Taz_Rx
    6796
    54
Everything posted by Taz_Rx
  1. Ageed. If you only want it as a cruiser and not a weekend track warrior then I think the above would be fine. It's also pretty similar to what I have now. I did think about giving you the whole "did you search first" spiel, but then thought that most suspension threads are about track/drift car setups, ands hence this whole "middle ground" setup doesn't really get covered too much.
  2. 4-5" is just stupidly low. Any form of "suspension" travel would be in YOUR SPINE as you'll be sitting hard on the bump stops. 2"s in the rear is more than enough. Anything more is only "poser low", illegal and dangerous!!!
  3. Dirty nissans :n: If the Starley is getting the 5ktze then get stuck into that shit. You know you loves K's more than SR's!! :locked:
  4. Yeah sounds good: Front - kings super low with AW11* (from the rear) adjustable shocks Rear - re-set leaves/reversed eyes with AE86 short stroke adjustables Then everything will be nicely matched. *The body of the shock is shorter than the strut tube. This can easily be retified by packing it out with some washers. :locked:
  5. Have you accounted for the slight curve in the parcel sheft? A flat piece of MDF is going to give you nightmares trying to fit it back in!! As for the stereo - Yes you'd be right in assuming there's no permamnent power. The yellow and red wires must both be hooking into a accessories power source.
  6. Yeah but I bet the sticker doesn't say "15* won't work"!? Evan is correct in stating this is bs. :locked: That might be a good idea. :n:
  7. Was hoping there would be a pic in the paper but only a real small article on it. And on this mornings drive to work - Somebody blew up the ATM in the front window of the capital chemist in Newstead. Baracades and cops everywhere and the whole front window is gone!!! :locked:
  8. I didn't see this thread last year. Know its probably not too much use to you now (if you have the maserati carb) but the Peurto Rican's run blow-through side draft webers running 8-9 second quarters!!! There's a thread sticky'd in this section just below the tech articles with lots of pics. :locked:
  9. ....and I use that to my advantage: Rego for a 1.3l tax return kilometre allowance for a 2.6l :y:
  10. Just saw this on trademe - so I'll move it to the ebay section later. Appears to be another 5k powered vehicle which I didn't know existed..... http://www.trademe.co.nz/Trade-Me-Motors/C...n-258813607.htm Sort of looks like a predecessor of the bonneted KR twonaces.
  11. Not a rolla...... but spotted a soft-roader (I think, bit hard to tell with a flat roof) ON ITS LID at the jelley-bean roundabout at the bottom of QV this morning. How the hell do you manage that!!!! :y:
  12. Could find one this morning. Though I was in my work clothes and didn't want to get all dirty, will have a bit more of a look tonight. I'll definatly have one (aswell as anything else from the underneath of a KE36 if you're interested in anything) early next year when my wags gets dismantled.
  13. Yeah good point Tom!! :y:
  14. There was no holes at all in the side brackets to mount it, so we just drilled them where we needed to. Think this is mainly because they're to fit RX2 through to RX5, but saying that they're also not really any different to a gen1 rad. Yeah the have thermo fan mounting points (can see in ebay pic) which were supposed to be spaced right for a Spal, but some AR.com guys have found they're not quite right. I haven't done anything about my thermos yet as I have twin 10"s and need to make some extra brackets. It was pretty easy to fit with 1 excepting - The hieght of the cap!!! If you sat the ASI in ontop of the oil cooler the top of the rad sat pretty much at the same hieght as the original, but the cap sat up an extra 30mm or so, causing it to foul the bonnet. Got around this by basically V-mounting the oil cooler to drop the rad down a bit further. I plan to mod my stone tray a bit to make room for this so I can straighten it back up, but I might wait a bit and get an ASI alloy oil cooler before doing this. I might have to take you a pic or 2 of my engine bay. :y:
  15. But a CA18DET is ok!? :y:
  16. You'll be suprise what a couple of hours with some wet and dry sand paper will get you!! Polishing is just the last step to get it shiny and finished. Just like painting, all of the hard work with polishing is in the prep work - Ie finer and finer grades of wet and dry. :y:
  17. Try 15x7 in +15 :y:
  18. No worries on the K rad, for the price you wanted it should have been sold by now! :y: I did a bit of research on ausrotang about the asi before I bought mine. There was group buy done a couple of years ago and quite a few guys had cracking cores etc. All of the post group-buy (ebay) ones seemed to be of a lot better quality, or they just got better at making them and mines all good. They're now also being shipped out of melbourne, not china so there's a possibilty you could even inspect before buying.
  19. Taz_Rx
    My Ke20
    I have TE27 bolt ons on my KE55 which I got from...... http://www.mmsport.com.au/index.php They're not listed on the website anywhere but ring them and they'll send you a set. :y:
  20. Think she just topped it up. Did you work out where the fluid had gone? Ie do you have a trail of bubbly paint under the master? oh and did you think those $25 autobarn jacks were to cheap to pass up too!!? :y:
  21. Reckon I'd still have one laying around somewhere. I'll double check tonight and let you know. :y:
  22. Watch the start of this vid.... http://www.youtube.com/watch?v=YHOX3deFhbw...feature=related :y:
  23. Forgot to add in my other reply - Funny your speco temp guage reads 10* high, mines around 8-9* too low!!! Thats compared to my digi hand controller read out which I'm more inclined to believe. PWR's are good, but also soooo bloody expensive. I recently got one these ASI rads for mine... http://cgi.ebay.com.au/RACE-alloy-radiator...=item45ef7afb37 They're still a quality product, tripple core and 4 pass. I haven't done a whole lot of driving on mine yet but haven't had any issue at all. Just some food for thought as they're about a 3rd of the price of a PWR. And while on the subject of rads - I'd love to take that k seies one off your hands if you've still got it (for my 4x4 project). Only prob is I won't have any funds for it until next year. :y: see what having kids (and a missus working like 8 hours a week) does to ya! Not much money for cars left. Let me know if you've still got it then. :P
  24. The fins just give extra suface area to disperse heat - just like an air cooled 4 stroke motor bike would have around the head. But considering the rocker cover.... sorry "engine hat" doesn't get overly heated I personally wouldn't bother. http://cgi.ebay.com.au/CHEVROLET-POLISHED-...=item414b4af37d
  25. Yes they will...... depending on what offset they are.
