oversize valves and brand new cnc ported head) 5 stud lyf
  13. cheap flareing tools and dies are JUNK. youll have to buy a snap on /blue point set to get some decent flares
  14. terry my old trimatic used to do the same thing. id normally get it more $hit till it changes gear. solution? manual conversion
  15. mx63 cressida
  16. http://www.ebay.com.au/sch/i.html?_odkw=28+36+weber&_osacat=0&_from=R40&LH_PrefLoc=2&_trksid=p2045573.m570.l1313&_nkw=28+36+weber+venturi&_sacat=0 ebay.
  17. what engine is it going on? i didnt need to play with my venturies
  18. wmmh - good old icy stella artois after a hard day at work :D
  19. always wanted to do a om642 or 646 conversion!
  20. wouldnt they be drums since they caliper bracket?
  21. http://www.ebay.com.au/itm/32-36-DGAV-DGEV-WEBER-CARB-Accelerator-Pump-Diaphragm-NEW-NOS-WEBBER-carburetor-/360558548693?pt=Motors_Car_Truck_Parts_Accessories&hash=item53f2f6d6d5
  22. thats the accelerator pump diapham. ebay or local carb joint
