Teddy
Admin
    5784
    5
Everything posted by Teddy
  1. ^^ i arrived 10 minutes after that post (Sleep on the weekends FTW) Complments of the rain, and general crap weather, progress was slowish today. Got the other headlight surround painted, along with the console n lid , bottom steering surround and lower horozontal steering colum plastics & Right hand air vent. Also re-velour striped the air vent, as that gives it that "new firm" feeling hehe. (It had a ting of brown on the upper lip of the plastic; which was enogh for me to pull it out again and redo it) Justin has painted the manifold, TB, TVIS plate, fuel rail and some other bits n pieces on the motor. Its looking really nice. Worked out the new location and started positoning the electric mirror switch. Tested new injector plugs, ordering a set this week (quick-Clip) ~ they fit very smug Found the TVIS wiring that id accdently taped over when i did the loom. Hahah. mnmmmmm i think thats it for today. can't wait for the motor to go in next week :wink:
  2. Ahhh finally someone got this car. Saw it on ebay, and went OOOOOOO. Its got all the goodies underneath :wink: ! Lucky _ man ~ Good luck with the rust
  3. Today, Going back up to work on it, again. Hopefully going to get the insides of the car basically done ~ Seatbelts, Seats, Trims, Dash bits, Motor loom, Ecu & new mounts. Yee !
  4. May take you up on that offer trev :wink: Cheers!
  5. Update teiimmmmeeee !!!!! Yesterday was a long day, thats for sure. Started at about 7:30 for work, finished at 4:30. 4:30 to 8:30 was fixing, taping and restoring engine wiring looom. 8:30 to 11:30 was puting oil pickup on motr, sealing sump, waterpump pully on, crank pully on, clean rail and TB, loosly put on tapet covers, line up and put dizzy in, clean motor, serch workhop for middle cam cover plastic that some C*nt has walked off with. guh... Today, motor will be going up to see car, again. Its going to have to get painted, and other things added to it before it can go back in. But ive been at it all week, and its close enough now. Motor will not be running this weekend. Update later today. :wink:
  6. ^^ R R R O O O F F F L L L
  7. Champion effort !
  8. Maybe it was discussed above, i can't remember / didnt read it ~ but wow, how are those carbs going to work on such an angle? lol
  9. ABBA :P
  10. Either way, I'm still coming :P
  11. mmm heres the switch, its before we reco'd it tho. I don't even think justin took an after pic of it; will get a new one. :P
  12. Motor back from chiltons engineering shop. - block crack tested and pressure tested - block pressure cleaned and washed - block bored and honed, machined top and straight edge checked - Oil galleries and ports flushed out - New welsh plugs installed - Crank track crank, grinded straight - Balanced crank - Pressure plate / flywheel / rods / pistons balanced - New 50" o/Size pistons - Crack tested rods - Pistons to rods assembled - Bearings to suit provided for Crank n Rods - Cyl head crack tested, pressure tested, cleaned. - New valve stem seals, new springs, valves reset. Seats cut - 3 broken studs removed and replaced - Cyl head machined flat, more of a machine if anything.. mmm i think thats it. Assembled Block to engine stand. Cleaned Block. Installed Crank & caps, Flexigauge checked all - all ok. Installed crank. Installed Piston rings to pistsons. Installed pitons into block. Flexigauge checked all - all ok. installed Caps. Checked endfloat, withinspec. Hylmoar headgasket. Clean block and head. Install head, torque down. Install Cams. Torque down. Disassembled oil pump, oil pump gears f*#@ed. Replaced oil pump front assembly, genuine. Vasso Packed new oil pump, re assembled, installed. Permatex seal. Checked rear main seal. Leaking, early life installed crooked. removed, cleaned, installed new seal, just past old ridge to prevent any possible future leaking. Installed rear cap assembly. Wire wheel'd down sump and bash plate, to remove old sealer. Found sump and plate damaged, fixed up and bashed straight. mmm.. Hotwashed Oil pickup and sump. Disassembled water pump, pump had excessive play. Replaced with genuine pump. Thermostat stuck, Replaced thermostat. Hot washed all water pump parts. Installed all parts together, then put onto motor. Used all new bolts. Installed crank cog & slot, Installed cam gears (hot washed cam gears). Found idler bearing fcekd, replaced genuine. Belt new genuine. Installed timing belt, motor turns nicely now. Dizzy leaking internally, Priced new unit - $850, no longer available. Disassembled dizzy, (punched pin on shaft, removed internals, pushed shaft out). Removed bearing and inner seal, hunted down new bearing and internal seal, ended upat BCB bearings, rare as item. Replaced bearing, and internal seal. Hot washed dizzy shell. Reassembled. Replaced external seal, hard as a rock. Installed onto motor. Injectors badly worn. Injjectors had major overhaul. Now working evenly and corectly. Hot washed manifold, engine mount brackets, engine brackets.. anything to remove all the paint. Will fix again later. Ugh, what a financially crippling week. i wish this car would just drive already :D
  13. thats SO hot ! o m g !
  14. did you try calling for your 3rd gear? maybe it just got lost...
  15. LOL ive got the origional philips screwdriver in my boot from that car, i found it and used it to get me some corona advanti mirrors LOL !
  16. TICK OF APPROVAL ! HELL _ YES !
  17. lol bring the ovlov wagon-o-slap out jason :lolcry:
  18. id love to try this sort of thing, with about 50 more HP and possibly see what peoples fasinations with locked diff's is... lol
  19. lol *Tank Slap*
  20. Cllicketh my link And the gods said, Let there be Square cars that are RWD. Gympie Skidpan & Angry 4k FTW :lolcry:
  21. :lolcry:
  22. oh dear gawd. 10 points for origionality, but haha an add dedicated for cat's piss. Great watch; esp the behind the sceens.
  23. +1 for revenue +1 for knowing where to speed just past the camera's +1 for Vandals & having a Field day on these new box's -1 for unsuspecting people just keeping with traffic -1 for bandaid fix of a big problem -1 consistency, accuracy and fairness +1 for donut consumptions in selected areas... ffs.
  24. Lesley, I know the pain you are feeling, but i think you have done well to get this much so far haha. It sounds like your dealership has looked after you pretty well, from what ive seen. All new parts come with some form of warrenty, to an extent. Like all new things. Reaistically, if you got a new turbo NOW, in warrenty, and 2 weeks later it blew up (outside of "vehicle warrenty"); provided your servious history is good for the vehicle, it looks like its all legit and you HAVE NOT touched anything, to warrent its failure; it would fall into 2 cadigitorys; 1) Parts warrenty - you get warrenty on the part (its different for everything, so keep this in mind) and its replaced at there cost, as its a faulty 'part' 2) out of warrenty consideration form - that your dealer fills in. Chances are, if everythings going ok and you have done nothing wrong, then they may get it. How much turbo work has your car had? Jeezzz.. ! We never get any 112's in @ work with big problems. Un looked after, they are good for about 150 / 200 (thousand) kms, before they really need to be binned - the motor that is haha. Ahh...
  25. i LOVE watching marcial arts. i can't do it for shite, tried it. I'm totalllly unko. hahah
