Trev
Donor
    6398
    29
Everything posted by Trev
  1. Are you scared now? 'inb4 your fuel lines are going to fall out and your engine will melt'
  2. I am thinking that you got the matilda 95+ ethanol :D I will have to give that a go one week in the ute as there are only 2 caltex servos near me that sell E10 91 where as there was a lot more.
  3. Do you always get 98 from the matilda?
  4. What servo? I have heard of this before where people claim that the car will run better on 95 than on 98.
  5. Sweet.
  6. Many turn up? I seriously thought this was mid year, even tried to organise dad to get me a car :laff:
  7. Pump still turning on?
  8. 4A pump is different.
  9. Trev
    Maxi
    LIKE LIKE LIKE LIKE LIKE. :fuzz:
  10. Mint Must be just you :laff:
  11. +1 to keep it as it is.
  12. 10k, serious? You could do it for <6k even if you buy brand new rwd stuff, a rwd manifold, aftermarket ecu wired and tuned, rebuild, fuel system etc, 10k would get you a really hot setup.
  13. Why does it take one day out of the year for people to go and be 'Australian'? why don't they just do what they do every other day of the year?
  14. Nah it has the heater control breaker and some plug areas, can get you a pic if you need one.
  15. ok. 1st pic: goes to passenger kick panel. 2nd pic: A/C inside the car. 3rd pic: Black 2 pin is A/C idle up, Not sure about the white one as I have never seen it. 4th pic: Yellow o2 sensor, white reverse, blue is A/C pressure switch (if you leave this in open circuit then the thermo will always run, loop the wires). 5th pic: Black plug plugs into the body harness. 6th pic: Black single is oil switch, round 2 pin is A/C fan.
  16. ^^^This^^^ CV's do not need to be removed, if you have the 6 bolt flange you undo them and move the shaft out of the way, if you have a stub axle then you undo the lower ball joint, pop the cv out of the gearbox and pull it all out of the way.
  17. That is mad.
  18. They are a different length but if you can drill holes then go ahead.
  19. The chev also went back to the AE82, I had some of the chev items for my 82 but it was damaged in the flood.
  20. Are you counting the pins used or the amount of locations the pins can have? 14 yellow will be the ecu 14 pn plug (yellow and not orange?) 10 yellow, I have not seen this before. 2 pin white sounds like the L/H kick panel wire. 10 pin black is for A/C IIRC and you don't need it plugged in. White 4 pin is for the wiper motor. Black 2 pin is the A/C idle up. 2 pin white round is reverse lights. Single yellow is o2 sensor. These sound like they are in the same spot. Need more info on the GREEN A/C plug. Blue plug goes to the little black box on the coil. Single black pin is the oil pressure sensor. IIRC the round 2 pin is the A/C fan plug.
  21. Or when the line of work you are in makes a touch phone useless as your hands are always dirty. I got sick of breaking phones, my latest is a $30 Telstra T100, it rings and stuff.
  22. Bottom is 12v ignition (12VIG), other is most likely the earth.
  23. Yes.
  24. On the calendar cruise we had so many cars that I was slowing/stopping traffic just so we could get onto the road.
  25. Brisbane area mega cruises died years ago but fark I would love this.
