B.L.Z.BUB
    8270
    155
  1. I taught myself off the internet. Just googled heaps of shit. Read a bunch of diagrams.
  2. 200 dollary-doos! Score!
  3. Stick an AE71 tacho dash is and hook this wire up to the negative side of your coil.
  4. Do the suspension and brakes first. No point making it fast if you can't stop.
  5. Defs a better option. buy an entire engine and drop it in. A 4AFZE isnt the most ideal option.
  6. Oi, I'm trying to sell parts here.
  7. There wont be a kit to suit a 4AFE. You could try and retrofit a 4AGZE SC12 onto it, you might even get lucky and it might bolt on. As for controlling it you'd probably just have to have the electromagnet clutch controlled by an in cabin switch. I am currently selling two SC12s :y: EDIT: people make 7AGZE's with a 7AFE block, I'd assume they are similar to 4AFE blocks, and the SC12 gear bolts on I'm pretty sure. I have mounts, tensioner, crank pulley etc.
  8. Give Ranko_87 (Andrew) at Southside Suspension a PM/call. He supplies Superpro bushes and he is a site sponsor. :y:
  9. I'm not even an Aussie and I was cheering for him. Definitely some raw talent there, its so good having so many people who can win a race now.
  10. Looks great, *E1*'s look awesome in red.
  11. No, we don't offer club rego. Try Toymods
  12. Go and see or ring up an engineer local to you. Best bet is to get the information from the horses mouth instead of internet hearsay.
  13. Itd be classified as a performance upgrade so would need to be modplated and the engine would need to be registered to the chassis.
  14. You need the AE71 engine cross member too (unless you buy KE Conversions 4AGE into KE70 engine mounts, comes with gearbox X member also), plus a hydraulic pedal box, plus clutch slave and master, banjo fitting for the clutch slave, AE71 tailshaft (unless you use a T18 gearbox). RWD sandwich plate.
  15. Fusible links can blow but still look good on the outside. Had it happen to me.
  16. Wow. Time to find a donor shell and cut out some sections.
  17. Look up 'KE Conversions' on Facebook, he does mounting kits. He's on here too, his user name is Jordanrolla.
  18. Yes, look up 4AGE into KE10, exactly the same process apart from wiring. May as well go 4AGE if you're gonna bother.
  19. Get proper guards and bonnet. Too much hassle otherwise. Also the lights wont bolt directly into the rad support, you'll need to weld in a flat front one or drill new holes. EDIT: You'll need the flat front apron and cowl too.
  20. Thanks mate , any info to narrow it down helps.
