Trev
Donor
    6398
    29
Everything posted by Trev
  1. Hardly see wagons, looks pimp :D
  2. Boil the kettle next time.
  3. Dash mat is available at supercheap and you have to remove the section where the clock is (inprint on mat). Dash tops are 99% of the time stuffed, good luck with finding a good one.
  4. Dunno why but I had this around the wrong way :D Here is a pic I just scanned:
  5. Nah that is for a 4af* I might go take some pics of my old 4ac and do a guide.
  6. K motors, mx5 drivers aren't the only gay ones :D
  7. All I could find was the piston threads, I mentioned to Dan on AE82 that there is a thread on toymods covering the cranks and I was trying to find it, I also thought that old corollas did a post of the cranks.
  8. Yeah it was, have not seen them as an aftermarket part, I got it from road and track.
  9. I think it was $37, do you have the part number?
  10. Ian do you know where the 'all 4age cranks and rods are forged' thread is on toymods, I could not find it.
  11. No dramas, it popped into my mind when I read this thread and the engine is basically beside me.
  12. Wheels = win, car looks great as it is, well apart from the paint fix on the PS.
  13. Sam if you didn't have both sensors in the block you could turn it upside down. Shitty phone pic I took just for you :D
  14. Did your name just change to Fzlfag666? Shizzle fizzle :D
  15. Earlier in the week I finally fixed the constant running of the thermo fan by bypassing the A/C pressure switch (A/C removed in conversion), it had been doing my head in for a while as I had tried continuity to plugs from the temp switch and checked the relay's, after talking to Justin (med man) the other day he suggested to do a continuity test again but instead I got some fuse wire and just bridged the plug I thought it was and the fan stopped. It has now been plugged using the pressure switch plug looped back into itself. And today I got around to fitting the intake air temp sensor since the series 3 does not have it in the plenum but has it in the airbox, I got one out of a camry so hopefully it will be better on fuel consumption. EDIT: Spelling, this keyboard is really annoying me now.
  16. I think the user Rolla__boy had 17's. on his old KE.
  17. Didn't see that pic till now. Not sure, have seen some with 17's made to fit.
  18. Line the crank gear mark up with the oil pump mark, the cam has to be set so the word 4A is upside down (2A at the top) and the little hole above the word 4A lines up on the centre mark (triangle) on the head. If it isn't clear enough I will draw a pic.
  19. Yes but from this thread you obviously have never had it on the strip.
  20. I might have a look to see what I can find, thanks.
  21. NTR, diff will break at 60 foot :D
  22. New cars intake systems are generally designed for emissions so people change them since they don't flow good enough for power.
