Car Trailer Project
  • Replies 201
  • Views 114k
day 4.3 I have spent 3 hours after work this week will go hard on this project in the new year. I have another 4 days off :lmao: but on call again :)
And in metric old man??
Ring up a tyre shop to get a quote. tell them What size wheels are on your car in metric see the response you get.
harden up WE talk imperial still for tyre sizes, trailers sizes 6x4 7x4 8x5 thats the way it is.
Looks like its coming a long well .What sort of tare weight do you reakon it will be?
I ve got my frame cut out for my new trailer, and like you bloody work gets in the
way of projects :)
One question where or how far back do you put the centre of the axles?
ive been told many formulas .
Keep the pictures coming good tread . :lmao:
rob
way of projects :)
rob
the trailer is getting heavy, the coupling is rated at 3.5 tonne so i will have to put over a weigh bridge and then work out my carrying capacity..
for axle placement i used 1/2 inch back of center for every foot of trailer. if there is to much weight on the draw bar with a short car I will just put the car back a bit.
day 4.6
3 more hours on the trailer today, I fabricated a plate for the jokey wheel, welded draw bar and drilled and bolted hitch
u do realise that everyone on here is gonna ask to borrow it once its done right?
ps, can i borrow the trailor once its done :yes:
I have been thinking about how i can accommodate. The regulations say brake intensity must be adjusted from drivers finger tips AKA a brake controller. I was wondering if there is a remote control device that could be fitted ,to save a brake controller being fitted to every car i use to tow with.
Thanks for the comments everyone,
Day 5
Today I Fitted front and sides. got straight as i could and then welded up
nice looks like a trailer now you going to make wheel cover thingys
bought these from a trailer place for $119 for the pair, will save me a little time.
I was gonna say you could buy these off the shelf. Looks the same as the ones we sell at work.
Trailer is really coming along there, wish i had the space to build one.
Day 6,
2 big problems,
1 wheel off set ,
2 spring shackle bolt almost rubbing on tyre.
I spent a lot of time today working out how to overcome these problems, I ordered the axle spring set to suite holden vy tonner rims,
