Trev
Donor
    6398
    29
Everything posted by Trev
  1. I have some money owing to me so I will see if I can get it.
  2. Skidpan.
  3. What a waste of time, why would you induce clutch slip in a 4k to get better performance.
  4. Change the plugs and at most the leads, sounds like a resistance issue for sure.
  5. Check the cooling system for a start and also check the intake hoses for splits, the adub I had was a pig to drive at 1st and I found a split in the intake.
  6. Trev
    Maxi
    22 is water temp sensor which will play with the start up.
  7. Sorry for the late reply, have to bail as I have had to spend money elsewhere but I may come out for a few hours.
  8. Sorry for the late reply, have to bail as I have had to spend money elsewhere.
  9. Trev
    Spotted Qld
    Spotted a white corolla II GP Turbo along the warrego at Tivoli yesterday, was on the side of the road with the cops behind it with what looked like smoke coming from under the bonnet, about 2 hours later I seen it (fairly sure it was) getting dropped a few doors down from my dads.
  10. Try the water hole behind you Tom.
  11. Trev
    Maxi
    I will have to come give you a hand again.
  12. All bigports are not the same, check the board to make sure.
  13. Forgot you had this tank.
  14. It is actually fairly easy, hardest part is finding parts to fill in the rear window.
  15. I like the grille, dunno why people would wanna remove the rear garnish.
  16. Glad I did the seat as the sedan seat clips can be an utter PITA, this way it just flips up, I took the cover off of the rear bottom seat and put it onto my spare seca base and had my mate fit some nut serts into where the holes are so I could bolt it all in. For the 2 door?
  17. YES, this time at low tide, scary as hell walking through the ocean.
  18. Mrs said yes, just gotta get another tent and whatever else I lost in the god damn flood.
  19. Sweet. Not a chance in hell, only one Trev here.
  20. Need to get out again, where abouts?
  21. Probably sounds good.
  22. Who the hell is this Trev?
  23. Since the board in it is most likely fubared you should try to wire direct to the light, I have some jewellery shop downlights here that I run off a 12v battery and they are bright as hell.
  24. Still got the blown one?
  25. Sorry Jono, I just clicked on the jaycar link you put up, I didn't realise that it also did capped the amperage, I thought it was just a voltage resistor.
