Redwarf
Everything posted by Redwarf
  1. I have seatbelts if you're interested. Make an offer.
  2. This is Queensland, we don't have daylight savings. It fades the cows or something.
  3. Sleeeeeeepy I tell you.......
  4. You are all feeling veeeeeery sleepy.......
  5. Just when you thought you were alone..... :(
  6. Just finished downloading The Cruel Sea- Honeymoon is Over. Listening to everything from Glenn Miller Band (swing) to Van Halen, Steve Vai and Frank Zappa. I also have Rolf Harris doing Bohemian Rhapsody somewhere, too.
  7. Gee, this one snuck up on us.....
  8. You guys are, the collective "Man". :(
  9. KE25 windsreen is about an inch smaller in height than a KE20 screen. Definitely NOT interchangeable. Same for the seals. R
  10. What engine is it going onto, in which model Corolla?
  11. Hmmm, a Mazda Gearbox-Eater... :D
  12. I never said it can't be done :D, it just requires a bit of work. It's one of the reasons I have a 1360cc 3K :(.
  13. Mine has TA22 struts, I can't see the point in S13 struts.
  14. Just popped down stairs with the measuring stick and can confirm there is negligable difference between the two. :D
  15. No, the main difference is in the inlet ports. You buy the extractors for your make of Coroola, for the simple reason KE20 pipes won't fit on a 30 and vice versa. You would either need to match port your inlet manifold, or find a big port one.
  16. FYI, You can't bolt a 4K crank directly into a 3K. Some clearance work is required due to the larger stroke.
  17. A change to nylok nuts may contribute to the warm and fuzzy feeling, I have them on the Dwarf, so even if they aren't tight, thay either won't undo, or will undo slower than standard nuts.
  18. wank wank wank wank wank...... :D
  19. Mate, we live in Queensland, most of our houses don't even have a heater!
  20. Job done. :harhar:
  21. It'd be an excellent club car....
  22. Is this a 100 series corolla, or a 110 series?
  23. You could do club level motorsport with it, but you couldn't rally it, not with a 3t.
  24. That do be the number. For info: Repco sell the good Hardy Spicer ones under that part number.
