post-1769-1174092870_thumb.jpgOriginally Posted by ToDa30/4
This car has done 245 kmph, ive had the GT4 6 years ,started off with the usual mods we all do and got carried away,motor built by Chris Miltons in Adelaide ,fabrication ,install & dramas sorted by Mark Mills of MADAZ Motorsport ( Top Guy ) and myself
remote oil filter
simmons 16" F90's
Toyo Gran Trampio 225/45's
ARP fixings thru out
braided brake lines
HKS pistons
HKS valve springs
HKS 1.6mm head gasket
HKS 264o cams both sides
HKS adj. cam wheels
JUN titanium retainers
Ferera 1mm o/s s.steel necked valves
Bronze guides
TRD thermostat
Unorthodox alloy crank pulley
Fererra Alloy fly wheel
Extreme 5 puc single plate clutch ,good so far maybe twin plate latter
Speed Source braided clutch line & slave cylinder rod
Speed source brass gear link bushes
TWM short shifter
Fensport alloy pullies
RMR alloy bell mouth plenumrossmachineracing.com
stock 55mm. t/body ,have a ford 70mm to go on
Madaz custom duel feed fuel rail
800cc side feed inj.
XS hi preasure Fuel reg.
Walbro fuel pump
Aussie headers
Aussie 3" dump HPC treated modified for GT turbo outlet
3' straight thru exhaust ,with a cannon with 41/2"outlet
10mm Top gun leads
Link plus ECU
Crane ignition module
HKS elec boost control
White line full suspension kit with front strut brace
Kings super low springs
Koni adj. strut insrts
DBA slotted discs x4
lucas pads , may need to upgrade here
AH UK. Ltd FMIC 645 x 160 x 95 ,600hp rated
Garrett GT35 600hp b/bearing turbo
Tial 38mm. waste gate
twin 12" elec fans
custom 4" alloy turbo intake
K& N 4' x 5" pod
Velo rece seat
cam lok 5 pt. harness
GFB bovus maximus BOV
cusco lower front brace
custom rear strut brace
Ok thats about it plans are I'm stripping the car out to get as light as i can, will be using the car for ANDRA sports compact Sports AWD class , run it at mallala & the collingrove hill climb, i had to put the project aside but am now back into it ready for the track april 07
I'm getting bored here guys !. don't believe everything posted on offical sites ,lots of firfeys are told by corperations ,do we have a whats the fastest car YOU own thread , if not lets :D
  • Replies 84
Just out of curiosity, Did you find out if it ran 2 engines or not?
Id like to know since i have been told the car i idolised is a load of shit.
Any one ?
In all truth, it probably was both in different incarnations.
Rally of Q is this weekend, so Chris is probably preparing rally cars, so I'd expect him to be back next week.
I always thought it was twin engined too, but I think that was from what GTA told me.
After having looked it up just the other day I found specs on a 1996 one,
Year 1996
Make Suzuki
Model Escudo Pikes Peak Version
Engine Location Front
Drive Type 4WD
Weight 1886 lbs | 855.5 kg
Engine
Engine Configuration V
Cylinders 6
Aspiration/Induction Twin-turbocharged
Displacement 1998.00 cc | 121.9 cu in. | 2 L.
Valves 18 valves.
3 valves per cylinder.
Horsepower 987.00 BHP (726.4 KW)
HP to Weight Ratio 1.9 LB / HP
HP / Liter 493.5 BHP / Liter
So maybe the earlier ones were twin engine? Like around the time that GTA came out?
Year 1996
Make Suzuki
Drive Type 4WD
Engine
Cylinders 6
Valves 18 valves.
The photo that TRD Ke70 posted was taken in 2004 at Race to the Sky in NZ, so those specs are 8 years out of date.
Well, as I don't own it this may not count... ahh well
Forgive me.. I'm not sure of the model... The newest corvette, there bloody fast and handle like nothing I have been in! A company in Melbourne that does the right hand drive conversions used to be next door to my work, the owner brought one if them over pretty much just off the boat (minus the passenger seat) and took us for a spin around the block... was pretty interesting while sitting on the front floor!
Another thing they have in there workshops are the new humbers... suprisingly quick for something of that size!
Just thought I would share...
Jarrad
XB GT Coupe. Off its tits 351 Cleveland, 4 Speed Toploader and 9" LSD. 265's on the rear and had no drama's spinning them in 3rd gear. It was almost undriveable in the wet.
