towe001
Senior Member
    2563
    10
Everything posted by towe001
  1. Husband ??! Do you know something i don't..... ?
  2. At times i wonder if i'm having a permanent brain fart. Strut bar would be KE3x or KE55 or a custom made. AE86 wouldn't fit without mods. Stabilizer bar would be in the same boat. Brake upgrade - Corona struts and have a search on the forum on what model hilux that comes the four pot calipers and what vehicle to grab the vented rotors from. I know the good things about braided brake lines but if its for a street car is the extra cost needed ? And you most likely could do it for cheaper :P
  3. This camp this camp this camp
  4. He got you there got you big lol Edit - Damn Riley, you be quicker
  5. Or if you have a android phone with gps then download https://play.google.com/store/apps/details?id=com.binarytoys.speedometer That way you don't have to figure out diff ratios, tires sizes and other mathematical formulas.
  6. Question - why do you want the coil-overs ? What are you hoping to get from using them ? The wording looks abusive, but it's just questions to ask yourself. Steering arms (or knuckles) from the likes of the AE86, RT104 (or whatever the model is), T-18 and a couple of others share the same ball joint as the KE3x You'll need these steering arms from the said vehicles if you upgrade to the bigger diameter struts and the bearing plates (strut tops) from the KE3x Strut upgrade also brings in a brake upgrade but what struts you use will depend on what type of brake upgrade you'll get. Have a search. Stabilizer - as in the castor arm that goes from the radiator support panel to the lower control arm, it won't need to be changed. Strut bar ? Thats one i'm not sure of
  7. You know what i think :P The darkside has more pull then a pool party of wet teenie bobbers... Whereas the rolla would be the pool party, it'd be nice but you'd be fingering for something better.
  8. :lmao: Me thinks Reed just got owned
  9. You sure their '55 arms ? The '55 arms are shorter by about 20mm then the '20 arms. Looked good and felt sexy when i saw it tonight. Maybe just clear coat the primer and start a new trend :P
  10. Makes me think of the Godfather and waking up with a ..... I had the audio tapes of Pete's Dragon many many moons ago
  11. Just another typical camry driver
  12. I think the mirrors would look funny on the '70. Their too period for the car. Maybe something along the lines of what Reed has on his '70. Those are good photos by the way. The white slanty makes me motivated to do something on me wagon :)
  13. Drivetrain losses Poor straightline traction. Bad braking. And thats even before the drum brakes call it a day and go home. No traction what so ever for the inside tires in a corner. Should be a bit better now that its running bike tires. But i'd still hate to be those drum brake without water cooling.
  14. TA22 for master cylinder. If you have a look on the firewall near where the clutch cable is, there's two studs - thats where the master cylinder bolts to (just have to drill a hole for the rod to go through. The clutch pedal will have to be modified with a hole for the rod to attach to.
  15. On a Honda rim at that...
  16. Date sounds good for us
  17. Its not Trevs '20 if thats what your thinking
  18. Grumble grumble grumble :) Better do it soon, i've heard that one might be on its way back to the coastline.
  19. Good write-up. You have my mark of approval :2thumbs:
  20. :wave: Lounge chair racing And seeing who can evacuate the room the fastest when i drop my guts....
  21. Sexy. You can polish mine next.
  22. Just a few more photos to pass the time
  23. You think you lot have problems Over 294 accidents within 5 years from just 6 intersections. Pretty impressive in a sad way. And makes me want to get a second dashcam for the back window.
