B.L.Z.BUB
    8270
    155
  1. 10am At the Gap BP. 26th Cruise over the hill PM me or whatever https://www.facebook...ry_type=regular
  2. A: I want updates on here regularly so I don't have to put up with FB crap B: Carry on EDIT: C: Still have an SC12 for you to borrow and will have a Niteparts bell soon
  3. Just pop the interior panel off. you might be able to just remove the latch bolts and kick it open.
  4. Hopefully its just a matter of replacing the hatch.
  5. This was on Gumtree in Noosa?
  6. Twin superchargers? That'd be a bit parasitic wouldnt it? Better off twin charging or do what I did and throw an SC14 on. If you need SC12's I have 2 for sale.
  7. S2 full bolt in swap, you just need the rear half of a T Series drive shaft. S1 is identical bar the sway bar mounts, though you can weld on ones from your old diff or there are bolt on mounts you can buy from Whiteline etc.
  8. Awesome, I was watching these but forgot to subscribe and couldnt find it again.
  9. You need ke70 strut top. You need custom springs or weld the lower ke70 spring perch on the xt130 strut. You can use the ke70 spring with the lower xt130 strut perch but its not ideal. Edit: or convert to coilovers
  10. Looks good DJ, white on blue always does. Suits it. You gonna finish the bodywork properly or just whack some stickers on it and slide?
  11. Sheeeet, did you not know about the bog? Damn. Is it full holes patched or just dents? Id still buy it probably, my ke70 is fun with boost I can't imagine how much awesome sketchy fun boost would be in a 10.
  12. I really wanted to buy this. Glad I didnt. Hope you got a deal because the price was a bit extreme.
  13. Ah ok, might be the same one, I just remember the one I saw because there was something up with the bonnet.
  14. Did it have a black bonnet? Pretty sure I saw this out in Ipswich one day.
  15. Have you asked your cam grinder what they reccomend? That would be your best bet. Cams a ground to work on specific set ups.
  16. Exactly my issue. I want to use one but hide it in my inner guard to keep things legal. Cheers for the info! May need to move the washer bottle to the LHS guard
  17. Matt do you know of a compact one thats easy to hide?
  18. I just ran a hose to from the line to my chassis rail and feign ignorance when pulled over.
  19. Was gonna try with mine, the effort probably wouldnt be worth it. I'm deleting mine anyway.
  20. Its there to release pressure, if you block it off the pressure will push unwanted fuel into your engine.
  21. Could you separate the mirror from the mounting stalk and attach a KE70 mirror?
  22. You could try heating them up with a blowtorch.
