rian
    1777
    37
Everything posted by rian
  1. Those are two of the weirdest options I've ever heard for a daily/family/city car. Just sayin'.
  2. You are the biggest car slut I've ever met. Stay away from my car!
  3. I think there is a dark green Camry Sportivo for sale on here, it looks pretty decent. There is also a silver KE70 with a 4AGE smallport for sale: gold mesh wheels, kamei front lip etc. I think you might have just missed out on that one though, I think it sold. Some idiot was selling them, have a look in the for-sale section.
  4. What?
  5. rian
    White Car
    I'll hopefully be in Bangalow for a few days as of Monday, let me know if you need a hand with the swap.
  6. AE8*/9* (excluding AE86) thrust bearings are different to T50 thrust bearings, they don't use a bearing carrier like the T50 thrust bearing. Left is AE86/AE71 T50 thrust bearing, right is AE8*/9* C5* thrust bearing.
  7. Where are you? I've got a twin cam that I've been slowly wrecking, it has seats in it still.
  8. The cars are super clean, but what's with the wheels? Are you stuck in the '90s or something?
  9. It might just be a broken wire in/near the plug? I'd lend you my distributor but it's about 4 hours from your house and I still need to so I can work on my car.
  10. Yeah it's inside the distributor, maybe grab a spare dizzy and see if it works?
  11. Crank angle sensor? Or crank angle sensor plug? I've heard of the pins/wires breaking inside the plug. Edit: Straight from wikipedia (I've never had to deal with a faulty CAS but it sounds similar to your problem): "A bad crank position sensor can worsen the way the engine idles, the pistons fire, or the acceleration behavior. If the engine is revved up with a bad or faulty sensor, it may cause misfiring, motor vibration or backfires. Accelerating might be hesitant, and abnormal shaking during engine idle might occur. In the worst case the car may not start." Also this is Trev's plug repair guide: http://www.ae86drivi...ge-Dizzy-Wiring
  12. Are you sure your battery isn't flat?
  13. Mum gave me a jaffle iron for Christmas... ʞ©$ɟ yeah!
  14. Will be ordering a cat then, and a straight through muffler if I can afford it.
  15. rian
    White Car
    These guys are from Byron, all they do is walk around town making shitty rap videos all day. Perfect examples of "lords".
  16. rian
    White Car
    You don't understand, Byron douchbags, or "lords" as they call themselves, ruin absolutely everything. They are the suckiest bunch of sucks that ever sucked. pic related.
  17. Most dished wheels are 90-100mm, quick releases are like 50-60mm(?) and most boss kits are 75 or 100mm. Just go and measure it off your steering column.
  18. Yep, that's cool. I'm liking the slant-fronts more and more everytime I see one. The front lip looks awesome as well.
  19. rian
    White Car
    So there's now 5 Byron Bay members on RC! Please don't make KEs the "cool thing" in Byron, I couldn't handle it if Byron douchebags started liking them. We already have to put up with flat-cappers liking them...
  20. rian
    White Car
    ^Do you drive a beige KE70? I've seen it around Byron a few times.
  21. This is exactly why I gave up looking for a 4AGE KE70 to buy and just did my own 4A conversion. That sucks man, I hope you don't find any more dodgey mods.
  22. Circuit opening relay. When you crank the starter it triggers the COR and turns the fuel pump on. Which helps the engine start quicker.
  23. Do you still have that starter signal going to the ECU? And also a starter signal to the COR?
  24. Exhaust diameter will probably be too big, I'm only going for a 2" system. I'll just get a new Lukey high-flow cat from work, they're only about $100.
  25. Just bought 3 meters of 2" exhaust pipe, a 12" resonator and a couple of flanges for $60! I might buy a catalytic converter and a high-flow/straight through muffler when I have more money, or just use the shitty muffler that I have.
