Taz_Rx
    6796
    54
Everything posted by Taz_Rx
  1. What is the actual problem with the bonnet? And how is it any worse the a big scoop, a carby or even a supercharger?
  2. Back to 6 stud's again... Now to pick up were I left off 2 days ago!
  3. Maybe I should since we only have 1/8 mile here now 🤔
  4. Looks a bit more like a motor again! Tried to bolt the manifold on this afternoon and managed to pull a stud out of the head 🤬 will have to wait until Monday now to get a helicoil for it. Once I've done that, it's manifolds on, flywheel, clutch and gearbox and back in the car! Oh and have to change the pilot bearing as it's a bit tight and crunchy.
  5. Agreed. Mine got broken into while it's been off the road for the last 12+ months and they fucked the key barrel trying to start it..... I do wonder how long they tried though before they realised 1, it had no battery in it and 2, the big hole in the transmission tunnel indicated it has no gear box! They are stupid low life's as well! 🙄
  6. They are indeed. Been using them for probably over 10 years.
  7. Oh and just realised I never posted any pics of the damage...
  8. Had the junior mechanic on the job. Head on, and he helped me do valve clearances. It's looking more like an engine again now. Everything has been cleaned and painted again. Then once it's back in the car I'll give the alloy a polish again. Main changes this time are; Another half mm over (now 1mm from stock) Full balance New hdcb exedy - t18 200mm kit Pulling the 315cc injectors and dropping in some 550cc, since last time it was on the dyno we maxed them at 16psi
  9. .... And just over a year on... 😲 There be progress!
  10. I just gapped a set of rings for my 5k the other day. What clearance did you do them too? If you did it properly and they were fine sitting in the bores on their own then the problem must lie in the ring/piston combo! Got a set of verniers? Compare the ring depth to the groove in the piston.
  11. You didn't get one of my copper em30's banjo?
  12. Wondered if you ever used those
  13. Nothing special. Just go to your local nuts and bolts store and it'll likely be a 10c fix!
  14. Can't say it's not consistent! Make a good dial in racer
  15. Just go to foamland Murray St
  16. It would just need 2 leaf spring perches welded on in the right spot
  17. Yes there is a couple of lurkers haha
  18. I'll just aim for fastest manual K! Haha
  19. Good work mate. Looking forward to seeing out on the roads soon. We might have to rouse up a few Rollas for an inauguration cruise for you haha
  20. Yes it might fit. But if the radiator isn't up to the task all that is going to happen is the thermostat will fully open a little earlier and still overheat.
  21. I don't you're getting Dave's point. Factory thermostats were designed to run within the optimal temperature range of the engine. If you want to 'push' said engine past what you deem normal operation and create more heat, this isn't a problem for the thermostat, it's a problem for the radiator. Think about in terms of a thermostat is a heat pump. You want your room at a comfortable 20°. What's going to get there quicker more effectively? The heat pump in the big lounge room or the one in the closet!?
  22. I like engine masters... Even if it is all V8 based. Starting watching them after I worked my way through every roadkill episode lol
  23. Well I'm about to start pulling an engine and box again for the second time in 2 months.
  24. Sometimes the cable will stretch over time and you don't notice so much with a worn old clutch. You might need some extra spacing where the cable comes through the fire wall. You need the cable relatively tort when the pedal isn't depressed.
  25. ∆ on a flywheel that has had a slipping clutch it can get glazed up and not give the best surface for a new clutch plate. With an aggressive clutch ie button you will also get wear similar to a brake rotor so machining becomes essential.
