Taz_Rx
    6796
    54
Everything posted by Taz_Rx
  1. :P Will be intersting when you get it on some different rollers then. Do you know if the place with the AWD dyno regularly calibrate it? Yeah 17lt/100km is getting a little rediculous for a 5k, I probably get better than that in my 13bbp rx4!!!! :P Never really worked mine out (bit hard with fuel cell and no fuel guage) but I reckon it would be between 10-15lt depending on how you drive it. What size injectors are you using? Matt and I both have 7mge 315cc items.
  2. And I just put some pictures of an A-K50 in the A series gearbox section of the FAQ. :P
  3. Bloody big ports!!! :P Good to see you have the bigger valve below them to make them worthwhile too!!
  4. Good to finally see some pics. Torque from this things is pretty amazing!! :P You made well over twice what mine made - bout 180nm'ish How long you going to keep the D5 for? That'd probably be your biggest restriction.
  5. So is that a serpentine belt!? :P
  6. Just saw on the news that Tony Quinn beat Jimmy in Rally Tas today (GTR vs GT2). Targa's going to be a bit more interesting this year I think!! :P
  7. lancer and laser wheels will fit (pcd wise) but the offset will be all wrong. The laser wheels will also foul on the centre hubs on the back without spacers.
  8. yes you can swap it straight over.
  9. Nah that was the first I'd heard about it. Not good news unfortunately!! :dance: ........ http://tasrotary.6.forumer.com/viewtopic.php?t=434
  10. Checked its not coming out of the heater core somewhere?
  11. luck you didn't buy a gilmer drive!! theres bugger clearance between the pullies and rads compared to a 55!
  12. Yeah they are "that guys" extractors. (admin mods don't like his name put up here) The brand new elec dizzy would also be from him too.
  13. Does it have a cam in it? Don't expect it to idle at 500rpm like a stock motor if so.
  14. You be suprised how much noise from a diff can travel up through the drive train and sound like its actually a problem at the front of the car. Like whats been said, jack it up and check the diff/tailshaft/uni joints, then move on if you don't find anything. :dance:
  15. You do realise you can buy brand new starter motors from Ashdown Ingrams etc? I ended up paying $200 (trade) for a reduction starter brand new (5kj). :dance:
  16. I think most the cable operated K-T bells in Aus are from the KE35's that had a T50. The KM series liteaces (with 4k's or 5k's) had the K-WX0 bellhousing, not T. x2 vids/pics/dyno graphs. 180rwkw is a pretty big claim! 7k or not.
  17. Well I was on the right track re the reverse plug, it green and female..... but obviously not it. I'll double check on my car, but I think my BB low level indicator has 2x wires. :dance:
  18. They're not that much different. Stick to the "principals", not the "directions" and you should be fine. :dance:
  19. I'll cut and paste what you've written about the rx7 on Tasrotary. :dance:
  20. http://www.rollaclub.com/faq/index.php?tit...eries/Gearboxes :) Weather the celica had a cable or hydraulic is IRRELEVANT when you change to a K-T bellhousing. Your biggest drama will honestly be finding a K-T belhousing.
  21. I hate you too SoulSearcher! :) I listed the Martini Homologation version as my pick in the "dream cars" thread. :wink: So how did it go?
  22. Yeah Quinton (among others) owns/ed it. Not sure if he still has it obviously.
  23. You where the lucky ebay bidder then!? :)
  24. 2x speakers only need 3x wires, as the 3rd is a COMMON earth. There may be an extension that plugs onto it to each speaker. See if you can't find any other wiring that could be for speakers. Can garentee that single wire is aircon. :) 3rd (and possibly 4th) wires in a 55 are for the 4th gear (and possibly 5th) trigger wires to the carby for cruising duties. Where does the wiring from your GB go back into the loom?
  25. Photo I was just emailed titled "You couldn't get a more Australian image.." :)
