Evan G
    3817
    23
Everything posted by Evan G
  1. because racecar jono!
  2. i heard you use ke30/55 tie rod tubes for sigma arms
  3. ill raise you sir!
  4. fix it again tony!
  5. recently rebuilt 7mge with around 20 thou removed from the block and head. (compression should be around 10.5:1), ran it in by mildly thrashing it. But now have the problem with TERRIBLE fuel eco. my mate who was following me while i was giving it a boot said it was blowing black smoke all thru the rev range. 60L of 98 octance just got 300km. timing was set at the factory 8 degrees. but i could feel like it didnt want to pull nicely. therefore bumped it up to 15, went a little beter then laster bumped it up to 22! now it ʞ©$ɟing PULLS! heres a pic of the plug any ideas on what to check? o2 sensor. afm? tps? vac leaks?
  6. inb4 chopped commo springs and flipped leafs :lolcry: :lolcry:
  7. http://xtremecarzone.com.au/index.php?showtopic=805 i went by this, by far the easiest and simplest
  8. hey knackers coming to jdmst today?
  9. 3rd? LOL peel out 2nd to 100 mate :P
  10. this is valve bouncing
  11. i replied to his pm. also when refering to cams please go by the DURATION @ 50 thou. this is a more accurate way of dermining the size of the cam
  12. or msg SLO-030. his a trader for coby extractors
  13. just put a dab of threebond on it. will seal that sharmuta right up!
  14. I'm 99.9% its cam timing. my old 4k was the same! didnt like any revs past 5 grand. when i decided to put a bigger cam in it because i conviced myself that was the problem i found the cam was a tooth out. fml
  15. if you earth out the plug for the sender the light should come on. ive had in the past were it was slightly loose cause the oil light to flicker. mind you this was on a fresh engine so bricks were shat!
  16. do recommend removing the motor to do a sump gasket. ive done 3 in car and all have leaked because it wont sit right in the back corners. remove the engine and do it. slight smear of threebond and replace all studs with bolts & washers
  17. better off just going down there. if theres nothing listed they'll match something up
  18. pedders. take a sample along if you can
  19. swap 2 and 3 spark plugs and turn over the engine with no filter on. the backfiring should clean it out the carb. if thats doesnt fix it rev the living ʇ~~ɔhole out of it with no filter on it
  20. only difference between 5k and 4k/3k is 5k has return line on it, all interchangable
  21. DAFUQ IS THE CAR?
  22. i was driving home last night when a kangaroo decided to cross the road. gave it a big rev and the ʇ~~ɔ stopped dead in its tracks and ran the other way!
  23. pull the plug off while running and hold it to the head and see if your getting spark
