February 23, 200917 yr comment_321747 WOW well note to self wont expect any great economy with my setup..LOL Also Stu did you rebuild your 5K before putting EFI on it etc? I am rebuilding the 5K I'm using so ill have to see the difference. Also Your D5 being analogue for the TPS does it jsut sense on or off or the whole range of movements? Just curious as if it is analogue like a 4K-e ECU well there can be huge improvements there to improve economy. Also what compression ratio do you run in your 5K? But all in all NICE setup would rocket in a KE11 and would of been easy to do a loom adn fuel lines as KE11 so easy to get to all wires etc. Also I take it you run a battery in the boot now? Cheers Cameron Report
February 23, 200917 yr Author comment_321754 No the engine wasn`t rebuilt when i efi`d the 5K. But was reringed and a cam put in it when my boss had it. i finnished and drove that for 2 1/2yrs and put about 10,000km on it then it was ready for boost. I`ll put forgies in it When it decides it needs them. Comp is from what Madrolla68 tells me"as i was tooo lazy to measure myself" is about 8.2:1 static. Thats using std 5K bowl top pistons with a 4K flat top piston cyl head. T.P.S i think only tells it to get off idle circuit. But not too sure. Yeah webers4x48 wired in the D5, its 10 wires from memory. The battery is in the boot as the KE-1x bay is too damn small stu. Report
February 23, 200917 yr comment_321801 Bare in mind that was basically 2 hours on boost Cam. :hmm: Bit over 20L/100km I could have drank twice that much in my mazda. :no2: Report
February 24, 200917 yr comment_321848 Thanks to Medicineman these are your photos from the GOR was good to meet you. Any chance of some enlarged photos? Thanks. Sam. Report
February 24, 200917 yr Author comment_321875 Any chance of some enlarged photos?Thanks. Sam. Yeah i have a heap of pics from the EFI conversion. I have to get my phone to syc with my pc. Or find the sd card adapter. hopefully tomoz. Si, Thats out of the rolla thought you were talking about the rota at first. If gearing is same as mine i sit on about 3,400rpm at 100km, which is on boost and just when cam kicks in. Not a receipe for good consumption. :hmm: stu. Edited February 24, 200917 yr by kickn5k Report
February 24, 200917 yr comment_322059 All i can say is braaaaaaaaaaaaaaaaaaaaaaaaahhhhh... pshhhhhhhhhhhhh! Seriously though, this thing hammers :hmm: Report
February 25, 200917 yr Author comment_322400 Should have some realistic torque figures within the nexts two weeks. Toymods have a dyno day on! The dyno that will be used is a different brand to the one i use, so we will see. Report
April 1, 200917 yr comment_333130 Again, I ask for pictures. Give me inspiration! The charger i just paid for the frieght etc. Also, can you direct me to where SC12's can be purchased from for the cost of freight?! Anymore updates on how the setup is going? New ECU yet? Sam. Edited April 1, 200917 yr by rollapv75 Report
December 23, 201015 yr comment_490032 Bit of a long shot, but... Any updates? :D Happy B'day by the way. :y: Edited December 23, 201015 yr by ewt Report
December 23, 201015 yr comment_490039 Update? Stu? Never! Actually, he should have a big update coming soon... Hopefully soon anyway! JP Report
December 25, 201015 yr Author comment_490506 Ha yeah cheers for the b'day wishes. Not such a long shot have a fair few updates on the go. I'm sick of the car bump steering so bad it prob looks like I'm drunk, so thanks to mr nobbler I'm going back to ke-1x strut bottum and lifting the front about a half to an inch and bringing the lca and steering angles a bit nicer. Oh and going from 5kze to 5kte using a t28 bb turbo and stupid build on engine. Maybe a colour change and retrim if the budget allows. No pics as yet but will get em up while Ive got time off. Stu Report
December 25, 201015 yr comment_490545 You really need to get a decent vid of this beast before you pull it down again, it sounds nuts! 20b crossed with a NASCAR! Get into it Stu! Report
December 26, 201015 yr Author comment_490585 You really need to get a decent vid of this beast before you pull it down again, it sounds nuts! 20b crossed with a NASCAR! Get into it Stu! Ha yeah The guy doing exhaust manifold came bolting out of his shop thinking it was some boosted small block v8 rocking up. Get into what with this time of year I'm waiting on laser cutter bloke for my car and radiator bloke for the dirty datto. I have been enjoying it a fair bit more last couple of months it still puts a huge grin on my face. Stu. Report
April 14, 201115 yr Author comment_517069 Well I've pulled the 5k out of the rolla and the bores look overrated. So I can keep it STD bore and keep a bit of strength in the block. So now the new setup will be: motor: 5k sps forged pistons spool conrods o ringed block arp head studs big dollar cylinder head induction: 28 series roller turbo off jdm s15 custom steam pipe exh manifold with 38mm tial external gate custom alum inlet manifold haltech e8 or e6x ecu other goodies: relocated alternator to other side of engine custom catch can and overflow. Let's see how long the import k50 and STD diff last at 25+ psi haha. Stu. Report
April 14, 201115 yr comment_517073 Well I've pulled the 5k out of the rolla and the bores look overrated. So I can keep it STD bore and keep a bit of strength in the block. So now the new setup will be: motor: 5k sps forged pistons spool conrods o ringed block arp head studs big dollar cylinder head induction: 28 series roller turbo off jdm s15 custom steam pipe exh manifold with 38mm tial external gate custom alum inlet manifold haltech e8 or e6x ecu other goodies: relocated alternator to other side of engine custom catch can and overflow. Let's see how long the import k50 and STD diff last at 25+ psi haha. Stu. All I can say is... LATERS BOX AND DIFF! :P Can't wait to see this all together man. Also, when can I come get the 4k head? Cheers, Jake. Report
