B.L.Z.BUB
    8270
    155
  1. http://www.rollaclub.com/board/topic/62621-ke70-pajero-master-cylinder-upgrade/
  2. Externally reg ones are the devil.
  3. Yeah 2 years old now. Picked up 2 heater taps and a door hinge. He had handbrake cables but didn't know if his mate who wanted them was 100% so couldn't get them. I'll just get them remade. That rear tie rod inner though. I don't want to have deal with Toyota for it. Maybe I'll shell out 200 odd for aftermarket.
  4. It was the ladies screaming as he drove past.
  5. Got under it tonight. The handbrake cable boots are gone and the lines are full of crap. even soaking them in WD40 didnt help. The LHS rear inner tie rod bush is gone, and a replacement is looking hard to find, there wasnt one in the poly kit. Trev sorted me out with a heater tap. Gonna need new copper washers for the oil return line.
  6. This will probably be massive https://www.facebook.com/events/790488994381031/
  7. Anywhere but Sydney :P If you like electronic music then definitely check out Home nightclub. http://homesydney.com/ I used to go there with my mates a lot. Lots of different rooms with different electronic acts. Bondi Beach isnt that great, its dirty and gross.
  8. Not too bad. Leak from the oil return from the oil cooler and maybe the dizzy but I'll just steal the KE70 dizzy as I put new seals in not long ago. Found a guy in Ipswich who can hopefully supply me the handbrake stuff. Already have a full poly bush kit. Hopefully I can sort this all out within a week. While the guy was inspecting it we came across: Hub to strut bolts loose Coilover lower base height locking ring loose. Front sway bar link pin bolt loose. Basic shit that should have been done right. can't believe I drove on it like that. EDIT: Awesome bloke though let me borrow his shop tools to sort it out. They get a 6 pack when I go back.
  9. Spent the afternoon tidying it up for RWC inspection tomorrow. Hopefully its all good. While I was at it I replaced the drivers side electric mirror motor cog. Now it doesnt sound like a printing press going up and down.
  10. https://lh5.googleusercontent.com/proxy/2BKuHaCOTOjyp6cDAkj_wdTbW3YXq_WhASr3adaDUnaAHkYhECISF9t7Mfn2-clEB9IYfok8NbJjxXnuJhSnbdhuhcg6cJHo9scmgTXjVxIuHtir0IMMRyKu8VW2wf4fHK02enAJpotGXB3vwg=w301-h401-nc Engine bay fuse box. You'll probably find its fine and it's the earth's in the ignition that are worn out. You can do a starter motor relay upgrade pretty easy. Similar to this, http://autofix.com.au/blog/fitting-an-auxiliary-starter-motor-relay
  11. Aussie states or USA states? Because we can't do shit in Aussie.
  12. On street cars.
  13. Definitely needs a front lip/splitter. Supposedly the guy I bought it off is gonna supply bolt on flares so lower is definitely a possibility, with some better wheels. Keeping this one N/A. Come take it for a spin and you'll understand. Spotties are a bit iffy for me, was thinking of trying to mount them further back. But I'll probably never use them so will most likely be removed.
  14. Some DSLR pics for everyone. Light wasnt the best plus I think the lens was a bit dirty.
  15. I'll try do some decent pics with the dslr at some stage. We never used the ke for family stuff, the only times was when she broke down. She now has RACQ so I'll never have to go rescue her hopefully. Plus she's got the Rav4. And she's pretty cool with this sort of stuff, as long as it doesn't take money away from necessities.
