rian
    1777
    37
Everything posted by rian
  1. Are they 17s? This car is refreshing to look at.
  2. I really don't think you should be able to move it by hand, the pressure plate takes a lot of force to depress.
  3. Looks neat man. Does your catch can catch much oil?
  4. And then sticker bomb your entire windscreen with illest stickers.
  5. I reckon this would look absolutely bawwwws times infinity if you took the visor and roof sticker off
  6. That front bar is awesome!
  7. I think I know what your problem is, you have a locked diff... But seriously, they invented the differential about a billion years ago because a non-differential axel was never going to work properly in a normal car. Why do you think going back to a non-differential rear end is an "up-grade" for your road-going car? Use your brain and replace your busted diff with a normal T series diff, or if it's a track car you should use your brain and replace your busted diff with a normal T series diff.... wait, did I just say the same thing? Derrrrrr
  8. This is an awesome car, I hope everyone votes for this for car of the year!
  9. ʞ©$ɟ spending $10000 on a wedding, spend $0 on a wedding and spend $10000 on a holiday instead.
  10. The best money I never spent was on a phone case that I didn't buy for that phone that I don't have that breaks the first time you drop it... wait what? NOKIA 4 LYF
  11. ^This. There's too many idiots that don't realise you can put more than 10 words in a text. There's too many idiots that can't answer/ask more than one question at in a single text. There's just too many idiots.
  12. Looks awesome, but how did you go about calibrating it?
  13. Smallports have a bigger flywheel (212mm), bigports have a smaller flywheel (200mm). But the flywheels are interchangeable so this may not be the best indication. Smallports have a knock sensor I believe? bigports do not. Smallports come in AE92s, bigports come in AE82s. If one is bigport and one is smallport, the wiring will be different. If you really want to figure out which one is which, look for a TVIS plate like Reed said or pull the manifolds off and check the port sizes.
  14. ^shutup dumbdumb
  15. Edit: ^beat me to it. The 3 rib (black and red lettering on the inlet cam cover) is probably a bigport, whereas the other 4age will be a smallport. So the wiring will be different.
  16. Bought a workbench, pretty good for $150. staff discount rules.
  17. Wow, just found out how expensive quality torque wrenches are. $500 for a W&B 1/2" unit, ʞ©$ɟ that! Probably cheaper on ebay...
  18. Should I buy a workbench or save money to spend on my car? Or should I buy a torque wrench?
  19. I sort of agree, having another pivot point on the right side of the master cylinder would be better. But I can see it failing from torsion/bending moment before it fails in shear. Otherwise everything is awesome. Though I still hate you.
  20. I believe they are Techno Phantoms or SSR Superstars, I'm not sure exactly.
  21. HEL make custom ADR approved ss braided lines. I think I paid $130 for a pair of front brake lines so I can't imagine a 10inch line would cost much.
  22. I had to move the distributor out of the way to get the headers onto my 4AGE, then put the distributor back in place on the headers were on and bolted up. Is there any way you could do that with yours?
