Everything posted by irokin
K50 Gearbox On A 3k-c Engine
FAQ is your friend: http://www.rollaclub.com/faq/index.php?tit...3K_powered_KE20
Who Makes Adjustable Camber Tops To Fit Ke55?
Sometimes definitive answers aren't out there and its up to you to find them out for yourself. If you do, let us know. Thats how this thing works.
3k Hotbox Experiment
Unless you've ported manifold and head to perfection, you're wasting your time. Bum dyno might tell you otherwise but its purely placebo.
What Grinds My Gears.
Don't upgrade to vista. You might as well unscrew the case and put a fragmentation grenade inside. 7shades: Windows 7 is coming soon. I think you'll like it. Its like windows vista...but it like....works! :) Strange that microsoft gets rid of Bill and suddenly theyre capable to churning out quality software...
- 4ac Or 4k?
1jz Ke55
ANYTHING can be put into ANY car with enough custom fabrication. There isn't much of a KE55 underneath there anymore. Cool none the less.
Cool Cars That Aren't Rolla's
You cannot appreciate this car until you see it in action. This is WITHOUT the ATTESA (4wd) working. I have no doubts that this car will lap as fast as a V8 supercar.... on semi slicks.
They can set the cameras to whatever the officer in the vehicle at the time decides. If hes decided to be an ass s/he can set it below the speed limit. That doesn't mean you'll get booked though.
Which Exedy Clutch To Get For Jdm 4age
Yes cushion buttons too. The difference is the cushioned button will actually slip to a small degree... then promptly chatter like mad. I run an exedy cushioned ceramic button in the silvia.
Ceramic buttons are NOT fun to drive on the street. If you intend to drive the car as a daily I would advise you look for another option. If its just going to be a weekend warrior just beware that they can be temperamental. The clutch chatter is very capable of destroying gearboxes if you don't know how to manage it.
Sr20 Ke35
Not a whole lot, the SR20 is not a big motor. About the only place you're going to have to compromise is with the transmission tunnel. The gearbox is sizey and you may have to position the motor further forward than you'd like to allow enough clearance without massaging the tunnel.
If Top Gear's cool wall has taught us anything, its that a car doesn't have to be practical or useful to be cool.
Suspension... Everyone Has Already Asked!
Yes, really.
Sr20 Ke35
I wouldn't think so. You'll definitely need custom engine mounts though.
Diagnosis Of Problems
Quite the contrary. Iridium plugs are fantastic for turbos but they're perhaps not suited to your engines particular ignition system. Some engines run great on coppers, some run great on iridium, just need to find what works on your engine.
Custom Chaser Rims
Dude, please, do me a favor and take at least a few seconds to check your spelling before posting.
15 Inch Hyundai Elantra Rims Will They Rub Against My Ke55 Strut?
PROBABLY!!!!111
- Region Leader
Feels like every second kit car made is another bloody cobra...
Not Enough Spark?
I'd be gapping them properly, at a guess probably to something like 0.040. Also whats the heat range of the plugs? Its possible they're too cold. Just to give you an idea how much voltage turbo motors have for spark, the SR20DET coilpacks produce about 40,000 volts.
Not Enough Spark?
Whats your spark plug gap?
Underground Garage Projects
Very nice!
Hey I loved the BTCC 850 wagons :y: My contribution, don't forget Le Mans is on this weekend :hmm: Porsche 911 GT1 '98
Bmw E30 Shockers In The Rear Of A Ke55?
If you do it right the first time you'll probably end up saving money instead of dicking around with other setups and eventually ending at the same conclusion.
Core Plugs And Acid Dipping
Just FYI, engines aren't actually put in an acid solution, its a strong alkali so base your decisions on that. Any metal thats going to degrade in an alkali will need to be replaced. Probably the main metal to look for that will be adversely affected is aluminium.