  16. Considering people put aircraft landing lights in their cars nothing surprises me.
  17. I keep seeing the question being asked. I just wanted something handy to link to.
  18. Lay it on its side and fill it with solder.
  19. Just wanted something to easily link into these posts on FB. Nobody bothers reading the NCOP.
  20. Drew Edward Thompson‎Rollaclub.com April 7 at 2:52pm · Kilcoy · I got a question for everyone? Is it true you can put a 4age into a ae71 with no mode plate cause it's a bolt in engine and their is no need for modifications done. And if so does that mean you can put one in and drive it on your red p's. Also some people say it's calassed as a EFI or something, just confused. Craig Tregear The E means EFI (I believe). The C in 4AC is for carburetor (sometimes the C in Toyota engine numbering means Californian emissions). Craig Tregear You just need to be careful about the difference between no modifications requires and production option (as I don't think Aus has AE71s with 4AGEs), there's a lot of fine lines. When I put a 7k into my KE55 I got told several different conflicting stories from the Victorian RTA. Drew Edward Thompson Yeah I understand, that's why I'm confused and trying to get everyone's opinions. I've looked on the government site and didn't say much about it Craig They probably don't know themselves. In my case the 7k is basically the same and bolts into a KE (with a different sump), but it was never offered as an option. Some people said its fine cause it's the same family of engine, others said it wasn't cause it wasn't an offered upgrade in Australia, others said it was fine cause it was still within the power increase thresholds. Drew Edward Thompson Yeah I know I got told that yeah because it's the same family and it bolts straight in and it's under power weight ratio. Cameron Williams Its a grey area. Technically you should get an engineers cert/modplate because a 4age is 40%+ power increase over a 4ac, and 4age sprinters ran much better brakes than ae71s. However in practice, in victoria, no one cares. Ring the rta if you want a proper yes/no answer.. and make sure you get it in writing! Drew Edward Thompson Ok sweet thanks Cameron Williams Going to do this exact conversion in a few months. Ill let you know how I go Drew Edward Thompson Alrighty sweet thank you Cameron Jamie Bainbridge And just for the record, a 7K into a KE2/3/5/7 is not just an engine number change, it needs to be engineered due to the capacity change. Jamie Bainbridge The ADRs also state that *any* increase in engine power must also accompany an acceptable increase in safety such as braking. That's very unclear an open to interpretation. If I was doing a 4AGE into an AE71, I'd get it mod plated just for piece of mind. It's only a few hundred bucks and you've then got the paperwork to prove it's legit, no worries. Drew Edward Thompson But then u can't drive it on your p's cause it mod plated Jamie Bainbridge So drive it around with the 4AC for a while. Do the brakes, suspension, bushes, wheels, tyres, cooling, interior, etc. Make it a nice car to drive. Collect the bits for your conversion and be ready when you're able. There's lots more you can do to cars besides engine conversions and an old Corolla probably needs heaps of major and minor things fixed. Drew Edward Thompson Yeah. Ben Lugg A mod plate cost me like 50 bucks per mod. Don't be a jew and just get it done. Just saw you're on your P's. Understood if not possible. Drew Edward Thompson I would get it done, I don't think I can drive the car a with a mod plate because I'm on my p's Jamie Bainbridge You might have the expectation that a 4AGE 70 will be quick, but really it's quite slow compared to many things on the street and even in amateur motorsport. You'll also be wasting most of your power if you don't have an LSD, good suspension, and good tyres. Get those sorted and you'll really enjoy driving your car, probably more than you would enjoy an otherwise stock car with an EFI conversion. Jamie Bainbridge Be patient, do it properly, piece by piece, and you'll have a car to truly be proud of at the end of it. Patience Luke Adlam It's got nothing to do with being a bolt-in unfortunately. Using Subaru as an example, all of their engines use the same mounts, so any EJ motor will bolt into any EJ car (almost every Subaru from 1990 until the BRZ), but obviously bolting an STi motor into a base model Impreza would be stupid unsafe due to the tiny brakes. To avoid engineering requirements the engine you're putting in has to have been offered in THAT chassis that was SOLD IN AUSTRALIA, and you must upgrade brakes etc to match those used in the car the engine came from. Cameron Williams there is a grey loophole in this case. very early bigport 4age's shared a bit more in common with the 4ac than later versions, ie 6 bolt crank and 3 rib block. so get some high comp 4age pistons (18mm pin version) and a small port top end, and put it in/on your 4ac block. that way, technically you havent changed your engine. the fuzz *could* try to get you for having too much power, but a few sneaky exhaust mods before a dyno test would ensure it passes the power increase test Drew Edward Thompson That is good Bronson Mercieca Geez you sound like a dodgy bloke cameron! Dean Heywood OK so how will I go with 7age ( 7a with 4age head and pistons) in to ke30 2 door sedan @ 730kg in Vic? Cameron Williams your screwed without a engineers cert Dean Heywood Thought so, planned on it anyway as well as many upgrades to brakes etc Cameron Williams sounds awesome! Brett Azzopardi The 4age power is greater then the 4ac so it's classed as a performance mod so yes it will need to be