Ke20 Fuel Tank Capacity?
hey guys, just want to know how many litres my tank holds, so that i can work out my litres to km
  • Replies 32
  • Views 21.5k
Easy way to work out how many litres per km... Fill her right to the brim... run around 100km, then refill... the amount that fits into the tank is what you've used to do that distance.
For example... I fill the tank of my T18 and drive 120 kms... I then refuel (noting that my tank isn't anywhere near empty... it's only down about a third...) I fill her right to the top, just as i did the first time, and note that i've put in 15.58 litres... then simply take the number of kilometres (120) and divide by the litres used (15.6ish) and it gives you the kilometres per litre... in this case around 7.7km/L
all i know is its small enough for me to plan out my cruise routes depending on where BP servos are
altho my manual/guide book says 45L's, my car always fills 30L's.........its baffled me the past few weeks :) glad this was brought up
45 sounds like alot but ive had the tank out of my ke20 and it looks as big as 2 20L gerry cans together.
I usally got about 600km range from my tank and the most i ever put in it was 35 litres.
i know mine is over 41L cos i just filled it up with 41.6L the needle was below E on the fuel gauge. just looking in the owners manual and it says 45L and when the needle is touching E there is 4L left in the tank.
to the E!!! damn. I don't let the needle drop below the last line on the gauge. My 20 gets a lil rough as it starts to pickup crap from the bottom of the tank..., any1 else run theirs to the E????