plated. Will also need to be plated for the fuel system since it is now efi from carb. As for being allowed to drive it on ur p's there hasn't really been a straight up answer, as it's still within the power limits that ur allowed them in that regard u should be allowed too. Drew Edward Thompson Thanks Brett Ripley Newt Hicks You need a blue plate for a 5k from a 4k. Pretty sure a 4AG from a 4AC is needed. But who knows there are P plate warrior voodoo magic happening. Brett Azzopardi On saying that, if u don't drive like a twat, have the car at a normal height and not to loud then u shouldn't have a problem. Jordan Teichmann I have a blue plate for my 5k swap Ripley Newt Hicks Put the engine in your car. Run the risk. Learn the outcome like the rest of us. Drew Edward Thompson Yeah haha. Bonnie Thomas Insurance companies probably look more favorably upon documentation. Food for thougt. Ripley Newt Hicks Insurance? Christopher Best I've ran a 4AGE in my Aus sprinter for like 6 months now. I get away with it by not getting pulled over. Bobby Kirkman I went in to the department of transport with a receipt for the engine and filled out a change of vehicle particulars form and it was done just like that.. no mod plate needed coz capacity isnt changing from factory.. still 1.6.. Joel Weiley So true Bobby Kirkman if its a ke70 with a 4age it has to be engineered Bobby Kirkman That is correct Joel Weiley as its only a factory 1.3l.. a 4a (c or ge) is a 1.6l so the capacity is increased thus needing to be engineered/mod plated Joel Weiley If you look on the complaints plate and rego papers engine number starts with 4a123456789 Bobby Kirkman Sorry, what? Your engin does? Jamie Bainbridge He's saying you can swap any 4A for any other 4A but as we discussed above that's not right. Bobby Kirkman In nsw or qld man? I took a 4ac out of my 71 and put a 4age into it, walked into the d.o.t with a receipt for engine and that form i mentioned earlier and it all got changed over in a matter of minutes.. they said nothing about a mod plate because the capacity hadnt changed.. Ripley Newt Hicks Just because the idiots at DOT don't understand the law doesn't mean doing it is legal. Bobby Kirkman I checked the table on the qmr website that Cleary states if the capacity is the same or with in a small tolerance then a modification plate is not necessitated.. Bobby Kirkman Ill find it and post it up man.. thats how i interpreted it anyways but yea let me know how you and others read it aswell Cameron Williams don't bother Bobby. ill post the NCOP rules, which applies to QLD/NSW/VIC (maybe other states, not sure) that states your wrong. Go to page 17, paragraph 1 and 2. Cameron Williams http://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/pdf/NCOP3_Section_LA_Engine_01jan2011_v3.pdf Cameron Williams shittest 4age is something like 40-42% power increase over the highest spec 4ac. Bobby Kirkman Ok cool man.. will have a read.. I'm not trying to argue or say that I'm right and your wrong.. i was just giving the information that i used and have had no issues with so far.. you can untwist your knickers now mate Cameron Williams trust me dude, i don't knot my jocks over facebook. however if you had done you're homework in the first place we wouldnt be having this conversation Ripley Newt Hicks Reading is hard Cameron, information on Facebook is easy. Bobby Kirkman I didnt get any info of facey man.. like i said, just offered the info on what i used as per the question.. but that link is quite helpful and clear haha.. cheers man, will now cross my fingers untill i can get it plated.. Cameron Williams like everyone has said here, don't drive like a dick on the road, don't have an obviously unroadworthy/overly lairy looking car, and you shouldnt have a problem with the fuzz Bobby Bobby Kirkman Cheers dude Ripley Newt Hicks Most cops probably won't care but all it takes is one switched on one who just had some other wanker mouthing off at him to decide you're the person who's day he's gonna ruin. Bobby Kirkman Yea ya see it all too often hey man.. and once theyre on a power trip, good luck!! Like · More · 8 minutes ago Jamie Bainbridge You're interested in the section LA2, specifically upgrading "Brake System" and "Occupant Safety" when increasing power more than 20% over factory. You'll notice these apply even when making changes to a stock engine, as well as a replacement engine with more power. Brake modifications have their own modification category LG. The entire code of practice for light vehicle modification is at: https://www.infrastructure.gov.au/roads/vehicle_regulation/bulletin/vsb_ncop.aspx Ripley Newt Hicks I'm gonna cut and paste this entire thread into a post on Rollaclub so I can link it whenever someone asks.
  21. Cheers mate, it's been a struggle. But good news, detailed it, threw my daughter in the passenger seat and went for a spin. It's driving and sounding great. Loving the pop put sunroof. There was a lot of what I thought was faded vinyl but it just turned out to be human scum and it cleaned up pretty well. I'll have to grab some interior pics. Also need to get on to putting in these poly bushes to tighten it all up.
  22. You should try to remove the malware/adware on your computer too that inserts those links to keywords.
  23. It was hunting at idle but turned out to be a sensor I forgot to plug back in. Running 100% now. Pretty happy, just need a Rwc now. Bonus picture.
  24. Both are reliable, but I'd always trust a Toyota over a Honda. Corollas are like pizza and sex, even when they're bad they're good.
  25. Seriously wishing I didn't have that 5th beer know. Went for a quick squirt around the block and that was fun as ʞ©$ɟ.
